Re: rear shock relocate
[Re: WHITEDART]
#1984149
01/05/16 02:18 PM
01/05/16 02:18 PM
Thumperdart
State of confusion
I left the bottom of the shocks in the Calvert location on the bars but moved em out up top just like factory but as far as they would go towards the wheels in the same factory channel. Then I drilled an access hole to run a sleeve(like stock)through the sheet metal and used the stock upper shock mount bolt and tightened em up and that`s it..........no welding or extra parts needed. Are those lowering blocks for mock up or how you run it............?
[Re: Thumperdart]
#1984163
01/05/16 02:33 PM
01/05/16 02:33 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Yes I run it like that 2in of block..those are steal 1/2 inch each
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Thumperdart]
#1984186
01/05/16 03:20 PM
01/05/16 03:20 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
So much for the "Can`t stack" lowering blocks on a fast car.......... I think he has tested them in the 60' too.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Thumperdart]
#1984387
01/05/16 07:31 PM
01/05/16 07:31 PM
WHITEDART
bean town ....Ca
So much for the "Can`t stack" lowering blocks on a fast car.......... . Dom I bought these from John Calvert and they're designed to be stacked car seems to 60 foot better this way I think F
[Re: fullmetaljacket]
#1984524
01/05/16 10:49 PM
01/05/16 10:49 PM
WHITEDART
bean town ....Ca
What are those shock plates? extended shock plates for more travel? I put those on to give me more shocked options. Also allows me to use a longer shock
[Re: LA360]
#1984731
01/06/16 03:23 AM
01/06/16 03:23 AM
WHITEDART
bean town ....Ca
Is there a performance advantage seems like it would make it really hard to get to the adjuster. My car is fairly low
[Re: WHITEDART]
#1984765
01/06/16 09:54 AM
01/06/16 09:54 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Leave the shocks out back. You're right as far as the ease of adjustment. Also, it puts more weight (although minimal) to the rear of the vehicle. Putting the shocks in front would be better for a rally type of car, where you want as much weight as possible inside of the wheelbase for stability. In back of the axle also gives them a little better protection from road debris.
[image][/image]
[Re: WHITEDART]
#1985317
01/07/16 12:29 AM
01/07/16 12:29 AM
Posts: 6,163 Melbourne , Australia
LA360
Is there a performance advantage seems like it would make it really hard to get to the adjuster. My car is fairly low More control, you're on the pinion side and the shock can control it's movement. Any decently fast Leaf Spring car will run this set up. The fast guys have track times and data to back it up.
Alan Jones
[Re: WHITEDART]
#1985331
01/07/16 12:53 AM
01/07/16 12:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Is there a performance advantage seems like it would make it really hard to get to the adjuster. My car is fairly low What ever the percentage of change there is(from the rear to the front) the shock has to be that much stronger to control the diff
