Re: 833 O.D. bolt pattern...one bolt slightly off?
[Re: Quicksilver440]
#1977274
12/27/15 05:57 PM
12/27/15 05:57 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What transmission is in your very first pic, cause I am not seeing that one in your later pics.
Never mind, I see it now, the angle was funky or something.
#1977594
12/28/15 12:45 AM
12/28/15 12:45 AM
Posts: 18,688 Fresno, CA
Jim_Lusk
Fresno, CA
It actually is...just not a commonly used one as its late model and hydraulic clutch. Here's the info:
4471829 1 D 10-3/8", 11" Clutch, A535, A435, A833 Transmission, Except Diesel Engine 1990-91
Also...my BB 833 bell bolt holes match this one but with a smaller Center hole. I also had to look at the first pic several times to figure out the angle and what I was seeing. I would also pull the bearing retainer to see if it fits the early bell. My only guess might be that the case was slightly re-engineered with that hole slightly off.
#1977603
12/28/15 12:50 AM
12/28/15 12:50 AM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
I wish...lol...no this a plain 833 OD my boys are putting in a 64 dodge Sweptline pickup they are building. I just found another old post where someone found something similar and just slotted the hole in the trans.... Ok, I don't know anything about manual transmissions, I didn't realize there was an overdriven 4 speed from the factory, I thought Passon made one for that reason. Very cool, hope it works out for ya.
#1977650
12/28/15 01:43 AM
12/28/15 01:43 AM
Supercuda
About to go away
About to go away
up yours
Pretty sure the A833 was out of production before 90
[Re: ProSport]
#1977694
12/28/15 02:51 AM
12/28/15 02:51 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I wish...lol...no this a plain 833 OD my boys are putting in a 64 dodge Sweptline pickup they are building. I just found another old post where someone found something similar and just slotted the hole in the trans.... Ok, I don't know anything about manual transmissions, I didn't realize there was an overdriven 4 speed from the factory, I thought Passon made one for that reason. Very cool, hope it works out for ya. I wasn't making fun...Passion does make a 18 spline much stronger version with better ratios. The one I have is very weak by comparison.
[Re: Supercuda]
#1977696
12/28/15 02:54 AM
12/28/15 02:54 AM
Quicksilver440
Central Valley, CA.
Pretty sure the A833 was out of production before 90 I know the 833 of was made into the late 80's....not sure about after that. This trans appears to have 3 different trans bolt patterns.
#1977704
12/28/15 03:00 AM
12/28/15 03:00 AM
Posts: 6,033 Salem
Grizzly
Moparts Proctologist
Salem
I dunno about that: I know a guy that ran an 833od for years behind a 511 6 pak in a '69 Charger for years and never broke it. He never lost a race either......... FWIW the hydraulic 833od I just picked up has the slave on the Driver side, just like the linkage set-up OD's. Yours appears to be on the Passenger side?
Mo' Farts
Moderated by "tbagger".
#1977706
12/28/15 03:06 AM
12/28/15 03:06 AM
Supercuda
About to go away
About to go away
up yours
Pretty sure the A833 was out of production before 90 I know the 833 of was made into the late 80's....not sure about after that. This trans appears to have 3 different trans bolt patterns. I have one that's got an 87 date code, FWIW.
[Re: Grizzly]
#1977716
12/28/15 03:45 AM
12/28/15 03:45 AM
Quicksilver440
Central Valley, CA.
I dunno about that: I know a guy that ran an 833od for years behind a 511 6 pak in a '69 Charger for years and never broke it. He never lost a race either......... FWIW the hydraulic 833od I just picked up has the slave on the Driver side, just like the linkage set-up OD's. Yours appears to be on the Passenger side? Yep..mines passenger side. I read there is a similar bell that is s drivers side that maybe came in some of the V6 trucks?
[Re: Supercuda]
#1977719
12/28/15 03:48 AM
12/28/15 03:48 AM
Quicksilver440
Central Valley, CA.
Pretty sure the A833 was out of production before 90 I know the 833 of was made into the late 80's....not sure about after that. This trans appears to have 3 different trans bolt patterns. I have one that's got an 87 date code, FWIW. I think mines an 83 date code.
#1978568
12/29/15 02:24 PM
12/29/15 02:24 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics.... I can't see the picture here at work. Is this the bell housing I sold you ? It had an alum 833 bolted to it when I found it at the junkyard ????
Mainstream Media is the new Pravda
#1978627
12/29/15 03:44 PM
12/29/15 03:44 PM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
I still say from the pic it looks like the ear was broken off welded and dressed down.Look all around the ear that pics looks like it was broken and fixed.Rocky
Chrysler Firepower
