Page 2 of 4 1 2 3 4
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977274
12/27/15 04:57 PM
12/27/15 04:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What transmission is in your very first pic, cause I am not seeing that one in your later pics.
Never mind, I see it now, the angle was funky or something.
Don't be the exception.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977276
12/27/15 04:58 PM
12/27/15 04:58 PM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
I'll take pics of the bell when I get home...
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Supercuda] #1977279
12/27/15 05:00 PM
12/27/15 05:00 PM
Central Valley, CA.
Central Valley, CA.
Same exact trans...might just be the angle of the PIC?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: MoPar] #1977285
12/27/15 05:08 PM
12/27/15 05:08 PM
Central Valley, CA.
Central Valley, CA.
MoPar....will do as soon as I get home in 1/2 hour. I mispoke in my original post... It's the passenger side bottom hole that appears to be off.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: MoPar] #1977313
12/27/15 05:58 PM
12/27/15 05:58 PM
Central Valley, CA.
Central Valley, CA.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977314
12/27/15 06:00 PM
12/27/15 06:00 PM
Central Valley, CA.
Central Valley, CA.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977457
12/27/15 09:35 PM
12/27/15 09:35 PM
MoPar Offline
MoPar  Offline
That is not a o.d. bellhousing for a 833 o.d. trans, I don't know what it is, maybe a late model bell ??
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: MoPar] #1977464
12/27/15 09:43 PM
12/27/15 09:43 PM
Central Valley, CA.
Central Valley, CA.
It actually is...just not a commonly used one as its late model and hydraulic clutch. Here's the info:
4471829 1 D 10-3/8", 11" Clutch, A535, A435, A833 Transmission, Except Diesel Engine 1990-91
Also...my BB 833 bell bolt holes match this one but with a smaller Center hole.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977509
12/27/15 10:25 PM
12/27/15 10:25 PM
MoPar Offline
MoPar  Offline
Take the input shaft bearing retainer off the trans and mate the trans to your big block bell,I bet bolt pattern will match your big block bellhousing.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977594
12/27/15 11:45 PM
12/27/15 11:45 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I also had to look at the first pic several times to figure out the angle and what I was seeing. I would also pull the bearing retainer to see if it fits the early bell. My only guess might be that the case was slightly re-engineered with that hole slightly off.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977603
12/27/15 11:50 PM
12/27/15 11:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I wish...lol...no this a plain 833 OD my boys are putting in a 64 dodge Sweptline pickup they are building. I just found another old post where someone found something similar and just slotted the hole in the trans....
Ok, I don't know anything about manual transmissions, I didn't realize there was an overdriven 4 speed from the factory, I thought Passon made one for that reason. Very cool, hope it works out for ya.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977650
12/28/15 12:43 AM
12/28/15 12:43 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pretty sure the A833 was out of production before 90
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: ProSport] #1977694
12/28/15 01:51 AM
12/28/15 01:51 AM
Central Valley, CA.
Central Valley, CA.
I wasn't making fun...Passion does make a 18 spline much stronger version with better ratios. The one I have is very weak by comparison.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Supercuda] #1977696
12/28/15 01:54 AM
12/28/15 01:54 AM
Central Valley, CA.
Central Valley, CA.
I know the 833 of was made into the late 80's....not sure about after that. This trans appears to have 3 different trans bolt patterns.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977704
12/28/15 02:00 AM
12/28/15 02:00 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I dunno about that: I know a guy that ran an 833od for years behind a 511 6 pak in a '69 Charger for years and never broke it. He never lost a race either......... twocents
FWIW the hydraulic 833od I just picked up has the slave on the Driver side, just like the linkage set-up OD's. Yours appears to be on the Passenger side?
Mo' Farts
Moderated by "tbagger".
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1977706
12/28/15 02:06 AM
12/28/15 02:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have one that's got an 87 date code, FWIW.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Grizzly] #1977716
12/28/15 02:45 AM
12/28/15 02:45 AM
Central Valley, CA.
Central Valley, CA.
Yep..mines passenger side. I read there is a similar bell that is s drivers side that maybe came in some of the V6 trucks?
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Supercuda] #1977719
12/28/15 02:48 AM
12/28/15 02:48 AM
Central Valley, CA.
Central Valley, CA.
I think mines an 83 date code.
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978568
12/29/15 01:24 PM
12/29/15 01:24 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics....
I can't see the picture here at work.
Is this the bell housing I sold you ? It had an alum 833 bolted to it when I found it at the junkyard ????
Mainstream Media is the new Pravda
Re: 833 O.D. bolt pattern...one bolt slightly off? [Re: Quicksilver440] #1978627
12/29/15 02:44 PM
12/29/15 02:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I still say from the pic it looks like the ear was broken off welded and dressed down.Look all around the ear that pics looks like it was broken and fixed.Rocky
Chrysler Firepower
Page 2 of 4 1 2 3 4
