Re: rear shock relocate [Re: WHITEDART] #1984052
01/05/16 11:10 AM
01/05/16 11:10 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: rear shock relocate [Re: WHITEDART] #1984149
01/05/16 02:18 PM
01/05/16 02:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I left the bottom of the shocks in the Calvert location on the bars but moved em out up top just like factory but as far as they would go towards the wheels in the same factory channel. Then I drilled an access hole to run a sleeve(like stock)through the sheet metal and used the stock upper shock mount bolt and tightened em up and that`s it..........no welding or extra parts needed. thumbs Are those lowering blocks for mock up or how you run it............?
Re: rear shock relocate [Re: Thumperdart] #1984163
01/05/16 02:33 PM
01/05/16 02:33 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Yes I run it like that 2in of block..those are steal 1/2 inch each
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: rear shock relocate [Re: WHITEDART] #1984181
01/05/16 03:10 PM
01/05/16 03:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So much for the "Can`t stack" lowering blocks on a fast car.......... whistling
Re: rear shock relocate [Re: Thumperdart] #1984186
01/05/16 03:20 PM
01/05/16 03:20 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I think he has tested them in the 60' too.
Re: rear shock relocate [Re: 1967dartgt] #1984206
01/05/16 03:40 PM
01/05/16 03:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Running low 9`s I`d say he tested em everywhere......... laugh2
Re: rear shock relocate [Re: Thumperdart] #1984387
01/05/16 07:31 PM
01/05/16 07:31 PM
bean town ....Ca
W
W
bean town ....Ca
. Dom I bought these from John Calvert and they're designed to be stacked car seems to 60 foot better this way I think F
Re: rear shock relocate [Re: WHITEDART] #1984411
01/05/16 08:06 PM
01/05/16 08:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hate how my car sits w/a 29.5x10.5 MT slick compared to the 29x13.5 QTP`s I`ve always ran so I`ll test these at Irwindale and see how I like em before/IF I switch back and lower it even more......... thumbs
Re: rear shock relocate [Re: fullmetaljacket] #1984524
01/05/16 10:49 PM
01/05/16 10:49 PM
bean town ....Ca
W
W
bean town ....Ca
Originally Posted By fullmetaljacket
What are those shock plates? extended shock plates for more travel?
I put those on to give me more shocked options. Also allows me to use a longer shock
Re: rear shock relocate [Re: WHITEDART] #1984548
01/05/16 11:11 PM
01/05/16 11:11 PM
fullmetaljacket Offline
Roger shocker that.
I ask because I'm fabricating a set out of Titanium with an extended shoulder like yours for longer shocks.
Re: rear shock relocate [Re: fullmetaljacket] #1984724
01/06/16 02:55 AM
01/06/16 02:55 AM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Mount the shocks in front of the axle tubes
Alan Jones
Re: rear shock relocate [Re: LA360] #1984731
01/06/16 03:23 AM
01/06/16 03:23 AM
bean town ....Ca
W
W
bean town ....Ca
Is there a performance advantage seems like it would make it really hard to get to the adjuster. My car is fairly low
Re: rear shock relocate [Re: WHITEDART] #1984765
01/06/16 09:54 AM
01/06/16 09:54 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Leave the shocks out back. You're right as far as the ease of adjustment. Also, it puts more weight (although minimal) to the rear of the vehicle. Putting the shocks in front would be better for a rally type of car, where you want as much weight as possible inside of the wheelbase for stability. In back of the axle also gives them a little better protection from road debris.
[image][/image]
Re: rear shock relocate [Re: WHITEDART] #1985317
01/07/16 12:29 AM
01/07/16 12:29 AM
LA360 Online boogie
LA360  Online Boogie
More control, you're on the pinion side and the shock can control it's movement. Any decently fast Leaf Spring car will run this set up. The fast guys have track times and data to back it up.
Alan Jones
Re: rear shock relocate [Re: WHITEDART] #1985328
01/07/16 12:48 AM
01/07/16 12:48 AM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I mounted mine in front of the diff.
Best 60' was a 1.21
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: rear shock relocate [Re: WHITEDART] #1985331
01/07/16 12:53 AM
01/07/16 12:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What ever the percentage of change there is(from the
rear to the front) the shock has to be that much stronger
to control the diff
wave
