Re: collector size for 468 sbm
[Re: R3DART]
#1978612
12/29/15 03:21 PM
12/29/15 03:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hello folks. I am looking for some opinions on whether I should have my headers modified for a bigger collector. I have the 1 7/8 TTI with 3" collector for W2 heads From what I understand, the new version of these headers come with 3.5" collector. So my question is, do you think it's worth it to modify the collector and destroy the coating? How much performance am I leaving on the table by staying with the 3"?
The combo is as follows; 468 ci Indy 245 cnc Pump gas Solid roller 1050 dominator
Car is 3000 lb (with me) abody 727 5200 stall Dana 60- 3:91
Thanks in advance guys. What RPM do you turn... but I would think a 1 7/8 pri and a 3" collector are small... if you want you can PM me and I'll run your engine specs through my header program for the proper headers ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: R3DART]
#1978690
12/29/15 04:52 PM
12/29/15 04:52 PM
MR_P_BODY
Thanks for the response. SpareParts; Not really a max effort although I plan to keep tweaking as I go. Now would be the time for me to do it (change collector) if it made sense. But by the time I get someone to do it and have them recoated, it's not going to be pocket change....
Mr P, I will pm you some specs. I am curious on this, probably no point in fooling with collectors if tube size is not ideal as well. If that turns out to be the case, it makes the decision easier. After you PM me I'll send you what I need.. as for what you have now it might be worth selling them OR changing the collector.. that would be your choice.. I use a 3.5" collector on most anything(either big cubes or high rpm) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: R3DART]
#1979041
12/30/15 12:30 AM
12/30/15 12:30 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I would want to see 2in/3.5 collector for sure on some thing that big.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: R3DART]
#1979043
12/30/15 12:32 AM
12/30/15 12:32 AM
1967dartgt
Hilltown Pa
I am going 2 to 2 1/8 to 2 1/4 with a 4 inch collector on my 422.
[Re: 1967dartgt]
#1979072
12/30/15 01:02 AM
12/30/15 01:02 AM
MR_P_BODY
I am going 2 to 2 1/8 to 2 1/4 with a 4 inch collector on my 422. I just sent him his numbers.. it calls for 2.027" to 2.152" dia and a collector dia of 3.686"to 3.936"with a length of 16.1".... thats for a bigger engine than yours... if you go bigger on dia it also changes the pri lengths...remember that is a timed length based on a dia.... all the specs I quoted are OD with a .062 wall edit for a 3 step headers your diameters are close enough but you need to figure the lengths.. the 4" collector is close enough also... without running numbers
[Re: R3DART]
#1979112
12/30/15 01:38 AM
12/30/15 01:38 AM
1967dartgt
Hilltown Pa
Mines a nos motor so short is your friend. Just need to get heat out as fast as you can with no major restrictions. I was running 2 in with 3.5 collectors before.
[Re: 1967dartgt]
#1979233
12/30/15 11:56 AM
12/30/15 11:56 AM
Posts: 814 in front of the computer
80arrow
I am going 2 to 2 1/8 to 2 1/4 with a 4 inch collector on my 422. Are these something you are building yourself? Or do you have someone lined up to build them?
[Re: 80arrow]
#1979237
12/30/15 12:07 PM
12/30/15 12:07 PM
MR_P_BODY
I am going 2 to 2 1/8 to 2 1/4 with a 4 inch collector on my 422. Are these something you are building yourself? Or do you have someone lined up to build them? These are what I built for my 405ci W-9.. three step 1 7/8- 2 -2 1/8 ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1979251
12/30/15 12:38 PM
12/30/15 12:38 PM
80arrow
I am going 2 to 2 1/8 to 2 1/4 with a 4 inch collector on my 422. Are these something you are building yourself? Or do you have someone lined up to build them? These are what I built for my 405ci W-9.. three step 1 7/8- 2 -2 1/8 Those look awesome. I'm sure I'll have to make my own headers but figured I'd ask about 1967dartgt's set. I really don't want to make a set for my car, lol.
