Page 15 of 45 1 2 13 14 15 16 17 44 45
Re: Trick Flow heads [Re: Thumperdart] #1975712
12/24/15 03:46 PM
12/24/15 03:46 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By Thumperdart
Originally Posted By ou812
Originally Posted By BradH
Now I'm curious about what the next incarnation of these will be from TF? work
They will have the MW version available mid summer 2016
NOW we`re talkin.............. luck
looks like a possible upgrade, will have to wait and see how they do,,my question would be how much can the present ones be blown out from their currant rendition. work
Re: Trick Flow heads [Re: fast68plymouth] #1975763
12/24/15 05:29 PM
12/24/15 05:29 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Did mock-up install today to evaluate plug clearance with the TTI A-Body (71 Swinger) RB Headers I'm running - Clearance looked good.
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Trick Flow heads [Re: fast68plymouth] #1978943
12/29/15 10:50 PM
12/29/15 10:50 PM
AndyF Offline
AndyF  Offline
I tested a smaller cam today and with a Dominator carb it picked up significant power everywhere over the big cam/850 DP combo that I ran last time. Gained 40 ft-lbs of peak torque and 15 hp at peak. At the bottom of the RPM scale it picked up a ton of power.
Re: Trick Flow heads [Re: fast68plymouth] #1983787
01/04/16 10:28 PM
01/04/16 10:28 PM
AndyF Offline
AndyF  Offline
I weighed the engine after it came off the dyno. 515 lbs complete with water pump, distributor, oil in the pan, etc. Not too shabby for a weight.
Re: Trick Flow heads [Re: fast68plymouth] #1983795
01/04/16 10:35 PM
01/04/16 10:35 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is inline with another fellows 470 B engine with alum topend and oil in it, IIRC 519 lbs.
Mopar to the bone!!!
Re: Trick Flow heads [Re: AndyF] #1983824
01/04/16 11:20 PM
01/04/16 11:20 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Andy the engine stand/dolly that you sell that you have pictured, do you still sell them ? I'd like to get one, IM me here when you get chance
thanks
Keefe
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: Trick Flow heads [Re: fast68plymouth] #1983833
01/04/16 11:23 PM
01/04/16 11:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Are we gonna get to hear what kind of mustard it made with what goodies?
Re: Trick Flow heads [Re: keefe] #1983873
01/05/16 12:03 AM
01/05/16 12:03 AM
AndyF Offline
AndyF  Offline
thanks
Keefe
Yeah that was a super popular product. Very handy too since I was the only guy who used 5 inch casters. The big casters let the engine roll really nice. I had to stop making those dollies though when I lost a key supplier.
Re: Trick Flow heads [Re: HotRodDave] #1983875
01/05/16 12:05 AM
01/05/16 12:05 AM
AndyF Offline
AndyF  Offline
675 hp and 630 ft-lbs of torque are the best numbers so far on pump gas. Still working on it.
Re: Trick Flow heads [Re: AndyF] #1983883
01/05/16 12:27 AM
01/05/16 12:27 AM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
thanks
Keefe
Ok thanks...
Re: Trick Flow heads [Re: fast68plymouth] #1983951
01/05/16 02:28 AM
01/05/16 02:28 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Well we have had one ( yeah 1 ) head show up, might be looking at only making 200HP with this combo if the Australian Customs don't hand the other one over. smile
1963 Plymouth Max Wedge
1971 Barracuda
Re: Trick Flow heads [Re: AndyF] #1984075
01/05/16 12:01 PM
01/05/16 12:01 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Nice,,with a little more compression it should be in the 700 range,,,keep us posted Andy.
Re: Trick Flow heads [Re: ozymaxwedge] #1984077
01/05/16 12:04 PM
01/05/16 12:04 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Called TF yesterday morning and he said mine were about 3 weeks out, probably closer to 2. boogie
Re: Trick Flow heads [Re: fast68plymouth] #1984283
01/05/16 05:27 PM
01/05/16 05:27 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Andy how big is that test mule?
Re: Trick Flow heads [Re: fast68plymouth] #1984288
01/05/16 05:29 PM
01/05/16 05:29 PM
AndyF Offline
AndyF  Offline
It is a low deck 470. 4.375 x 3.91 with 10.5 compression.
Re: Trick Flow heads [Re: AndyF] #1984431
01/05/16 08:33 PM
01/05/16 08:33 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Andy would you mind sharing a little more info far as piston,rods and cam
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Trick Flow heads [Re: fast68plymouth] #1984453
01/05/16 09:15 PM
01/05/16 09:15 PM
AndyF Offline
AndyF  Offline
SCAT superlight crankshaft and I beam connecting rods. Diamond shelf pistons. First cam was a Bullet single pattern, 271/.690. Second cam was Ultradyne single pattern solid roller, 259/.650 lift. Third cam is being ground now. Also have a new carb on the way as well as a few other parts. Should be back on the dyno by the end of the month. The intake manifold needs to be ported but no luck getting that done quickly. Might need to try porting it myself.
Re: Trick Flow heads [Re: fast68plymouth] #1984574
01/05/16 11:31 PM
01/05/16 11:31 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Andy ,
did you try the dominator with the Bullet cam ? I presume the bullet is a flat tappet solid ?
thanks for your input
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow heads [Re: fast68plymouth] #1984606
01/06/16 12:00 AM
01/06/16 12:00 AM
AndyF Offline
AndyF  Offline
I did not try the Dominator with the Bullet cam, I didn't have it in time. The Bullet cam is a solid roller. I think the Bullet would work great if the engine had a little more compression or if it was in a dedicated race car. Low end torque doesn't matter too much if you have a 5000 stall!
Re: Trick Flow heads [Re: dartman366] #1984634
01/06/16 12:48 AM
01/06/16 12:48 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
[/quote]Called TF yesterday morning and he said mine were about 3 weeks out, probably closer to 2. boogie [/quote]
Whoop! Whoop! Good to hear you are getting closer. I'm stalled out waiting for pushrods to arrive.
Did have to remove some material from a corner of the cast valve covers to clear MSD Distributor body (head to distributor clearance is fine).
