Re: 833 O.D. bolt pattern...one bolt slightly off?
[Re: JohnRR]
#1978728
12/29/15 06:00 PM
12/29/15 06:00 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics.... I can't see the picture here at work. Is this the bell housing I sold you ? It had an alum 833 bolted to it when I found it at the junkyard ???? Yep....I don't think the bell is off...it looks like it matches a BigBlock one I have. I think the hole in the trans if off a little.
[Re: therocks]
#1978729
12/29/15 06:01 PM
12/29/15 06:01 PM
Quicksilver440
Central Valley, CA.
I still say from the pic it looks like the ear was broken off welded and dressed down.Look all around the ear that pics looks like it was broken and fixed.Rocky you could be right therocks....I'll look at that again.
[Re: Quicksilver440]
#1978747
12/29/15 06:27 PM
12/29/15 06:27 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics.... I can't see the picture here at work. Is this the bell housing I sold you ? It had an alum 833 bolted to it when I found it at the junkyard ???? Yep....I don't think the bell is off...it looks like it matches a BigBlock one I have. I think the hole in the trans if off a little. Did you take measurements of holes between the 2 ? Do you have another trans case , or another bell ? either way take measurements between the 2 of whatever you have .
[Re: JohnRR]
#1978796
12/29/15 07:27 PM
12/29/15 07:27 PM
Quicksilver440
Central Valley, CA.
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics.... I can't see the picture here at work. Is this the bell housing I sold you ? It had an alum 833 bolted to it when I found it at the junkyard ???? Yep....I don't think the bell is off...it looks like it matches a BigBlock one I have. I think the hole in the trans if off a little. Did you take measurements of holes between the 2 ? Do you have another trans case , or another bell ? either way take measurements between the 2 of whatever you have . I actually do have another trans case (empty) and another bell...I'll measure both just to document the difference. If you see my post above...I think Blown340 got it right...I think it's a GM version of the 833 with the saginaw bolt pattern. I actually have an empty cast iron '75 833 O.D. mopar trans case here that I bought awhile back to swap these internals into to beef up the O.D. a little.
#1978884
12/29/15 09:34 PM
12/29/15 09:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I believe the output splines would be different as well if it's a Chevy.
#1978942
12/29/15 10:48 PM
12/29/15 10:48 PM
JohnRR
Rob , in case you haven't figured it out those are the trans bolts there on the inside , I just put them there so I could set it on the shelf trans mount side down . Good to see you figured it out , which hole was it that was off ?
#1978947
12/29/15 10:52 PM
12/29/15 10:52 PM
JohnRR
I think mines an 83 date code.
I want to say the truck I got that out of was an 87 ... but I remember it having the 1991 up grille in it ??? I don't know if they were using a hyd clutch in 1983?
#1978952
12/29/15 11:02 PM
12/29/15 11:02 PM
JohnRR
I went back and looked at my pictures...no way that's a 10 spline input shaft. that's not a 10 spline , but if it were no biggie , the clutch disc won't care what it's behind , check the driveshaft end though ... I think I have an output shaft if you need it .
[Re: JohnRR]
#1978957
12/29/15 11:07 PM
12/29/15 11:07 PM
Quicksilver440
Central Valley, CA.
Rob , in case you haven't figured it out those are the trans bolts there on the inside , I just put them there so I could set it on the shelf trans mount side down . Good to see you figured it out , which hole was it that was off ? Yep...I found the bolts...I appreciate that. It was the passenger side bottom bolt hole on the trans that was off. In my original post I said Drivers side..but I was mistaken. I'm not sure when the hyd clutch first appeared...I find conflicting info on that.
[Re: JohnRR]
#1978959
12/29/15 11:08 PM
12/29/15 11:08 PM
Quicksilver440
Central Valley, CA.
I went back and looked at my pictures...no way that's a 10 spline input shaft. that's not a 10 spline , but if it were no biggie , the clutch disc won't care what it's behind , check the driveshaft end though ... I think I have an output shaft if you need it . Good point about the splines....I worried about the input shaft length though...but I think it's good...I'll check the output splines when I get home. It does have a mopar tailhousing though...so I should be good.
#1979102
12/30/15 01:31 AM
12/30/15 01:31 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Input shafts are different lengths also. I have both in the garage and the GM is about an inch shorter.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1979212
12/30/15 11:10 AM
12/30/15 11:10 AM
Posts: 43,615 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yep, that is one reason they cut the input shaft down to run 833's in Chivvy's, the other reason is they need to use a roller bearing in the crank instead of a bushing.
JB Rhinehart, Realist
A-Body's RULE!
#2340080
07/19/17 11:52 PM
07/19/17 11:52 PM
Supercuda
About to go away
About to go away
up yours
Almost two years later too
[Re: Supercuda]
#2340113
07/20/17 01:03 AM
07/20/17 01:03 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Almost two years later too LOL....third generation don't care.
Moparlee
