Late B-Body Shock Question
#1976029
12/25/15 10:19 AM
12/25/15 10:19 AM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
Okay so not long ago I purchased a 79 Chrysler Cordoba with a 360/A999 transmission and 8.25 rear. The car has a rebuilt front suspension minus shocks. It also has the poly bushings in the front and the rear has new leaf springs/bushings as well. Now, the question I have is the car has older looks like Monroes on the front and the older KYB GR2 shocks on the back. This car is mainly a driver/cruiser but, when I take corner it seems to have more lean than I like.
My options for replacing the shocks are Bilsteins which cost almost a quarter for what I paid for the car or should I just get some KYB GR2s for the front and the KYB performance shocks for the rear or should just suck it up and buy the Bilsteins? This car will be mainly a cruiser but, I figure I would ask since I think the prior owner mentioned something about shocks and our roads can be rough around here. Thank you in advance.
Re: Late B-Body Shock Question
[Re: OrangeProwler]
#1976264
12/25/15 06:20 PM
12/25/15 06:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Shocks don't really do much for body lean, not their job.
With the tires you're running, you will be limited in performance anyway so I wouldn't suggest Bilsteins.
Firmfeel sells bigger torsion bars and front/rear sway bars. But nothing is cheap, you could easily exceed the purchase price of the Doba with just new T bars, sway bars and Bilsteins. But with those the handling is done (except for better tires).
[Re: Supercuda]
#1976272
12/25/15 06:34 PM
12/25/15 06:34 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Firmfeel sells bigger torsion bars and front/rear sway bars. But nothing is cheap, you could easily exceed the purchase price of the Doba with just new T bars, sway bars and Bilsteins. But with those the handling is done (except for better tires). I'll disagree with the tire statement. I put Bilstein's on my Dart with 205/75/14 tires and I noticed a night and day difference. On the freeway, the car wasn't pitching as if I was sailing the seven seas. Although, I will agree that sway-bars and/or stiffer springs would better suite reducing sway. Again, if it's a car he plans on cruising around with for a long while, I say go for some mild upgrades. Who cares if you've got more money into it? Some minor upgrades will make the car so much more enjoyable.
[Re: OrangeProwler]
#1976275
12/25/15 06:42 PM
12/25/15 06:42 PM
Supercuda
About to go away
About to go away
up yours
Cooper Cobras
I can guarantee the smaller tires on my DD will out grip the larger Cooper Cobras he's got.
[Re: Supercuda]
#1976285
12/25/15 07:19 PM
12/25/15 07:19 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Cooper Cobras
I can guarantee the smaller tires on my DD will out grip the larger Cooper Cobras he's got. I overlooked the Cooper Crayolas. Yeah, those have no grip, but how does tire grip effect sway? Body lean is mostly attributed to low spring rates and lack of an anti-sway bar.
[Re: OrangeProwler]
#1976309
12/25/15 08:28 PM
12/25/15 08:28 PM
Supercuda
About to go away
About to go away
up yours
I was referring to the handling via suspension upgrades would be limited by the tires at that point, not so much body lean. Granted even the Coopers would handle better than not having the upgrades, but next set of tires need to be better.
[Re: OrangeProwler]
#1976341
12/25/15 10:16 PM
12/25/15 10:16 PM
Posts: 801 central CT
cudazappa
central CT
I highly doubt that there are performance shocks designed for the 73+ b/r body available. Last I recall you'll need shocks for a late 60s GM A body (Tom Quad did this on his St. Regis). Easiest way to upgrade the handling is to look for someone parting a 79 Chrysler 300 or Magnum GT and grabbing the torsion bars and sway bars from them. The rear away bar was available also on toe package cars. The other thing is to eliminate the iso-clamp system on the rear axle and replace the k frame and torsion bar crossmember bushings with Firm Feel's aluminum ones. That's a one and done upgrade, the poly bushings available are better than nothing and I would only recommend them if you don't plan on keeping the car. I built the 300 in the beginning of this video: http://youtu.be/LHj8QGpxCL4
1971 Challenger
[Re: OrangeProwler]
#1976451
12/26/15 03:16 AM
12/26/15 03:16 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
My options for replacing the shocks are Bilsteins which cost almost a quarter for what I paid for the car or should I just get some KYB GR2s for the front and the KYB performance shocks for the rear or should just suck it up and buy the Bilsteins? This car will be mainly a cruiser but, I figure I would ask since I think the prior owner mentioned something about shocks and our roads can be rough around here. Thank you in advance. How much money do you have to spend? Do you have enough for torsion bars and good shocks? If you need front shocks any way you may as well get some bilsteins from Firm Feel or PST and see if that helps enough.
A new iron curtain drawn across the 49th parallel
[Re: OrangeProwler]
#1976801
12/26/15 11:04 PM
12/26/15 11:04 PM
cudazappa
central CT
Budget minded upgrades: Start with the HD front sway bar and rear sway bar Step 2 grab the cop/300/big block torsion bars Step 3 good parts store shocks or better Step 4: 5 leaf rear springs
This will make a nice cruiser. My old 300 that now gets autocrossed has a very basic build. Biggest upgrade on that car is the 16x8 wheels and the tubular UCAs and boxed LCAs
1971 Challenger
[Re: OrangeProwler]
#1979231
12/30/15 11:52 AM
12/30/15 11:52 AM
Posts: 163 Speedway In.
IndyDave
Speedway In.
When we were running Cordobas and Magnums as hobby stockers, we ran Afco front shocks for a GM A-body like was mentioned before.
If you go the route of used T and sway bars, look at the first 4 digits of the VIN. Any Doba or Charger / Magnum with the 3rd and 4th digits of 22 came with the larger front sway bar and a rear sway bar. The "440/ Police T-bars can be found under '79 300's but also Magnum GTs. My advice on T-bars is to bite the bullet and buy a set from Firm Feel.
The other thing you will need to do is replace the K-frame bushings with urethane or if you can score a set of the long discontinued 4419942 solid cast iron bushings. This is VERY important if you are going to get froggy in the twisties with one of these cars. With the stock bushings the k-frame moves enough under the car in hard cornering that is will bind the steering, especially if the bushings are worn at all. The 4419942 bushings were created initially for late B police cars as the steering binding was becoming a real issue.
On the rear, use a set of MP XHD B-body leafs and shock plates from a 71- 72 B body with a rear sway bar. The iso clamp system for the rear springs and the huge front eye bushing allow the rear end to move around quite a bit also.
Dave Dusterberg 1979 Aspen R/T (soon to be #19 CAM/T) 2002 Ram 1500 SLT 2005 Magnum R/T 2005 Mustang GT SCCA CAM/C #19
[Re: OrangeProwler]
#1979464
12/30/15 05:50 PM
12/30/15 05:50 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Thank you everyone. The leaf springs I think are already 5 spring units from what I remember. ... I can't consider 5 leafs good for handling performance. I would definitly add another leaf per side to start with. A regular '60s C-body car already had 6 to 7 blades usually. I'running 7 blades per side on my '73 A-body, but I'm hauling 2 propane tanks in the trunk too.
[Re: OrangeProwler]
#1981759
01/02/16 02:36 AM
01/02/16 02:36 AM
OrangeProwler
Middle of A Field
I figure those leaf springs are still better than probably what was originally on the car. I'm looking for a little more ability but, as I said I won't be doing any road courses with the car. I'll probably just do just the bigger torsion bars, and bigger sway bars (add one on the rear) along with some decent shocks and call it day. All the bushings have been upgraded. I don't want to get it too firm. But, I figure it wouldn't hurt to ask here anyways. I'm thinking of saving the handling mods for our Charger.
[Re: MuuMuu101]
#1997667
01/24/16 02:12 PM
01/24/16 02:12 PM
Posts: 2,592 None
71rm23
None
If it's a car you plan on enjoying for a long while, I'd say get the Bilstein's. Does it have sway bars as well? If not, maybe get a pair of those. X2 here
