Re: Lightweight battery
[Re: Monte_Smith]
#1984324
01/05/16 06:13 PM
01/05/16 06:13 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Most starting problems are the result of poor wiring and over 50% of cars are poorly wired. That big 00 starter cable does you ZERO good, if your ground cable is a 4 gauge cable, with a bolt run through an eyelet somewhere in the trunk. The cable is too small, the starter is NOT in the trunk and your chassis is one of the WORST conductors there is. The most bad azz starter in the world and a diesel truck battery won't fix that. The ground side MUST be as good as the hot side........few are
Monte, Based on your quote above how would your wire your start circuit? Cable/wire size etc. matt
[img] [/img]
[Re: Monte_Smith]
#1984331
01/05/16 06:19 PM
01/05/16 06:19 PM
Thumperdart
State of confusion
My junk likes the wt. in the back but this is good info for sure........... Maybe........maybe not. The weight in the trunk, gives it more rear percentage.........but with less rear percentage, the "hook" issue may have just as easily been fixed with shock adjustments and hitting the tire harder. Too many guys try something a couple times and then conclude "well, that didn't work". You always have to keep in mind, that when you change ONE thing, that may require you to change something else, to get the most benefit from change ONE. Seldom if EVER, is loosing weight from the car a bad change. Just may take a tweak elsewhere to optimize that change Understood, and my first 1/8th mile outing after the wt. removal and only one batt. sucked and spun like never before but still went 6.20 at 111+ mph so ya I need more seat time but again, too fast for a bar so,.......... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: sixpackgut]
#1984360
01/05/16 06:48 PM
01/05/16 06:48 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I run a Braille, weighs 17#. I've had it about 2 years, street and strip.
1979 AMC Spirit, NHRA Q/SA
[Re: clonestocker]
#1984437
01/05/16 08:47 PM
01/05/16 08:47 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte, Based on your quote above how would your wire your start circuit? Cable/wire size etc. matt I like quality 00 cables, with GOOD ends on them. Although I hate it, many insist on grounding the battery to the frame. If you choose to do that, you also need to run a 00 ground cable TO the starter, or at least the engine block, directly from the battery. On the HOT side, I also run 00 cable to a quality starter solenoid, such as a constant duty liftgate solenoid and then 00 from that to starter motor. People need to remember that factory starter solenoids are not rated for constant duty and are also not rated to crank your high compression motor. Do you need a constant duty........NO, but they are better quality and rated for more amp draw.......Another place where big cables, do no good if the solenoid won't pass the juice. The entire starter system needs plenty of flow from hot to ground, with no restrictions or loss of amperage...........It's NOT about voltage. A 00 cable and a speaker wire both carry 12 volts, only one of those will crank your car though
[Re: astjp2]
#1984475
01/05/16 09:45 PM
01/05/16 09:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know my starting system is wired correctly and I WONT pay pay BIG bucks for a battery.. I'll deal with the few pounds extra from the battery and loose the weight elsewhere..the street rod is 2920 with me and 18 gals of fuel and a real battery that was $43 at Costco... if I want less weight.. I'll run 3 gals of fuel instead of 18 gals... even then I most likely wouldnt run that low because I'm too lazy to add fuel every run..... but to each their own if that floats your boat ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: fullmetaljacket]
#1984531
01/05/16 10:55 PM
01/05/16 10:55 PM
Monte_Smith
North Alabama
Monte. R u saying that a 00 ground cable stretching all the way from the negative side/ground of the battery in the trunk and ran all the way to the front to either the starter or the block? Yes sir
[Re: Monte_Smith]
#1984892
01/06/16 02:34 PM
01/06/16 02:34 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Monte, Based on your quote above how would your wire your start circuit? Cable/wire size etc. matt I like quality 00 cables, with GOOD ends on them. Although I hate it, many insist on grounding the battery to the frame. If you choose to do that, you also need to run a 00 ground cable TO the starter, or at least the engine block, directly from the battery. On the HOT side, I also run 00 cable to a quality starter solenoid, such as a constant duty liftgate solenoid and then 00 from that to starter motor. People need to remember that factory starter solenoids are not rated for constant duty and are also not rated to crank your high compression motor. Do you need a constant duty........NO, but they are better quality and rated for more amp draw.......Another place where big cables, do no good if the solenoid won't pass the juice. The entire starter system needs plenty of flow from hot to ground, with no restrictions or loss of amperage...........It's NOT about voltage. A 00 cable and a speaker wire both carry 12 volts, only one of those will crank your car though This how mine is wired. A faulty on/off switch will screw the whole thing up as I experienced last year, but there are less places to look when wired this way. On the Racepac, my voltage and amperage never fluctuates unless something rattles loose, or something breaks like the On/Off switch.
[Re: Monte_Smith]
#1984893
01/06/16 02:34 PM
01/06/16 02:34 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Monte. R u saying that a 00 ground cable stretching all the way from the negative side/ground of the battery in the trunk and ran all the way to the front to either the starter or the block? Yes sir I wired my latest car this way. It starts better then any car I have ever had with just a 12 volt system. I'm a believer. I also didn't use any chassis grounds either. I had a couple junction blocks on the big battery cable and tied everything back to it. All electronics ground back to the battery. Then if using an alternator and trunk battery use a cable. I see people make the mistake of having a battery in the trunk, and alternator up front and using a 10 guage wire to connect them.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: sixpackgut]
#1984903
01/06/16 02:54 PM
01/06/16 02:54 PM
Monte_Smith
North Alabama
The problem lies with the fact that a LARGE percentage of guys simply do NOT understand electricity and how it works. They do not understand the ENTIRE circuit has to be up to the task and that the ENTIRE circuit includes the ground side.
I see NICE cars all the time with a 3 dollar, 4 gauge cable from Auto Zone, that runs from the battery to the chassis and that's IT for ground. The guy is scratching his head wondering why it won't start and nothing works right.
Many have NO idea how a relay works, why you need one, or even what it is........much less how to wire the durn thing. It's pitiful.
I covered in another thread, that the chassis is about the WORST thing you can use as a ground, yet guys continue to do it..........why? Because of the proliferation of "old school" guys who come and say "well, I have done it that way for 40 years and had zero problems".........whatever, fine, good for you, but what works and what works better are two different things. I can get my clothes clean beating them on a rock, but a washing machine works better
[Re: justinp61]
#1984999
01/06/16 05:57 PM
01/06/16 05:57 PM
MR_P_BODY
A buddy of mine has been after me to move my battery to the trunk of my Dart for some time now. Unless something changes when the new engine goes in I don't see it's worth the trouble and expense. I run a group 24 and have never had any start issues. I would like to upgrade the charging system though. The one thing most are not grasping here is.. once you start the car.. you can throw that battery away.. each component needs its own ground so they can talk to one another... the alt runs the car and recharges the battery after the start... put a GOOD alt on it ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: sixpackgut]
#1985000
01/06/16 05:57 PM
01/06/16 05:57 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Monte, I know before you have said that you have nothing in the trunk of the GN. where do you have the battery? I'm really thinking about putting a light weight in and moving it back near the front but...then there is no master cutoff unless you run the wires all they back to the trunk anyway
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1985006
01/06/16 06:06 PM
01/06/16 06:06 PM
Posts: 10,024 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Monte, I know before you have said that you have nothing in the trunk of the GN. where do you have the battery? I'm really thinking about putting a light weight in and moving it back near the front but...then there is no master cutoff unless you run the wires all they back to the trunk anyway Mount the switch up front and use a LONG Morse cable to the back. Works great, no long cables needed.
[Re: sixpackgut]
#1985093
01/06/16 07:58 PM
01/06/16 07:58 PM
Monte_Smith
North Alabama
Monte, I know before you have said that you have nothing in the trunk of the GN. where do you have the battery? I'm really thinking about putting a light weight in and moving it back near the front but...then there is no master cutoff unless you run the wires all they back to the trunk anyway Batt is in pass side floor, as close as I could get it to firewall. Pro-Lite, weighs 9lbs. The master disconnect is mounted inside car as well, with a lever on it that Chad can reach from the seat. Also has a very light Morse type cable that run to back to satisfy the "push" switch rules
