Re: Brass or Aluminum Rad. Which is best?
[Re: Morty426]
#1977529
12/27/15 11:42 PM
12/27/15 11:42 PM
Posts: 15,451 Omaha Ne
TJP
Omaha Ne
[Re: Rhinodart]
#1977646
12/28/15 01:37 AM
12/28/15 01:37 AM
moparpollack
Lil Herman
Lil Herman
85086
Aluminum is better for making a nice Mopar engine compartment look like a Chevy's. Never saw one that looks as good as the OE equipment. Yep, I don't go watch Drag Week because everyone thinks they have to run a Chivvy cowl hood and aluminum radiator. I'm sorry I guess everyone should make their car the way you want it so you can say it was done right.
[Re: Got2Gnow]
#1977784
12/28/15 11:38 AM
12/28/15 11:38 AM
Posts: 2,046 ky.
kenworth_goose
ky.
My personal experience on the copper/brass vs. aluminum radiators. My 68 Dart GTS, hot 360. I fought a cooling issue for a short length of time. Had a later model A-body radiator, shroud, fan. etc. Everything but the shroud was new, all hoses, water pump, thermostat, radiator, belts, engine was fresh built, fan was new as well. It would consistently run 220 plus and sometimes higher. I actually replaced almost every part on this thing with zero improvement. I tried different fans, water pumps, t-stats, hoses, even another new radiator. Never a single change. Even added a new electric fan added to the front of the radiators. Everything ran the same. Finally, after reading how aluminum dissipates heat faster and more efficient than copper/brass I bought a new one. I even bought one of those cheap units from Ebag. I had to fab up some brackets to mount it. And this was without any kind of fan shroud. I put it in, filled full of collant and I barely ran over 160 again. It could be 90*+ outside and the highest I ever saw it was 170*. I've had the very same experience with my 79 Dodge dually. Had a NEW copper/brass, couldn't keep it cool in the summer with the a/c on. All I did was buy a new aluminum radiator and all cooling issues were gone. This is my personal experience. I will always disagree that a copper/brass is better for cooling.
[Re: kenworth_goose]
#1977879
12/28/15 02:27 PM
12/28/15 02:27 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I worked in a old timey radiator shop in my youth. Your original A-body radiator probably needed riding out as the tubes plug up over time. You wouldn't believe how many old tubes were probably plugged solid... So its likely a new brass radiator would have fixed your cooling problem as well....unless you are saying the radiator was new too? Were they the same capacity/configuration radiator?
[Re: Quicksilver440]
#1977946
12/28/15 04:34 PM
12/28/15 04:34 PM
Posts: 2,046 ky.
kenworth_goose
ky.
I worked in a old timey radiator shop in my youth. Your original A-body radiator probably needed riding out as the tubes plug up over time. You wouldn't believe how many old tubes were probably plugged solid... So its likely a new brass radiator would have fixed your cooling problem as well....unless you are saying the radiator was new too? Were they the same capacity/configuration radiator? Yes, 2 new copper/brass radiators, neither would cool. Aluminum took care of it right away!
#1977968
12/28/15 04:54 PM
12/28/15 04:54 PM
RapidRobert
Yes, 2 new copper/brass radiators, neither would cool. Aluminum took care of it right away! The plot thickens
[Re: RapidRobert]
#1977981
12/28/15 05:33 PM
12/28/15 05:33 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I had a Ramcharger in the past... Older truck, 360 also... OEM cooling config worked fine... Something else in the mix... What would the fix be in the past??? Pre-aluminum rad availability... Been in bumper to bumper, 95+ heat, multiple occasions... Sometimes for hours at a time... OEM 'air' system... 20 years of running time... 26" rad, A/C water pump, viscous, 7-blade fan, shroud... NEVER have seen the temp beyond 180...
[Re: justinp61]
#1978022
12/28/15 06:39 PM
12/28/15 06:39 PM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
G Tale of two cars, father-sons. Sons, 528 all aluminum Hemi with big aluminum radiator, runs over 2 hundred or more, all the time, with two fans and custom made shroud. Fathers, 472 Hemi steel block aluminum heads stock radiator no shroud, like it came off the line, runs 160 all day, any temp outside. 63&65 Dodges. I told him to get rid of the rad. and electric pump, won't listen, steady throwing money at it?? [quote=justinp61]Tale of two different cars, apples to oranges.
To the orginial poster, you don't need a high dollar radiator to cool your car. A parts store replacement will work fine. [/quote
Apples to oranges? Only difference is the block, same crank, just bigger bore in the 528, same flat tapet cam. So both cars have electric water pumps? No, hot one has a Merzzery or however you spell it. I'm saying that's the problem, do you agree?
[Re: cudaman1969]
#1978034
12/28/15 06:52 PM
12/28/15 06:52 PM
Quicksilver440
Central Valley, CA.
Apples to oranges? Only difference is the block, same crank, just bigger bore in the 528, same flat tapet cam. So both cars have electric water pumps? No, hot one has a Merzzery or however you spell it. I'm saying that's the problem, do you agree? I agree...I ran my 500+HP Street Car on long road trips over mountains even in summer with a stock water pump and electric fan with zero issues (180-190 degrees +/-). I changed to a 55 GPM water pump and now the cars temp creeps up to 220 +/- even driving around town in dead of summer. I'm going back to the stock water pump...
[Re: cudaman1969]
#1978038
12/28/15 07:06 PM
12/28/15 07:06 PM
TJP
Omaha Ne
There are way too many variables involved to answer the question here with anything other than ones opinion, PERIOD!!! It is not just the material, a few of the other variables are, Fin Count, number of rows, are they staggered or not, are the fins louvered, thickness of the fins, how many fins per inch, how are the fins attached to the tubes, diameter of tubes, thickness of the tube walls, spacing between the tubes and on it goes.
[Re: TJP]
#1979971
12/31/15 04:31 AM
12/31/15 04:31 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
There are way too many variables involved to answer the question here with anything other than ones opinion, PERIOD!!! It is not just the material, a few of the other variables are, Fin Count, number of rows, are they staggered or not, are the fins louvered, thickness of the fins, how many fins per inch, how are the fins attached to the tubes, diameter of tubes, thickness of the tube walls, spacing between the tubes and on it goes. I think to many people on here arguing about this subject think that a brass and copper radaitor has brass as part of the liquid cooling system, which it does not. The tubes and tanks are copper and the brass is the thin strips wedged between the tubes to suck heat out of the copper tubes into the air If aluminum radaitors weren't cheaper than copper radaitors are now do you think the car companys would use the aluminum in spite of the costs The aluminum radaitors are cheaper, not better
[Re: Got2Gnow]
#1980168
12/31/15 03:07 PM
12/31/15 03:07 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
To the OP:
Whatever radiator you choose to run, make sure to do a thorough flush out job of your cooling system before installing the new unit. I would even go so far as to advise flushing out the block by removing the drain-cock or a freeze plug and spraying your garden hose in it for a few minutes until the water runs out clean.
Get all the nasty stuff out that will plug up your new unit.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: 19swinger70]
#1980172
12/31/15 03:11 PM
12/31/15 03:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
good point there. I usually end up putting radiator petcocks in place of the block drain plugs to easy future draining. You'll probably find the hole plugged with stuff and will need to poke it loose once you get he block drain plugs pulled.
[Re: Got2Gnow]
#1980188
12/31/15 03:30 PM
12/31/15 03:30 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I have used these for 30 or more years for a very fast and quite good reverse flush. Certainly beats crawling under the car to open jammed up block and radiator petcocks,,or worse yet removing bolt in plugs from the block. You need not have it installed permanently if for cosmetic purposes,,,just tap unit in before flushing and remove when done. Also flushes out heater which simple draining does not. I also leave engine idling while flushing. Flush until coolant runs clear out of top of radiator. Always keep water flowing from hose while engine running as otherwise you can damage water pump from lack of lubrication that coolant provides. Some 15 minutes for whole job. Your cooling system will love you, therefore it will treat you well. http://www.amazon.com/Prestone-AF-KIT-Flush-Fill-Kit/dp/B000CCFY5W
[Re: Got2Gnow]
#1980202
12/31/15 03:36 PM
12/31/15 03:36 PM
Supercuda
About to go away
About to go away
up yours
You don't put drains in the block for flushing, you put them in there to DRAIN the block. You know, get all the coolant/water out of the block. So you don't drool coolant all over the place when you pull a head or something similar. Pretty sure the Prestone flushing kit doesn't get the sediment at the bottom of the water jackets out either. Since I've seen it come out my drains after a flush, draining all the water out for a proper refill.
[Re: Got2Gnow]
#1980408
12/31/15 06:11 PM
12/31/15 06:11 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Aluminum conducts heat twice as fast but needs to be twice as thick so it is a wash. The real issue for functionality between the two is the vast difference in mechanical desighn NOT the material. The OEMs do it in AL because it is cheaper, they also use those stupid plastic tanks on the end because they are cheaper but usually around 5-10 years old they start leaking and need replaced, especially with dex-cool type crap coolant. Many brass radiators (includeing brass tanks) are still in service 50+ years later .
