Re: Lenco ST1200 5spd and Hyatt RS Clutch in '69 GTX Project
[Re: lockjaw-express]
#1987398
01/10/16 04:35 AM
01/10/16 04:35 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
hi Jeremiah,
I have the "old discontinued" bellhousing...are you saying my 15330 bell won't work?
Did you have the later mfg 15335?
I guess I am a little confused on what bell you actually have.
BTW, Chris at Hyatt RS told me that as long as you have the original bellhousing serial number from Lakewood, they can recertify it. Or, you can send back to Lakewood for them to modify and certify.
br, Mark "The old lakewood 15330 was drilled for an a-230 similar to a stock bell. The Lenco adapter plare isdrilled for an a-230. They discontinued the 15330 and superseded the part number to the already existing pn 15335 which does not have the smaller a230 pattern. I purchased another 15335" We now own two Lakewood 15335 bellhousings. Hopefully I can make them work in their respective cars.
#1987476
01/10/16 12:46 PM
01/10/16 12:46 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Hi JericoGTX,
Tim selected a disc that would work both on the street and the strip with high HP...it will slip a small amount for the street, and with reduced static pressure it will slip much more.
I did not get a full answer to that question from Beth or Chris, but then again, a lot has happened for them. They do have other employees from what I could gather.
Have you been driving your clutch on the street?
br, Mark i have one of Tim's clutches, i ran it on the street for a summer. long as your left leg is up to snuff they work good!! It will squeak a bit when its hot if your trying to maneuver around tight spaces like a parking lot. mine would still be in there but i ran out of sacrificial hemi 4 speeds...
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#1987525
01/10/16 01:36 PM
01/10/16 01:36 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Hi pro sport, thank you, however a good friend of mine did the original restoration.
68hemigts,
Thank you for the picture, and I am hoping for good results. Tim Hyatt told me that the Lenco St-1200 would be the best to handle any track use. He also told me that the street manners are very good, and that clutch use would be at a minimum.
I ordered mine with the heavy duty sprags for any driver error for the street.
BTW, Very nice '68 Dart you have!
Br, Mark
#1993763
01/19/16 12:05 AM
01/19/16 12:05 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Those sure are nice I have a few machinist buddies out there that will make one for me after I get the blueprints done. I want to have the register adapter machined so it will do large and small bell openings,just flip it around for whatever retainer you have. Sounds like it's going to be an awesome machine Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#2002134
01/30/16 07:40 PM
01/30/16 07:40 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Here are the pictures of the RobbMC Starter to clear TTI Headers, and a very well made product.
I also used RobbMC Offset dowels, and they are very well made, and worth every penny!
Got everything aligned and ready to mount the Lenco, which should be here around the 8th of February.
#2002400
01/31/16 12:48 AM
01/31/16 12:48 AM
Posts: 525 Shannonville, Ont
Blown 68 R/T
Shannonville, Ont
Mark Sounds awesome! A big Hemi/Lenco , Randy will be smiling up above! Think you're selling yourself short with the 9.90's running 800+hp. keep us posted with your progress, maybe see ya at Norwalk sometime. Kevin
#2002871
01/31/16 08:12 PM
01/31/16 08:12 PM
fourgearsavoy
Rittman Ohio
Yeah I'm sure Randy would approve I'm really glad someone like you got that car.Randy and I discussed putting a stick in that car after his hip surgery but that's about all the further it went. Nice car,hope to have my Savoy back together before Norwalk in July. See you then. Gus
#2010275
02/12/16 01:02 AM
02/12/16 01:02 AM
Posts: 1,505 TN
SCATPACK 1
TN
Hi Rowin4 & sgcuda,
Tim Hyatt told me that the type of disk would be street friendly with the Lenco. The static pressure is set at 1475#, however, I would need to bring that down to 800# for the strip.
Curious question? It is at 1475# now. How many turns in or out does it take to adjust it down to 800#? Thanks Jerry
Old Geezer Racing
