Page 3 of 4 1 2 3 4
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: therocks] #1978705
12/29/15 05:18 PM
12/29/15 05:18 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
Are you sure you don't have a chevy A833 OD (NP440) trans? I believe it had the old saginaw bolt pattern but could be wrong. Here's a little more info:
http://www.jalopyjournal.com/forum/threads/np-a833-trans-question.697901/
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: JohnRR] #1978728
12/29/15 06:00 PM
12/29/15 06:00 PM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
Originally Posted By JohnRR
Originally Posted By Quicksilver440
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics....
I can't see the picture here at work.
Is this the bell housing I sold you ? It had an alum 833 bolted to it when I found it at the junkyard ????
Yep....I don't think the bell is off...it looks like it matches a BigBlock one I have. I think the hole in the trans if off a little.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: therocks] #1978729
12/29/15 06:01 PM
12/29/15 06:01 PM
Central Valley, CA.
Central Valley, CA.
Originally Posted By therocks
I still say from the pic it looks like the ear was broken off welded and dressed down.Look all around the ear that pics looks like it was broken and fixed.Rocky
you could be right therocks....I'll look at that again.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978747
12/29/15 06:27 PM
12/29/15 06:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Did you take measurements of holes between the 2 ?
Do you have another trans case , or another bell ? either way take measurements between the 2 of whatever you have .
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: blown340] #1978795
12/29/15 07:25 PM
12/29/15 07:25 PM
Central Valley, CA.
Central Valley, CA.
In researching this...I think you figured it out! The saginaw and 833 bolt pattern is almost the same with just that one bolt hole being slightly different. So I have a chevy version of the 833....but it will still work, I'll just slot that hole and I should be good to go. Thanks! Makes me feel better knowing why....
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: JohnRR] #1978796
12/29/15 07:27 PM
12/29/15 07:27 PM
Central Valley, CA.
Central Valley, CA.
I actually do have another trans case (empty) and another bell...I'll measure both just to document the difference. If you see my post above...I think Blown340 got it right...I think it's a GM version of the 833 with the saginaw bolt pattern. I actually have an empty cast iron '75 833 O.D. mopar trans case here that I bought awhile back to swap these internals into to beef up the O.D. a little.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978807
12/29/15 07:47 PM
12/29/15 07:47 PM
Central Valley, CA.
Central Valley, CA.
I just thought of something....if it's a chevy version...does it have the same input shaft as a mopar trans? That could be a problem..... frowwn
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978829
12/29/15 08:17 PM
12/29/15 08:17 PM
Central Valley, CA.
Central Valley, CA.
When I get home...I'll have to count the splines. This article says the GM 833's had 10 spline input shafts.
Hemmings 833 article
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: MoPar] #1978842
12/29/15 08:35 PM
12/29/15 08:35 PM
Central Valley, CA.
Central Valley, CA.
I went back and looked at my pictures...no way that's a 10 spline input shaft.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978884
12/29/15 09:34 PM
12/29/15 09:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I believe the output splines would be different as well if it's a Chevy.
Don't be the exception.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978942
12/29/15 10:48 PM
12/29/15 10:48 PM
JohnRR Offline
JohnRR  Offline
Rob , in case you haven't figured it out those are the trans bolts there on the inside , I just put them there so I could set it on the shelf trans mount side down .
Good to see you figured it out , which hole was it that was off ?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978947
12/29/15 10:52 PM
12/29/15 10:52 PM
JohnRR Offline
JohnRR  Offline
I think mines an 83 date code.
I want to say the truck I got that out of was an 87 ... but I remember it having the 1991 up grille in it ???
I don't know if they were using a hyd clutch in 1983?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978952
12/29/15 11:02 PM
12/29/15 11:02 PM
JohnRR Offline
JohnRR  Offline
that's not a 10 spline , but if it were no biggie , the clutch disc won't care what it's behind , check the driveshaft end though ...
I think I have an output shaft if you need it .
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: JohnRR] #1978957
12/29/15 11:07 PM
12/29/15 11:07 PM
Central Valley, CA.
Central Valley, CA.
Yep...I found the bolts...I appreciate that. It was the passenger side bottom bolt hole on the trans that was off. In my original post I said Drivers side..but I was mistaken.
I'm not sure when the hyd clutch first appeared...I find conflicting info on that.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: JohnRR] #1978959
12/29/15 11:08 PM
12/29/15 11:08 PM
Central Valley, CA.
Central Valley, CA.
Good point about the splines....I worried about the input shaft length though...but I think it's good...I'll check the output splines when I get home. It does have a mopar tailhousing though...so I should be good.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1979102
12/30/15 01:31 AM
12/30/15 01:31 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Input shafts are different lengths also. I have both in the garage and the GM is about an inch shorter.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: astjp2] #1979212
12/30/15 11:10 AM
12/30/15 11:10 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep, that is one reason they cut the input shaft down to run 833's in Chivvy's, the other reason is they need to use a roller bearing in the crank instead of a bushing.
JB Rhinehart, Realist
A-Body's RULE!
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #2340056
07/19/17 11:24 PM
07/19/17 11:24 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Wow....learned something new every day.
Moparlee
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #2340080
07/19/17 11:52 PM
07/19/17 11:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Almost two years later too
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Supercuda] #2340113
07/20/17 01:03 AM
07/20/17 01:03 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
LOL....third generation don't care.
Moparlee
Page 3 of 4 1 2 3 4
