Re: Need advice, what parts to use for an A body open track car
[Re: NV69B7RR]
#1970924
12/16/15 05:20 PM
12/16/15 05:20 PM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
It looks like they mount in a similar fashion at the axle, however the action arm on the Hellwig units looks substantially longer in pics. Do you have a bar you could measure? Distance at all 3 mounting holes would be good. I could do the same when I get home. All the A bodies are at the house right now.
[Re: NV69B7RR]
#1970975
12/16/15 06:50 PM
12/16/15 06:50 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I got 12" from center to center of forward most hole and 10" rear most hole so the middle hole must be at 11". My bar is Hellwig #6908 and the A-body model is #6807.
Mopar to the bone!!!
[Re: 68rrunner]
#1971352
12/17/15 10:58 AM
12/17/15 10:58 AM
Posts: 22,728 Bitopia
jcc
Bitopia
What is the rate compared to the 3/4 bar? Thicker doesn't mean stiffer. ??????, are we talking rates, or material properties?
[Re: NV69B7RR]
#1971521
12/17/15 04:58 PM
12/17/15 04:58 PM
Posts: 43 Santa Fe Springs, CA
Jon @ Hotchkis
For simple reference, our A-body sway bar is stiffer than the B-body bar.
A-body rates: - 230 lbs/in - 265 lbs/in - 310 lbs/in
B-Body: - 150 lbs/in - 180 lbs/in - 220 lbs/in
Also, material choice does not affect the rate of the bar; a chromoly bar will have the same rate as a mild steel bar. Different materials are used for their bending properties for when the bars are shaped on the bender.
Hotchkis Performance 8633 Sorensen Ave. Santa Fe Springs, CA 90670 Phone: 562-907-7757 x224 Fax: 562-907-7765
Hotchkis Performance East 9075 Highway 152 Mooresville, NC 28115 704-660-3060
[Re: NV69B7RR]
#1971570
12/17/15 06:34 PM
12/17/15 06:34 PM
72Swinger
Nebraska
Does not matter what the Hotchkis bar does in my case because it wouldn't work with my inboard springs, where the Hellwig does.
[Re: NV69B7RR]
#1975697
12/24/15 03:21 PM
12/24/15 03:21 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
Rick I think those are the rear sways in each of the three adjustment holes. Jon do you have rates for the two different front Hotchkis A Bars?
[Re: norcal-fjo]
#1978937
12/29/15 10:43 PM
12/29/15 10:43 PM
Jon @ Hotchkis
Tommy is right, those rate I posted were for the rear.
Fronts are a bit of an apple to oranges comparison really since they mount and attach differently:
67-72: 700lbs/in. '73+: 375lbs/in.
Unfortunately I do not have the motion ratios for the lower arms in front of me to calculate the wheel rates.
[Re: 68rrunner]
#1979624
12/30/15 09:01 PM
12/30/15 09:01 PM
Jon @ Hotchkis
When Aaron and I talked about this, then different mounting locations equalized the rate; however, the earlier bar allowed more control because of the longer action. That sounds about right from the arm lengths and attachment points.
