Re: Trick Flow heads
[Re: AndyF]
#1984757
01/06/16 07:35 AM
01/06/16 07:35 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Thanks Andy for the answer . Would you consider trying a solid ft cam ? I know they give up some power but as these are not a "race" head would this not help the majority of users of this type of head . I know i might be a Luddite but i am happy to use a cost effective ft cam
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1985056
01/06/16 07:08 PM
01/06/16 07:08 PM
Posts: 31,082 Oregon
AndyF
Tex I found that flat tappet cams were just too expensive for me to use so I switched to roller cams for my dyno engines. I'm already on the third cam in this engine so that would be a lot of lifters if I was using a flat tappet. Plus if you eat a lifter the entire engine needs to be rebuilt which is a couple of weeks of downtime as well as $2000 in parts. I agree that a flat tappet setup is less money for a "one and done" street engine, but I can't afford to do engine R&D with a flat tappet cam.
[Re: fast68plymouth]
#1985067
01/06/16 07:28 PM
01/06/16 07:28 PM
tex013
Sydney,Australia
Thanks Andy , yes I do understand for R&D a roller is simpler . Thanks again for your input .
Tex
[Re: AndyF]
#1985085
01/06/16 07:48 PM
01/06/16 07:48 PM
dartman366
Mt. Vernon, Ohio
has it been determined what head studs or kit is going to be used with these heads. TF has a stud kit listed on their website. The TF kit wasn't available when I built my engine so I made my own stud kit using ARP parts. Thank's Andy, I had seen a TF number but didn't know how it corelated with ARP's number's, I will check it out.
[Re: B Dartman]
#1985276
01/06/16 11:50 PM
01/06/16 11:50 PM
dartman366
Mt. Vernon, Ohio
Short Rockers studs ARP-AJ2500-1B Longer head bolts if you already have a stock length 145-3606 ARP Hex head bolt kit and just want to buy the ten longer bolts instead of a complete 145-3609 kit are ARP-HAP4500-5 Thank you! From Page 7 of the thread: Complete Head Bolt kit is ARP 145-3609...if opted for over studs. I am going with stud's and as far as I can tell it is 145-4206 kit w/12pt nut's, if you want stud's w/hex nut's it is 145-4006.
[Re: AndyF]
#1985631
01/07/16 04:13 PM
01/07/16 04:13 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Andy, did you check to see if any aluminum valley covers work or are close enough to modify to work with the TF heads?
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#1985662
01/07/16 05:16 PM
01/07/16 05:16 PM
AndyF
Andy, did you check to see if any aluminum valley covers work or are close enough to modify to work with the TF heads? No I didn't. I use a bathtub type valley pan when running std port heads.
[Re: AndyF]
#1985703
01/07/16 06:18 PM
01/07/16 06:18 PM
Posts: 4,704 Wichita
GY3
Wichita
Andy, did you check to see if any aluminum valley covers work or are close enough to modify to work with the TF heads? No I didn't. I use a bathtub type valley pan when running std port heads. Do you ever have to "port" the bathtub valley pans? Mine had a little overhang on the outside edges of the ports on my CNC ported stealths.
[Re: AndyF]
#1985752
01/07/16 07:03 PM
01/07/16 07:03 PM
GY3
Wichita
Well it is getting close to that with these TF heads. I'm considering making my own valley plate so I can just run paper gaskets between the intake and the head. I haven't quite figured out how to do it yet so I'll stare at it some more.
It is possible that the bathtub is costing me some power. There is a slight bit of overhang in a few areas but it isn't much. I opened mine up a bit with the dremel.
[Re: AndyF]
#1985782
01/07/16 07:24 PM
01/07/16 07:24 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It is possible that the bathtub is costing me some power. There is a slight bit of overhang in a few areas but it isn't much. Andy years ago after we decided what intake we liked and were going to stick with we would weld a plate across the bottom of our big block intakes. I wish I had one left to post a picture but its not that hard.
[Re: GY3]
#1985792
01/07/16 07:35 PM
01/07/16 07:35 PM
Thumperdart
State of confusion
It is possible that the bathtub is costing me some power. There is a slight bit of overhang in a few areas but it isn't much. I opened mine up a bit with the dremel. Same here........
[Re: AndyF]
#1986586
01/08/16 11:15 PM
01/08/16 11:15 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
It is possible that the bathtub is costing me some power. There is a slight bit of overhang in a few areas but it isn't much. Have done this before but had a problem because I made it from thin Aluminium, with vibration it broke the seals on the block ends. So if your going to make one use about 1/4 ali.
1963 Plymouth Max Wedge 1971 Barracuda
