Re: Post your street strip 2nd Gen Hemi combos
[Re: hemi-itis]
#1986794
01/09/16 09:04 AM
01/09/16 09:04 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
My 528 is nearing completion. It is a Mopar Mega block, with ported Mopar heads, Barton rocker system, Kellogg 4.150 crank, custom ground Comp 800+ 55MM nitrous roller cam, custom 4.500 JE 11:1 Pistons, ported Indy tunnel ram with (2) 1050 Dominators and (2) NOS foggers. I am hoping for 9's on motor in my 70 Challenger. Still all steel, full interior, all glass windows. (Still a Steet car)
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: BradH]
#1986819
01/09/16 11:46 AM
01/09/16 11:46 AM
Posts: 5,166 CT
GTX MATT
CT
The OP needs to provide more info on the car. You can run high 10s in a street and strip E body with an OEM-head 440 with the right combination. Ahhh... 10's with a factory 440 and OEM heads??? I am calling BS on that comment. The OP asked what others were running so he could get some idea's for his build. I already posted what I had that fit the description of a 440 with ported OEM heads that could run high 10s, so there is nothing bogus about that. BTW, he didn't say "factory" 440, he said a 440 with OEM heads. Its not OEM heads, but there is a member here from Australia who has a stock stroke 440 with CNCed Stealths running high 10s in a B body who literally uses his car as a daily driver from what I understand. He's 252 @ .050 which is a bit hairy for some for a daily but could be done by many.
[Re: Dragula]
#1986910
01/09/16 02:48 PM
01/09/16 02:48 PM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
I already posted what I had that fit the description of a 440 with ported OEM heads that could run high 10s, so there is nothing bogus about that. BTW, he didn't say "factory" 440, he said a 440 with OEM heads. [/quote] It can be done, we have run 10.87 on a +.030 440 with OEM heads and a steel crank at 446 cubes....It takes work to do, and a good combination of parts. The car cannot be super heavy either and probably isn't the most daily driver friendly, but we have done it....With a stroker, the ET drops into the 9's on pump gas RB with after market heads. [/quote] Agree, we did it back in late 70s 440-.030 over 906 stock heads 800 dp 68 Dart, was a race car though, but could have been driven on the street. 10.80s-122 3040lbs.
[Re: 70VcodeCoronetRT]
#1986938
01/09/16 03:45 PM
01/09/16 03:45 PM
Posts: 1,629 pa
572charger
pa
mine is a 606 cuin its a pump gas 12 to 1 compression hemi stage V heads barton single dominator intake in a mopar steel block it has run 9.60s at 140 mph in a 3910 lb charger on the motor on 93 octane !!!!! i just put all the parts in aluminum indy block that is 180 lbs lighter than mopar block hope to get it to the track this year !!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Dragula]
#1986942
01/09/16 03:51 PM
01/09/16 03:51 PM
Posts: 1,505 TN
SCATPACK 1
TN
I already posted what I had that fit the description of a 440 with ported OEM heads that could run high 10s, so there is nothing bogus about that. BTW, he didn't say "factory" 440, he said a 440 with OEM heads. [/quote] It can be done, we have run 10.87 on a +.030 440 with OEM heads and a steel crank at 446 cubes....It takes work to do, and a good combination of parts. The car cannot be super heavy either and probably isn't the most daily driver friendly, but we have done it....With a stroker, the ET drops into the 9's on pump gas RB with after market heads. [/quote] OK with ported heads and a stroked 440 but at what car weight? Not arguing, just trying to get an understanding.
Old Geezer Racing
[Re: quickd100]
#1987012
01/09/16 05:49 PM
01/09/16 05:49 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Mine is rather head limited and peak hp comes in at 5782rpm and torque peaks at 4818rpm. I shift at 6200. It makes over 800ftlbs from 4100 all the way to 5500rpm. It's REAL fun on the street.Dave I bet that bad boy is a heck of alot of fun to drive on the street. Ron
#1987069
01/09/16 07:25 PM
01/09/16 07:25 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I built this 572" for pump gas street / strip use. World Alum. block, Stage V heads, ported by MCH, 10.5 CP pistons, K1 crank & rods, Indy intake, Stage V rockers, Dwayne Porter spec. Comp solid roller that is on the mild side for longer valve train life. So far I am pleased with it. I had to sit out last season, will be back this year.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
#1988356
01/11/16 12:26 PM
01/11/16 12:26 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
572" hemi, KB block MP heads ported by MCH Dwayne Porter spec'd solid roller...276/284 at fifty, real mild lobes to be easy on parts Barton intake, single 1200 cfm Dominator 11:1 compression for pump gas 727 trans, 4.10 Dana rear, drag radials, Cal-Tracs
On motor and on 93 octane pump gas it has been 9.50s at 140 mph at a little over 3800 lbs.
On a little nitrous and at 3900 lbs. it has been 8.95 at 149.7 mph. It'll definitely go faster...been pretty conservative w/ it so far.
#2015595
02/19/16 06:36 PM
02/19/16 06:36 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Pro-tip: Buy a Challenger Hellcat, A8 trans, swap the supercharger pulleys, get ECU unlocked and buy a tune. Buy a set of wheels and mount some drag radials. Drive it daily and grin. Mount the drag radials for track day. Enjoy the A/C, premium leather, satellite radio, heated steering wheel... It'll be more comfortable at 135mph than your 70 Challenger at 80mph. disclaimer: I prob have hearing loss from my Barton 528 solid cam clatter.
[Re: Vert]
#2021974
02/29/16 05:38 PM
02/29/16 05:38 PM
Posts: 48 the Netherlands
dutchrunner
the Netherlands
1969 RR with 572 Hemi. StageV heads and Modman intake . F&B performance sixpack system regulated by XFI 2.0
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
