Re: mechanical engineers please help!
[Re: maximum entropy]
#197658
01/19/09 04:00 PM
01/19/09 04:00 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
The forces at work are significant and strong enough to crush something as seemingly stout as the spring perches. Some of the guys on here where talking about it on another thread. Now I'm going to have to take mine back apart and re-enforce them...
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: BADDART]
#197659
01/19/09 04:09 PM
01/19/09 04:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If your springs are strong enough to keep from defecting and you have good shocks you probably wouldnt see any difference. But with a 4-link the farther you go from the axle centerline to the rear heim joints the easier it is to pull the front wheels(greater leverage) even with the IC at the same distance and height ![](/ubbthreads/images/graemlins/wave.gif)
[Re: BADDART]
#197663
01/19/09 11:59 PM
01/19/09 11:59 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Ok non-engineers get a pass, but you engineers need to study a little more! Many people got this right, but nobody got it for the right reason.
First of all... Lets talk basics.
Torque= Force x Distance
So if you have 500 ft-lbs of torque. That is equal to
500lbs x 1 ft
OR
1 lb x 500ft
You can easily see that with a given input torque (from the axle) the force to counteract that force gets LOWER as the length gets longer.
Practical example: You have a tight lugnut you need to get off. It is applying a torque to stay tight. You have to counter act this torque with a wrench and a force. We all know as the wrench gets longer, the force gets smaller.
Torque=Force x Distance.
Ok now for the specific example, Maximum E. almost got it right in the begining, he was on the right track.
You can see from my example above that the longer distance would have less force on the spring (less wheel hop). So many of you are thinking, then why when I add 2" of lowering blocks does the wheel hop get worse (Just as mentioned by the old guy above who probably hasn't read this far because he only cares what he knows, not why it works)
What you need to think about though is the distance from the application of the torque center, to the point the force is being applied. In this case, the critical area for high force is near the front eye of the spring. That's because the spring is at it's weakest point with only one leaf section there.
So if you think about the geometry, the spring is in an arc. As you space the axle upwards, the axle center actually gets closer to that front eye of the spring! Think about if you were to measure from the eye of the spring straight rearward, it's a shorter distance then if you measure on the angle downward. This means as you space the axle upwards, the distance gets shorter.
Torque=force x distance.
The torque is the same no matter where you put the axle. So if you space it upwards and the distance is shorter, the Force is actually increased.
So yes, the forces on the spring get worse with the lowering blocks, but it's not because the distance get's longer, it's because it gets shorter.
Hope that's not too confusing, if anyone wants a picture (Free Body Diagram) just ask and I'll draw one up and post it...
[Re: dizuster]
#197664
01/20/09 12:40 AM
01/20/09 12:40 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
500lbs x 1 ft
OR
1 lb x 500ft
Everything above as Stated is Correct IMO![](/ubbthreads/images/graemlins/thumbs.gif)
Everything below as stated is mostly incorrect.IMO ![](/ubbthreads/images/graemlins/biggrin.gif)
I will give my arguements on this tommorow And its all good, I look forward to sparring with you dizuster, you know your stuff. mike ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dizuster]
#197665
01/20/09 01:44 AM
01/20/09 01:44 AM
Posts: 1,278 Mission BC
10sec440
Mission BC
500lbs x 1 ft
OR
1 lb x 500ft
I'm no engineer but I have enough experience in auto repair that I think I can comment...I don't agree with this: "So yes, the forces on the spring get worse with the lowering blocks, but it's not because the distance get's longer, it's because it gets shorter."
I agree that the distance between the axle center and the spring eye get shorter, but it's the force that the axle perch exerts on the center of the spring that causes the windup,not the spring against the eye. Spacing that perch farther from the spring will make it more prone to rotate IMO. Can a car be built with a 2"lowering blocks and be strong enough that it will hold together and run 8's? Sounds like it.Is it optimal? I don't think so. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 10sec440]
#197666
01/20/09 03:08 AM
01/20/09 03:08 AM
Remember TWO forces are happening here. One is rotational force from the diff housing to the springs. The other is the diff housing pushing the car (via the spring) forward...... in a linear motion. As I see it one force will counter act the other to some degree.How much one force will counter the other I am not sure.The stiffness of the spring, weight of the car and traction may have some effect. This may explain the differing experiences stated here. I would imagine a longer lowering block would lessen the rotational force on the spring pad at least.Particularly when the diff housing would be more likely to 'run over' the spring mount! Some times it is just easier to try it and see what happens. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: bwdst6]
#197669
01/20/09 07:31 PM
01/20/09 07:31 PM
dizuster
Oakland, MI
And there's no need for a free body diagram, it's a Mechanical Vibrations problem, not a Statics problem where everything is assumed to be rigid.
True but the load path applied is still calculated in a similar fashion. If you can come up with a simply explained vibrations solution on a forum like this feel free...
