Re: spark plug recommendation
[Re: mopar dave]
#1977048
12/27/15 12:49 PM
12/27/15 12:49 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
what does "dirty" mean? are there deposits build up on the center porcelain/ electrode? usually a plug is too cold when you have missing under light loads and the plug can't keep the center clean.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#1977056
12/27/15 01:08 PM
12/27/15 01:08 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Define "dirty",,,,,,,,ae you reading after a high gear jaunt??
[Re: mopar dave]
#1977095
12/27/15 02:07 PM
12/27/15 02:07 PM
Thumperdart
State of confusion
There`s guys runnin 7`s up 14.1.1 but I`d go # 8`s.......
[Re: mopar dave]
#1977096
12/27/15 02:09 PM
12/27/15 02:09 PM
Thumperdart
State of confusion
when I say dirty I mean dark brown to black. never foul but just dark in color. the shell is always black at the base of the threads using a 7. street and track. o2 numbers seem to always be in range(12.5-13.1wot) 14.5 idle. iv never been able to do a hard run clean cut pass. they shut the track down til your out of that area at the end of the track. this engines going to the dyno and I need to get some plugs. what do you recommend? Can`t always blame the plugs and need to check out the ign. and carb...................
[Re: bonefish]
#1977139
12/27/15 02:42 PM
12/27/15 02:42 PM
Thumperdart
State of confusion
this may sound bizzar but has anyone ever tried putting several different heat ranges in a motor at the same time then comparing how they look. Yep, years ago I left Cabs house w/a few different plugs in my 360 and read em and went w/Autolites before switching to NGK`s.........
[Re: mopar dave]
#1977244
12/27/15 05:11 PM
12/27/15 05:11 PM
Thumperdart
State of confusion
ok Dom. ill get some 8's and see what they look like after dyno time. Dom, how did the autolites work out for ya? They never did BUT, I`ve got my carb tuning skillz coming around so maybe that would change but not willing to start over when plugs are a major part of the tune...........at least the POROPER ones......
[Re: mopar dave]
#1977265
12/27/15 05:45 PM
12/27/15 05:45 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
I'm going to try Autoite 3910 in the B1 motor I'm dynoing next month, it has right at 13.0 to 1 compression ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) They have worked well for me in many motors on pump gas with lower compression, I'm one of those guys that likes to run my motor lean with the coldest plug I can keep looking good, clean with no color or speckles ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) The ignition timnig, AFR, and the spark plug heat and tip type all contribute to what the spark plugs look like ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) IHTHs ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: mopar dave]
#1977400
12/27/15 09:07 PM
12/27/15 09:07 PM
dartman366
Mt. Vernon, Ohio
ever have any luck with the champion cx series with the cut back strap? I have never run the champions but have run the AR series in autolites with the cut back straps,,AR3910 in my small block with 13.0 to 1.0 comp, work's good for me.
[Re: mopar dave]
#1977442
12/27/15 10:09 PM
12/27/15 10:09 PM
dartman366
Mt. Vernon, Ohio
AR3910, ok. any street driving on that? no, track only, 13. to 1 comp and sunoco supreme fuel, 112 octane, ran them for years with no failure's, even with extended idle time they never hiccuped.
[Re: mopar dave]
#1977670
12/28/15 02:07 AM
12/28/15 02:07 AM
Cab_Burge
ever have any luck with the champion cx series with the cut back strap? I've never seen a set of them, let alone bought a set to use ![work work](/ubbthreads/images/graemlins/custom/work.gif) I'm usually looking for the best bang for the buck, not the latest, greatess, trick race part of the year ![work work](/ubbthreads/images/graemlins/custom/work.gif) AKA I've never thought about trying them, I have used some of the C57YC and maybe a set of the C61YC, if that is a good Champion part number ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I drove my low compression pump gas Duster on the street with both the AR3911 and AR3910 with no fouling or missing problems running Oregon 91 octane pump swill ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I ended up trying and using Champion RC12Yc and RC9YC alos, both worked okay, the RC12YC seemed a little hotter than I liked so I ended up using the RC9YC due to the lower cost at the local parts stores on special compared to the AR3910 or 3911s ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
