Page 4 of 5 1 2 3 4 5
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2032925
03/17/16 06:34 AM
03/17/16 06:34 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Originally Posted By lockjaw-express
Hi JBC, yes, I have been thinking that as well...great idea, thank you!
I looked at my car today, and you gave me a great idea. Thank you again.
Also, if someone out there knows how to hide the shifter pushrods and the shifter towers that stick out the tunnel, I am open to all ideas.
This is why I love posting on Moparts...always great ideas!
BR, Mark
Thanks for the response. I bet that is going to be a beast.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: jbc426] #2033420
03/17/16 09:08 PM
03/17/16 09:08 PM
Ohio
lockjaw-express Offline OP
Ohio
Pictures of my 3" custom 304 SS exhaust system that I built to clear the new transmission.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2033488
03/17/16 10:31 PM
03/17/16 10:31 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
U do nice work. I likey
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2033494
03/17/16 10:38 PM
03/17/16 10:38 PM
Ohio
Ohio
Thank you, Rick!
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2034106
03/18/16 09:23 PM
03/18/16 09:23 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I am a little worried about that 8 3/4 rear with a healthy big block and a Lenco no
Gus beer
64 Plymouth Savoy
Dana 60
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2034206
03/18/16 11:24 PM
03/18/16 11:24 PM
Ohio
Ohio
Hi Gus,
I will replace the center section with the Aluminum through-bolted unit.
Should be strong enough then.
BR, Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2034214
03/18/16 11:37 PM
03/18/16 11:37 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Very Nice! I will be looking out for you. I'm building a 69 GTX clone street/strip car. Body, suspension and interior is almost done.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2034228
03/19/16 12:09 AM
03/19/16 12:09 AM
Ohio
Ohio
Hi Markz528, very nice GTX and garage!
I live over by the Kenwood Mall here in Cincinnati.
br, Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2034242
03/19/16 12:51 AM
03/19/16 12:51 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
br, Mark
Wish it was my garage. Le Hodge is doing the car body and interior for me. Should be home soon.
You aren't too far away from me..............
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: markz528] #2040031
03/27/16 09:01 PM
03/27/16 09:01 PM
Ohio
Ohio
Update:
New front AMD floor pans sectioned and welded in, primed, seam sealed, painted with body color and installed dynamat over entire front floor.
The dynamat is quite heavy, however I was able to cancel out the additional weight by installing .063 SS mandrel exhaust system which was about 15# lighter than the steel TTI crush bent H-Pipe, and I saved another 5# off of the mufflers.
I still may install a center console to hide the shift rods, and to cover up the holes in the tunnel for the shift towers and the slot for the reverser rod.
New molded carpet set from Brewers was also installed.
More to follow.
Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2040136
03/27/16 11:07 PM
03/27/16 11:07 PM
Washington
madscientist Offline
Washington
IDK but I love the linkage in the cab. Just says the rest of you are pussies.
But that's just me.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2040165
03/27/16 11:32 PM
03/27/16 11:32 PM
Ohio
Ohio
Hi Madscientist, I am concerned how much heat will come through the tower holes since they are oblong cutouts, and that is where the fill plugs are at to fill the transmission full of oil.
Now looking at my pictures, I may not be able to hide much inside the console...maybe I could get a upholstery shop to make a long cover that will slip over with Velcro???
I am a couple of days away from a re-fire of the car :-))
BR, Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2040237
03/28/16 01:34 AM
03/28/16 01:34 AM
Washington
Washington
BR, Mark
I would think a good upholstery shop could make some covers with Velcro. I like the idea. Lif you have to R&R the trans anything you can do to make it quicker is better.
And like I said, I love the look of the shift rods like that.
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2054131
04/14/16 08:43 AM
04/14/16 08:43 AM
Brunswick Ohio
Roadrunner 542+8 Offline
Brunswick Ohio
Hey Mark, your GTX is looking great, love the Lenco!
John
542 Stroker, Dual Quads, Tremec TKO 600 5 Speed, Dana 60 4.10
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2054140
04/14/16 08:58 AM
04/14/16 08:58 AM
Ohio
Ohio
Hi John, thank you!
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2054247
04/14/16 12:33 PM
04/14/16 12:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hi Gus,
BR, Mark
Or the nodular from Dr.diff I just set up and installed in my Dart..............GREAT WORKMANSHIP...........
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2054517
04/14/16 08:09 PM
04/14/16 08:09 PM
Ohio
Ohio
Hi Thumper, but the Aluminum one is lighter and cooler looking ;-))
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2054519
04/14/16 08:13 PM
04/14/16 08:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So true man.............. thumbs
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2071725
05/11/16 09:36 PM
05/11/16 09:36 PM
Ohio
Ohio
Radiator had a small pinhole leak from installation of the engine without pulling the radiator...repaired but leaks.
I installed a Be Cool 1000HP Crossflow retrofit radiator that is much bigger.
Mark
Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project [Re: lockjaw-express] #2071735
05/11/16 09:50 PM
05/11/16 09:50 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Lookin good.
