Re: spark plug recommendation [Re: mopar dave] #1977866
12/28/15 02:12 PM
12/28/15 02:12 PM
AndyF Offline
AndyF  Offline
Originally Posted By mopar dave
ever have any luck with the champion cx series with the cut back strap?
Yes, the CX plugs are all I use on the dyno motors. Bulletproof plugs with the cut back strap. Extra piston clearance also. They are fairly cold plugs though, race only, not a street plug.
Re: spark plug recommendation [Re: mopar dave] #1977869
12/28/15 02:17 PM
12/28/15 02:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run NGK 9's in my 14.8-1 572. After a clean cut power run they look perfect. However driving around the pits they're way dark. Never seemed to bother it down track. Same plugs 300 passes. Made it's best passes ever this fall.
Doug
Re: spark plug recommendation [Re: AndyF] #1978026
12/28/15 06:45 PM
12/28/15 06:45 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
which heat range cx plug would you use in 13:1 gas engine?
Re: spark plug recommendation [Re: Thumperdart] #1978393
12/29/15 03:25 AM
12/29/15 03:25 AM
Mt Morris Michigan
Mt Morris Michigan
are the ngk r5671a-8 resistor type?
