Re: Swapping cowl - how to do with vin stamps?
[Re: moparx]
#1977815
12/28/15 12:23 PM
12/28/15 12:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
since you live in sweden, what does your DMV say about vin problems ? That is the answer right there. The legal VIN is the tag on the dash, not the stamp in a cowl. So here, at least, what you do with the cowl is irrelevant for identification purposes. What some can't seem to grasp is that taking that legal VIN tag off the dash from a rusty, wore out, tore up, no longer salvageable "collectible" vehicle and putting it on a "donor" is what's illegal. Not fixing a rusty cowl.
[Re: Supercuda]
#1977820
12/28/15 12:33 PM
12/28/15 12:33 PM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
since you live in sweden, what does your DMV say about vin problems ? That is the answer right there. The legal VIN is the tag on the dash, not the stamp in a cowl. So here, at least, what you do with the cowl is irrelevant for identification purposes. What some can't seem to grasp is that taking that legal VIN tag off the dash from a rusty, wore out, tore up, no longer salvageable "collectible" vehicle and putting it on a "donor" is what's illegal. Not fixing a rusty cowl. Steve - some states do a VIN check and verify body stampings when registering an out of state vehicle. I wonder what their procedure is on this? The safe thing for him to do is check w/ his authorities and thoroughly document whatever he does in case of a future sale. This topic has had quite the flogging on this site previously, not that I remember there being a definitive correct answer. -Michael
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
[Re: andben]
#1977825
12/28/15 12:45 PM
12/28/15 12:45 PM
Posts: 18 Sweden
andben
Sweden
Ohh didnt know it was so sensitive for you guys. I apologize. Better to cut out the rust and let everything be and use body filler like you do ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) And No, Swedish government is more realistic than identifying a car with a plastic piece with two nuts.
[Re: Alaskan_TA]
#1978040
12/28/15 07:07 PM
12/28/15 07:07 PM
Supercuda
About to go away
About to go away
up yours
The body stamps are legal identifiers, they are what law enforcement uses to determine VIN fraud cases like dash VIN swaps.
They also use them to determine the original full VIN if it is missing, this is why you see some state issued VINs with the full original VIN as part of the full state issued VIN.
They also know how to check for welds around the numbers using forensics.
As a secondary identifier the body stamps are relevant. If there is an issue with the dash VIN then yeah, they look at body stamps. But what do they look at with pre 68 cars? Or how about even older ones where the engine serial number is the VIN and it has a swapped engine? Best bet is to talk to the relevant authorities first and save yourself some grief and money.
[Re: andben]
#1978108
12/28/15 08:55 PM
12/28/15 08:55 PM
Posts: 12,495 Western Colorado High Desert
moparmarks
When we bring in Cudas and Challengers from out of state we have to run a vin search on them. When the State Trooper comes out to inspect the car he looks at the body numbers. If the body numbers don't match the vin tag and title then we have issues. Having no body numbers is better than having ones that don't match.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Alaskan_TA]
#1978117
12/28/15 09:05 PM
12/28/15 09:05 PM
moparpollack
Lil Herman
Lil Herman
85086
The picture of the major repair and weld it in the correct spot. My friend used to own a frame shop and cut cars in half, section in frame repairs, swapped out roofs, cowls, etc, and this was since the 60. Do you think that every car was checked when sold to the new owner? Never was the fact that the car two made into one talked about or discussed. Cut it up weld it up hand enjoy the car! You never know that you are driving might be an example that someone cut up in the 60s. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
