Page 16 of 45 1 2 14 15 16 17 18 44 45
Re: Trick Flow heads [Re: fast68plymouth] #1984652
01/06/16 01:16 AM
01/06/16 01:16 AM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Thanks for the info Andy.
Re: Trick Flow heads [Re: AndyF] #1984757
01/06/16 07:35 AM
01/06/16 07:35 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Thanks Andy for the answer .
Would you consider trying a solid ft cam ? I know they give up some power but as these are not a "race" head would this not help the majority of users of this type of head .
I know i might be a Luddite but i am happy to use a cost effective ft cam
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow heads [Re: tex013] #1984796
01/06/16 12:05 PM
01/06/16 12:05 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
has it been determined what head studs or kit is going to be used with these heads. work
Re: Trick Flow heads [Re: tex013] #1985056
01/06/16 07:08 PM
01/06/16 07:08 PM
AndyF Offline
AndyF  Offline
Tex
I found that flat tappet cams were just too expensive for me to use so I switched to roller cams for my dyno engines. I'm already on the third cam in this engine so that would be a lot of lifters if I was using a flat tappet. Plus if you eat a lifter the entire engine needs to be rebuilt which is a couple of weeks of downtime as well as $2000 in parts.
I agree that a flat tappet setup is less money for a "one and done" street engine, but I can't afford to do engine R&D with a flat tappet cam.
Re: Trick Flow heads [Re: fast68plymouth] #1985067
01/06/16 07:28 PM
01/06/16 07:28 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Thanks Andy ,
yes I do understand for R&D a roller is simpler . Thanks again for your input .
Tex
New best MPH 130.32
Re: Trick Flow heads [Re: dartman366] #1985069
01/06/16 07:30 PM
01/06/16 07:30 PM
AndyF Offline
AndyF  Offline
TF has a stud kit listed on their website. The TF kit wasn't available when I built my engine so I made my own stud kit using ARP parts.
Re: Trick Flow heads [Re: AndyF] #1985085
01/06/16 07:48 PM
01/06/16 07:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thank's Andy, I had seen a TF number but didn't know how it corelated with ARP's number's, I will check it out. scope
Re: Trick Flow heads [Re: B Dartman] #1985208
01/06/16 10:34 PM
01/06/16 10:34 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Originally Posted By B Dartman
Originally Posted By Azzkikrcuda
Short Rockers studs ARP-AJ2500-1B
Longer head bolts if you already have a stock length 145-3606 ARP Hex head bolt kit and just want to buy the ten longer bolts instead of a complete 145-3609 kit are ARP-HAP4500-5
up up Thank you!
From Page 7 of the thread: Complete Head Bolt kit is ARP 145-3609...if opted for over studs.
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Trick Flow heads [Re: B Dartman] #1985276
01/06/16 11:50 PM
01/06/16 11:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
up up Thank you!
I am going with stud's and as far as I can tell it is 145-4206 kit w/12pt nut's, if you want stud's w/hex nut's it is 145-4006.
Re: Trick Flow heads [Re: fast68plymouth] #1985586
01/07/16 03:11 PM
01/07/16 03:11 PM
AndyF Offline
AndyF  Offline
Those part numbers are for RPM heads. The center studs will be too short to work on the TF heads. I think we already covered this topic back on page 4 or 5 of this thread.
Re: Trick Flow heads [Re: AndyF] #1985631
01/07/16 04:13 PM
01/07/16 04:13 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Andy, did you check to see if any aluminum valley covers work or are close enough to modify to work with the TF heads?
The only Carbs I care about are under the hood!
Re: Trick Flow heads [Re: Azzkikrcuda] #1985662
01/07/16 05:16 PM
01/07/16 05:16 PM
AndyF Offline
AndyF  Offline
No I didn't. I use a bathtub type valley pan when running std port heads.
Re: Trick Flow heads [Re: AndyF] #1985703
01/07/16 06:18 PM
01/07/16 06:18 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Do you ever have to "port" the bathtub valley pans?
Mine had a little overhang on the outside edges of the ports on my CNC ported stealths.
'63 Dodge 330
11.19 @ 121 mph
Re: Trick Flow heads [Re: fast68plymouth] #1985749
01/07/16 07:00 PM
01/07/16 07:00 PM
AndyF Offline
AndyF  Offline
Well it is getting close to that with these TF heads. I'm considering making my own valley plate so I can just run paper gaskets between the intake and the head. I haven't quite figured out how to do it yet so I'll stare at it some more.
It is possible that the bathtub is costing me some power. There is a slight bit of overhang in a few areas but it isn't much.
Re: Trick Flow heads [Re: AndyF] #1985752
01/07/16 07:03 PM
01/07/16 07:03 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I opened mine up a bit with the dremel.
Re: Trick Flow heads [Re: AndyF] #1985782
01/07/16 07:24 PM
01/07/16 07:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Andy years ago after we decided what intake we liked and were going to stick with we would weld a plate across the bottom of our big block intakes. I wish I had one left to post a picture but its not that hard.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trick Flow heads [Re: GY3] #1985792
01/07/16 07:35 PM
01/07/16 07:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here........
Re: Trick Flow heads [Re: fast68plymouth] #1986113
01/08/16 03:49 AM
01/08/16 03:49 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Me too!
Re: Trick Flow heads [Re: fast68plymouth] #1986565
01/08/16 10:38 PM
01/08/16 10:38 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Picked up Fel-Pro Part# 1215 (Kit: High Performance Valley Pan, 4 Intake Gaskets and Distributor Gasket/O-Ring). Haven't installed yet but just laying in place it appears any trimming would be miniscule.
Re: Trick Flow heads [Re: AndyF] #1986586
01/08/16 11:15 PM
01/08/16 11:15 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Have done this before but had a problem because I made it from thin Aluminium, with vibration it broke the seals on the block ends. So if your going to make one use about 1/4 ali.
1963 Plymouth Max Wedge
1971 Barracuda
