Re: Appache Heads [Re: 496 A-body] #1984254
01/05/16 04:41 PM
01/05/16 04:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Originally Posted By 496 A-body
Stock intake valve on eagle is 2.050
Ray,having ported both eagles and apaches do you have flow numbers for both heads measured on the same bench and same bore?
yes at home.
on the bore size, I have tried a couple bore sizes and it didn't make any difference since the valves open towards the center. this is completely different then a wedge head.
off memory
my eagles are 275 @.4, 345 @.6 on my car
Apaches I just finished went 312 @.4 and 360 @.6
another set of Apaches hit 320 @ .4 but will need to be tubed. I was working on them last night.
I have not been able to hit the 370/380s like others have at higher lifts
Re: Appache Heads [Re: Max Weg] #1984257
01/05/16 04:43 PM
01/05/16 04:43 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
320 cfm at .400" of lift? Good lord that's a lot of flow
Re: Appache Heads [Re: WO23Coronet] #1984280
01/05/16 05:22 PM
01/05/16 05:22 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Dave Webber claims 325 @ .4 with his CNC program but his numbers stock are a bit higher in the low lift numbers than Mine, Brett's, Matt's, etc so not sure about that. I got 320 before I went to far so we will see what happens after the tube goes in. I can reshape the floor a little also. Might try to copy that thitek head picture and pull a bunch more metal from that side
Re: Appache Heads [Re: sixpackgut] #1984295
01/05/16 05:33 PM
01/05/16 05:33 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Anyone know if these are Webbers numbers? Or MCH?
http://www.buyracingparts.com/cnc-ported-heads/cnc-ported-mopar-heads/images/64cnc6.4flow.jpg
Re: Appache Heads [Re: 496 A-body] #1984314
01/05/16 05:56 PM
01/05/16 05:56 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
top to bottom of the apache combustion chamber is 4.10. I use a pin to locate my sb ford, LS and Hemi head on the bore adapter. on my 4.0 bore, the valve hits and wont open. I can move it so it will open but the chamber is still bigger than 4.0.
They are not Webbers numbers and I have seen a lot of really high numbers posted for all the hemi heads that I really don't know what to make of them.
I port a lot of LS heads and my bench seems very comparable. A GM CNC LS3 head on my bench flows exactly what the published numbers are for that head. same goes for the rest of the LS stuff but when it comes to the GEN Hemi stuff, only comparables are stock numbers from guys on moparts.
Re: Appache Heads [Re: Max Weg] #1985556
01/07/16 02:35 PM
01/07/16 02:35 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Re: Appache Heads [Re: Max Weg] #1986983
01/09/16 04:59 PM
01/09/16 04:59 PM
texas
462hemi Offline
462hemi  Offline
texas
i have had many sets of 6.1, eagle and apache heads ported and flowed on the same machine. these are my typical results
ported 6.1s- 360-370 @6
ported eagles- 355-360@6
ported apaches- 380@6
and the thitek 2.20 valve heads on my 462 flowed 401@6
462 gen 3 hemi daily driven
Re: Appache Heads [Re: 462hemi] #1987706
01/10/16 05:31 PM
01/10/16 05:31 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Is this a comparison with the same valve and bore in each cylinder head?
Adriel Paradise
Substation Design Engineer III
Re: Appache Heads [Re: Adrielp] #2005659
02/04/16 08:48 PM
02/04/16 08:48 PM
texas
462hemi Offline
462hemi  Offline
texas
same valve??? uh no. a stock 6.1 head uses a 2.08 intake valve. a stock eagle valve is 2.05 and a stock apache valve is 2.14. my thitek heads use 2.20 intake valves. bore size was the same in all of them at 4.125. frankly, we changed it from 4" to 4.185" and saw very little flow difference.
Re: Appache Heads [Re: Max Weg] #2005807
02/05/16 12:04 AM
02/05/16 12:04 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Have you ever flowed an early 5.7 head? Also can you tell us about your 462" HEMI?
Re: Appache Heads [Re: 462hemi] #2005901
02/05/16 02:08 AM
02/05/16 02:08 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Are you OsO?
Mopar to the bone!!!
Re: Appache Heads [Re: Max Weg] #2011981
02/14/16 09:02 PM
02/14/16 09:02 PM
texas
462hemi Offline
462hemi  Offline
texas
no......but he is a friend of mine smile
Re: Appache Heads [Re: WO23Coronet] #2011989
02/14/16 09:11 PM
02/14/16 09:11 PM
texas
462hemi Offline
462hemi  Offline
texas
i have flowed ported and non ported early 5.7 heads. without digging them out........i think i remember the early 5.7 stock flowing 270ish and ported 305ish? my 462 is a aluminum blocked motor. 4.200 crankshaft, 4.185 bore. thitek 2.20 heads, lsm cam specd by me,12.8 to 1 comp, arrington 1.7 roller rocker arms, it has a hogan sheetmetal intake on top with a 168mm tbody. it is a pump gas motor and is no kidding what i drive everyday(i dont drive far though). its in a 2006 charger and the goal is to click off some 10.0s in my 4300lb whale. on top of that it has a 300hp nitrous outlet direct port that i will get dialed in after we get the motor on point
Re: Appache Heads [Re: Max Weg] #2012048
02/14/16 10:19 PM
02/14/16 10:19 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Well thanks coming over here and sharing, I thought your build sounded like something I read about on MMF. Need as many guys over here as possible who have already "been there and done that" with these baby Hemi's.
