Smallblock timing chain stretch help #1979524
12/30/15 06:51 PM
12/30/15 06:51 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
What timing chains are you guys running in your high horsepower smallblocks? We have taken apart three of our strokers this year to freshen up and the chains have had severe stretch! All three were true bullet roller timing chains. I know we put quality chains in, I believe they were Cloyes. Is anyone having better luck with a different brand?
Also we replaced one chain in my dads car with a Milodon gear drive. I heard switching to a gear drive costs horsepower? Is there any truth behind this? Any help would be appreciated.
Thanks, Mark
Re: Smallblock timing chain stretch help [Re: MGC340] #1979582
12/30/15 08:27 PM
12/30/15 08:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Smallblock timing chain stretch help [Re: MGC340] #1979589
12/30/15 08:31 PM
12/30/15 08:31 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
That's the way to go
Re: Smallblock timing chain stretch help [Re: J_BODY] #1979598
12/30/15 08:39 PM
12/30/15 08:39 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Very sweet! But so is the price! Lol
Re: Smallblock timing chain stretch help [Re: MGC340] #1979600
12/30/15 08:40 PM
12/30/15 08:40 PM
bronx n.y
O
O
bronx n.y
Yes it is. If that would bin a chevy it would be 700
Re: Smallblock timing chain stretch help [Re: MGC340] #1979602
12/30/15 08:41 PM
12/30/15 08:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the KB gear drive in all of my race stuff..
I do have a chain with a tensioner in my 416 street
rod.. after the wear to get the edges of the chain
down on the rollers it seems to be working fine.. I
will find out when I see more than 500 miles on it
wave
Re: Smallblock timing chain stretch help [Re: MGC340] #1979606
12/30/15 08:48 PM
12/30/15 08:48 PM
bronx n.y
O
O
bronx n.y
Mr. P u don't like the belt
Re: Smallblock timing chain stretch help [Re: MGC340] #1979609
12/30/15 08:54 PM
12/30/15 08:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
that's what you get when you're a Mo-tard! .....and it's actually cheaper on Ebay! (not chevy cheap, but pocket change cheaper laugh2 )
Re: Smallblock timing chain stretch help [Re: MGC340] #1979612
12/30/15 08:56 PM
12/30/15 08:56 PM
bronx n.y
O
O
bronx n.y
Lol Kool
Re: Smallblock timing chain stretch help [Re: MGC340] #1979614
12/30/15 08:58 PM
12/30/15 08:58 PM
P
Porter67 Offline
Porter67  Offline
P
I think if you checked most after a bit of use you might find most will give a little.
How much stretch are you talking?
Why toss "stroker" when the majority spin less or equal rpm vs other builds?
Just asking because it seems you just stumbeled on the reason people look for other options.
But ive ran rollmaster with a tensioner on all mine that stayed under 7500 and replace as/if needed.
Re: Smallblock timing chain stretch help [Re: MGC340] #1979635
12/30/15 09:12 PM
12/30/15 09:12 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Had the same problem with my BB chains went to this setup 3 seasons later their still good.
P/N are for BB but you should be able to find it in a small.
Summit part numbers
Race Billet True® Roller (9 Keyway) 9-3625TX9 _
Race Billet True® Roller (3 Keyway) 9-3625TX3 _
Here is a small block P/N CLO-9-3603X9
Re: Smallblock timing chain stretch help [Re: one bad fish] #1979637
12/30/15 09:13 PM
12/30/15 09:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not really a fan of them... way too pricey and you end up
replacing the belt after time... the gear drive has been
great for years now(one engine has 15 years on the gear
drive)
EDIT
The belt drive was good for 1 thing in my opinion..
that was to help control harmonics on the engine..
I havent seen it to be worried about it but I dont
build big power.. I just turn more RPM
wave
Re: Smallblock timing chain stretch help [Re: MGC340] #1979649
12/30/15 09:35 PM
12/30/15 09:35 PM
bronx n.y
O
O
bronx n.y
Kool
Re: Smallblock timing chain stretch help [Re: MGC340] #1979707
12/30/15 10:57 PM
12/30/15 10:57 PM
crabman173
crabman173
Stutter boxes Kill chains
I know you did not mention having one but..if you do then chains are wearable item that needs replacement
Chain quality is not what it used to be either
soak chain in oil day or two before install--it helps
Re: Smallblock timing chain stretch help [Re: Porter67] #1979784
12/31/15 12:20 AM
12/31/15 12:20 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
I know Stroker doesn't have to do with the stretch on our motors just stating they were stroker motors is all. My brothers .030 360 had the same chain same stretch in it. It's enough stretch that I think a guy could take a link out to make up for the difference. 3 seasons on a chain I know is plenty. Just was curious if anyone had better luck with other pieces.
Re: Smallblock timing chain stretch help [Re: Porter67] #1979786
12/31/15 12:22 AM
12/31/15 12:22 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
We were looking at running a tensioner. You've had good luck running one then? Thanks, Mark
Re: Smallblock timing chain stretch help [Re: J_BODY] #1979789
12/31/15 12:23 AM
12/31/15 12:23 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
It's a chebby world! 🤑
Re: Smallblock timing chain stretch help [Re: JD Dart] #1979791
12/31/15 12:25 AM
12/31/15 12:25 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Summit part numbers
Thanks I'll check that out👍🏻
Re: Smallblock timing chain stretch help [Re: ] #1979792
12/31/15 12:26 AM
12/31/15 12:26 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
No stutter boxes.
Re: Smallblock timing chain stretch help [Re: MR_P_BODY] #1979822
12/31/15 12:46 AM
12/31/15 12:46 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
wave
Mr P Body,
What KB gear drive are you running? I was on there website and they only list for big block applications. Did you buy your before they were discontinued?
Thanks, Mark
