Re: Smallblock timing chain stretch help
[Re: MGC340]
#1979844
12/31/15 01:05 AM
12/31/15 01:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I run the KB gear drive in all of my race stuff.. I do have a chain with a tensioner in my 416 street rod.. after the wear to get the edges of the chain down on the rollers it seems to be working fine.. I will find out when I see more than 500 miles on it Mr P Body, What KB gear drive are you running? I was on there website and they only list for big block applications. Did you buy your before they were discontinued? Thanks, Mark It was from MP... I ended up buying 3 of them over time... I dont know if they quit making them or not ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1979877
12/31/15 01:46 AM
12/31/15 01:46 AM
Posts: 127 Sioux Falls, SD
MGC340
Sioux Falls, SD
I run the KB gear drive in all of my race stuff.. I do have a chain with a tensioner in my 416 street rod.. after the wear to get the edges of the chain down on the rollers it seems to be working fine.. I will find out when I see more than 500 miles on it Mr P Body, What KB gear drive are you running? I was on there website and they only list for big block applications. Did you buy your before they were discontinued? Thanks, Mark It was from MP... I ended up buying 3 of them over time... I dont know if they quit making them or not Thanks I'll look into it! I appreciate the help!
[Re: MGC340]
#1979898
12/31/15 02:08 AM
12/31/15 02:08 AM
MR_P_BODY
I run the KB gear drive in all of my race stuff.. I do have a chain with a tensioner in my 416 street rod.. after the wear to get the edges of the chain down on the rollers it seems to be working fine.. I will find out when I see more than 500 miles on it Mr P Body, What KB gear drive are you running? I was on there website and they only list for big block applications. Did you buy your before they were discontinued? Thanks, Mark It was from MP... I ended up buying 3 of them over time... I dont know if they quit making them or not Thanks I'll look into it! I appreciate the help! Its a single idler gear drive.. you might look elsewhere for one.... if you want ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Allan_G]
#1981355
01/01/16 07:27 PM
01/01/16 07:27 PM
MR_P_BODY
Looks much like the KB unit.. basically the same mounting for the idler...I used a piece of paper to get the idler clearance.. very simple.. they have been on for years now ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Quicksilver440]
#1981374
01/01/16 07:43 PM
01/01/16 07:43 PM
MR_P_BODY
What are the options for chain tensioners? Is the MP piece the only one available? I thought I read it wasn't as good as the stock tensioners from the magnum motors? If I recall the magnum one is the same.. I believe there was another company making the tensioner also. but I forget the name.. on a double roller chain it will wear quickly until the rollers come into contact.. then it slows right down... that tensioner was designed for the non roller chain like in the production silent chain ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1981398
01/01/16 08:06 PM
01/01/16 08:06 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I've had good results from pre-oiling the chain in synthetic gear oil for a day or two prior to install. It's such a small amount of oil that it hasn't had any bad effects that I can tell.
I use the same gear oil on my chainsaw chains, and it works WAY better, probably 2 or 3 times better than any other chain and bar lube I've ever tried. That's how I got the idea.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: MR_P_BODY]
#1981400
01/01/16 08:06 PM
01/01/16 08:06 PM
dartman366
Mt. Vernon, Ohio
What are the options for chain tensioners? Is the MP piece the only one available? I thought I read it wasn't as good as the stock tensioners from the magnum motors? If I recall the magnum one is the same.. I believe there was another company making the tensioner also. but I forget the name.. on a double roller chain it will wear quickly until the rollers come into contact.. then it slows right down... that tensioner was designed for the non roller chain like in the production silent chain Some of those timing chains had stamping marks on the outer edge that would sometimes wear down the nylon on the tensioner prematurely, almost like saw teeth, the ones that have the smooth edges don't seem to do this, at least not nearly as bad, I have had the same Mopar tensioner on my engine now with 2 different chains and still good as new, I run the Mancini brand which at the time was a re-packaged Rollmaster made in Austrialia.
