Page 2 of 3 1 2 3
Re: 440 engine build w/existing drivetrain [Re: cgall] #1979331
12/30/15 03:05 PM
12/30/15 03:05 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Originally Posted By cgall
If you are serious about fun only, it would be no fun to build a 500" engine and then start breaking clutch and driveline parts. I would use the parts you have and add h-beam rods and forged flat-top pistons. now you have a shortblock that will live through missed shifts and a shot of nitrous if you so desire. I recommend Rob Nixon at Smythe Automotive for any machine or assembly work you may need.
Yes!!! I agree!!!!!
Been there, done that. If you don't want to open up a huge can of worms I would stick with a 440 ci. I built a monster 505 ci and have been upgrading driveline parts ever since.
Re: 440 engine build w/existing drivetrain [Re: ccdave] #1979772
12/31/15 12:04 AM
12/31/15 12:04 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
im gonna be using my six pack setup off my old motor so there's no chance I'll ever be playin with the nitrous. The car already has the Strange S-60 Dana with Spicer 4:10s from Cass (Dr. Diff)as well as their driveshaft with the Chevy u-joints. The 4 speed is tough enough on it's own, so what is there to break with a 505?
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1979776
12/31/15 12:07 AM
12/31/15 12:07 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
sorry guys: many times I just assume that people knew my last combo and how great it ran for how simple it was, and i was breakin crap all the time, hence the upgrades....
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1979788
12/31/15 12:23 AM
12/31/15 12:23 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Yes,
my 727 was not up for the task of over 650 ft lbs of torque so I pulled it this fall and upgraded several parts within the trans. I also replaces my 10 year old U joints.
Having a significant amount more torque unveiled the shortcomings of old stock parts.
Re: 440 engine build w/existing drivetrain [Re: Cab_Burge] #1992358
01/17/16 01:43 AM
01/17/16 01:43 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
thanks for all the advice, my head is now spinning nut I will buy a kit Monday
Re: 440 engine build w/existing drivetrain [Re: ccdave] #1992414
01/17/16 04:55 AM
01/17/16 04:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes!!! I agree!!!!!
I agree since he is running a stick shift. But I will say that my 63 was running mid 11's with my old 440 and now has run 10.70's and since its an auto car I have not broke any drivetrain parts since I put the 493 in the car in June 2011. Course I dont race every weekend as I only race about twice a year. Its mostly a street driven car that I cruise around in taking it easy most of the time. I am using an 8-3/4 but I want to change to a Dana when I can afford too. My driveshaft uses the bigger U-joints and I bought it from Mancini as I believe the company that made it was called "Victory". Ron
Re: 440 engine build w/existing drivetrain [Re: 383man] #1992660
01/17/16 03:46 PM
01/17/16 03:46 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
so even if i already have the upgraded S-60 and driveshaft with the 1350 joints you would stay 440?
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1992661
01/17/16 03:47 PM
01/17/16 03:47 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
my thought was to buy the 505 kit from say 440 source, use my 906 arrowheads that have been in a box for 10plus years. use the racer brown cam i mentioned above. and be good to go?
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1992979
01/17/16 10:17 PM
01/17/16 10:17 PM
Weak parts and traction break parts, not HP work I did learn that on racing a 4 speed car that you must feed the driveline devil, you can feed it tires, clutches,gears, tranny parts, U joints or you pick the part you want to fail or replace often shruggy whistling devil
AKA, it won't break parts when it is spinning the tires at the command of your right foot work shruggy Been there done that with my last pump gas street car that ran low tens and high nines in the 1/4 mile boogie devil
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1993801
01/19/16 12:47 AM
01/19/16 12:47 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
I sent this email to Mancini as well as 440S and Mark Z. If anyone has an opinion, I welcome it! (that's why we're here,right?)
I need a rotating assembly, Car is a 3840 lb b-body 4-speed with an Strange S-60 4.10 gears (spicer) also upgraded driveshaft with HD 1350 joints. Lost my forged crank in a 383 zero decked block,78cc iron heads and TRW domed 12.5-1 pistons. intake side was milled to match the six pack intake.
I now have a 70's 440 block line bored, torque plate honed 0.30 and need a rotating assembly. planning on using arrowhead reconditioned heads (2.14 and 1.81) been in the box for 12 years now. I have a Racer Brown cam #STH-42 Hydraulic 5.20 lift (intake/exhaust) and 254 duration at 0.50" lobe separation intake 105 exhaust 111 separation 108.00 advanced 3.0
I'm going to use the six pack setup again (need an RB Edelbrock 6-pack intake) as well as this Racer brown Cam/lifter that I already have.
I need a recommendation as to which stroker kit you would use (MRE440493F84-6B3d) or a 512 kit, or other?
I will also need windage tray,oil pump/oil pan/oil pickup (3/8 or 1/2?),HD timing chain(double roller or true roller?)/chain cover, water pump housing and water pump, and distributor (Mallory Unilite is what I had in the 383)
Goals: I'm looking to build the biggest short block I can afford to enjoy now. The only thing I may add later are budget aluminum heads...
Thanks,
John
513-312-2038
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1994678
01/20/16 03:02 AM
01/20/16 03:02 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
thoughts anyone?
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1994722
01/20/16 04:45 AM
01/20/16 04:45 AM
4.250 stroke crank with 2.200 BB Chevy rod journal sizes, 7.100 long BB Chevy H beam forged steel rod, shelf piston with either a reverse dome or a dish that will give you between 10.0 to 1 to 10.7 to1 compression ratio with the aluminum heads you buy or lower the compression ratio to no more than 9.5 to 1 with your iron heads thumbs True roller timing set and degee the cam you select twocents Six paks rock thumbs My last 400 block 518 C.I. stroker six pak motor made 720 HP with 712 Ft lbs on Oregon 91 octane pump swill boogie That baby put many smiles on my face as well as made the old phincter pucker more than once on the street boogie devil
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1994847
01/20/16 01:23 PM
01/20/16 01:23 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
thoughts anyone?
yes
your head choice .... sounds like you wantto build a 500 inch shortblock and you couldn't have chosen a worse head to run ...
oh wait , you aren't using junkyard fresh 516's ...
fan
Mainstream Media is the new Pravda
Re: 440 engine build w/existing drivetrain [Re: Cab_Burge] #1994859
01/20/16 01:36 PM
01/20/16 01:36 PM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
And why are we putting Chevy garbage in a Mopar engine?
440source.com has a lot to offer and knowledge.
Re: 440 engine build w/existing drivetrain [Re: WS68SSC] #1994955
01/20/16 04:01 PM
01/20/16 04:01 PM
Because I've been building and racing Mopars a lot longer than Brandon has been selling his kits work I've sold Brandon parts long before he opended his business shock work shruggy I'm really glad that he did open and continues to operate 440 Source up bow We Mopar racers need all the help we can get thumbs Now as far as "chevy" parts I don't buy anything from GM to use in any of my Mopar motors, it is all race parts design to fit into Chevy motors also, at a lot better price work shruggy Using a smaller rod journal sizes reduces the rod weight and bearing speed and doesn't dangerously harm the strength of the forged steel crankshafts or rods up Selecting the best parts available to use when desiging racing motors combination with the best parts availble is the smartest thing to do when racing, correct work
Re: 440 engine build w/existing drivetrain [Re: JohnRR] #1995314
01/21/16 02:01 AM
01/21/16 02:01 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
when extra money permits..... i will upgrade to aluminum heads, i realize iron heads are a thing of the past. I want to build the biggest short block I can afford now, and look forward to "weekend upgrades" later!
Re: 440 engine build w/existing drivetrain [Re: WS68SSC] #1995318
01/21/16 02:06 AM
01/21/16 02:06 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Yes, 440 Source has a great website, where's the offers and knowledge??? No telephone or email replies. not trying to be rude but they have not responded to my email or telephone message.
Re: 440 engine build w/existing drivetrain [Re: Cab_Burge] #1995321
01/21/16 02:09 AM
01/21/16 02:09 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
4.250 stroke crank with 2.200 BB Chevy rod journal sizes, 7.100 long BB Chevy H beam forged steel rod, shelf piston with either a reverse dome or a dish that will give you between 10.0 to 1 to 10.7 to1 compression ratio with the aluminum heads you buy or lower the compression ratio to no more than 9.5 to 1 with your iron heads.
who offers this crank selection?
Re: 440 engine build w/existing drivetrain [Re: jcastle1] #1995372
01/21/16 05:30 AM
01/21/16 05:30 AM
Ohio Crankshaft CO, Molnar, Scat and several other crank companys or importers names that are not popping up in my head right now shruggy The last three 4.250 and 4.300 stroke cranks that I used in my latest stroker builds where originally 4.150 forge steel imported stroker cranks with BB Mopar rod journal sizes that I bought on the cheap and I had them offset ground down to 2.200 and offset ground to 4.250 and 4.300 stroke here locally by a good machine shop work
Lots of different ways to accomplish your goals up scope
I've also bought old top fuel cranks with 4.500 stroke with the stock Mopar rod journal sizes and had them ground down and offset destroked to 4.375 work Lots of choices out there up
Re: 440 engine build w/existing drivetrain [Re: WS68SSC] #1996051
01/22/16 01:31 AM
01/22/16 01:31 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Hmmm. Not sure where to start w this comment....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Page 2 of 3 1 2 3
