Rear shock question
#1974897
12/23/15 12:51 AM
12/23/15 12:51 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
How much shock travel do you want to have on a leaf spring car?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Rear shock question
[Re: sixpackgut]
#1974906
12/23/15 01:07 AM
12/23/15 01:07 AM
Posts: 6,150 Melbourne , Australia
LA360
I would say that around 5" will typically work on most cars. I installed a pair of 7" travel AFCO's on a friends car, but that was more to get the tires off without have to unbolt too much
Alan Jones
[Re: SpareParts]
#1974991
12/23/15 03:19 AM
12/23/15 03:19 AM
sixpackgut
Charleston
I have afco 3890's on back. They long Theyre 25" long! I have no idea how you can have a shock that long on your car
[Re: sixpackgut]
#1974999
12/23/15 03:32 AM
12/23/15 03:32 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
If your springs are moved inboard, it makes longer shocks even stock length shocks to long.
Mopar to the bone!!!
[Re: sixpackgut]
#1975110
12/23/15 01:37 PM
12/23/15 01:37 PM
Thumperdart
State of confusion
I`m runnin Rancho 5-ways and don`t have the lengths handy but iirc there`s 6" of travel w/2" of that being compression and the rest extension. The key is enuff comp. on the street to not bottom out and enuff ext. to not unload the tires.......
[Re: Thumperdart]
#1975160
12/23/15 03:10 PM
12/23/15 03:10 PM
sixpackgut
Charleston
I`m runnin Rancho 5-ways and don`t have the lengths handy but iirc there`s 6" of travel w/2" of that being compression and the rest extension. The key is enuff comp. on the street to not bottom out and enuff ext. to not unload the tires....... that is exactly what I was thinking also but I was having a lot of rear separation looking at photos of my car at drag week now that I have leaf springs on it. Thinking if I had a stiffer shock than I wouldn't need that much either.
[Re: sixpackgut]
#1975164
12/23/15 03:14 PM
12/23/15 03:14 PM
Thumperdart
State of confusion
Yep, tighter extension............
[Re: sixpackgut]
#1975261
12/23/15 05:46 PM
12/23/15 05:46 PM
Posts: 861 lancaster,california
johnnycuda
We suggest 1.5'-2" of downward travel from ride height, and 4" of extension on a street driven car if possible, on a drag only car 1" minimum of the shock shaft showing at ride height, max of 2". The stock rear shock length on A-bodies is 14.23" collapsed and 22.15" extended, ride height generally around 16" to 17", assmuning its not lowered or raised considerably.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Monte_Smith]
#1975288
12/23/15 06:47 PM
12/23/15 06:47 PM
Thumperdart
State of confusion
If you want less separation, you need more spring rate. The shock only controls the housing and is not a travel limiter, unless you let it bottom or top out. On my slow ass junk, tightening the shocks slowed the extension and makes it ride like a truck............
[Re: sixpackgut]
#1975307
12/23/15 07:20 PM
12/23/15 07:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How much shock travel do you want to have on a leaf spring car? Ray.. I'm sure the 9 way rancho shocks would work for ya.. same length as you have now(at least I think they are) and it has more control on the extension.. save your self 2" of compression for the street... if you bottom out you hit a damn good pot hole(a normal Mich road).. just slow the extension more on your launch.. might be at 9.. but I would think a 8
[Re: Monte_Smith]
#1975381
12/23/15 09:29 PM
12/23/15 09:29 PM
sixpackgut
Charleston
Part of my problem was hap hazardly ordering a leaf spring and caltracs 2 weeks before Drag Week not knowing how my car would sit. I have 3 spring eye holes and i used the higher one to get it to sit right.
In my living room right now are negative 1 inch mono rears to get the front eye lower and ride hight correct. Also just ordered shocks that are 10 compressed 15 extended double adjustables. Also changing my 350 springs i just put on the front to 300s. Also have a new rack and pinion for my car because mine is shot.
I am taking off Strange SA shocks off the rear. Also plan on replacing my wilwood street vented rotor brakes for wilwood drag setup. Will lose 8 lbs changing the front brakes
[Re: sixpackgut]
#1975567
12/24/15 10:28 AM
12/24/15 10:28 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
I have afco 3890's on back. They long Theyre 25" long! I have no idea how you can have a shock that long on your car Lol she's there, it's the one they make for a Mopar rear. I am doing different mounts for it, I wanted the extension to never be a problem.
[Re: sixpackgut]
#1975660
12/24/15 02:23 PM
12/24/15 02:23 PM
Thumperdart
State of confusion
I am taking off Strange SA shocks off the rear. Also plan on replacing my wilwood street vented rotor brakes for wilwood drag setup. Will lose 8 lbs changing the front brakes Go get em cowboy................
[Re: Monte_Smith]
#1975677
12/24/15 02:53 PM
12/24/15 02:53 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Tightening the shock is supposed to slow the extension and limit the speed of rise, but not control amount of rise, that is strictly spring rate.
Tightening a single, adjusts both bump and extension, so yes, will make it ride stiff Doesn't the front eye location control rise? Doug
[Re: dvw]
#1975721
12/24/15 04:08 PM
12/24/15 04:08 PM
sixpackgut
Charleston
Tightening a single, adjusts both bump and extension, so yes, will make it ride stiff Doesn't the front eye location control rise? Doug Yes, that is why I got the right springs for the car now.
[Re: sixpackgut]
#1975808
12/24/15 07:27 PM
12/24/15 07:27 PM
sixpackgut
Charleston
Fyi, i just swapped my leafs and weighed everthing.
My switch from ladder bars to leafs and caltracs added 52lbs to my car
[Re: sixpackgut]
#1975852
12/24/15 09:07 PM
12/24/15 09:07 PM
Thumperdart
State of confusion
My switch from ladder bars to leafs and caltracs added 52lbs to my car Curious but why did you switch?
[Re: sixpackgut]
#1975859
12/24/15 09:28 PM
12/24/15 09:28 PM
sixpackgut
Charleston
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive
[Re: sixpackgut]
#1975981
12/25/15 02:46 AM
12/25/15 02:46 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive Isn't your class running just as fast as modified? Was looking at the difference between ss sb/pa and modified and I think the ss class was faster.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1976016
12/25/15 05:19 AM
12/25/15 05:19 AM
sixpackgut
Charleston
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive Isn't your class running just as fast as modified? Was looking at the difference between ss sb/pa and modified and I think the ss class was faster. Jay Brown ran in the 8s in mod this year with a ford cammer
[Re: sixpackgut]
#1976893
12/27/15 01:33 AM
12/27/15 01:33 AM
Posts: 10,049 MN
JERICOGTX
MN
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive Isn't your class running just as fast as modified? Was looking at the difference between ss sb/pa and modified and I think the ss class was faster. Jay Brown ran in the 8s in mod this year with a ford cammer And the guy with the Green Nova was running 9.0's until it broke at Union Grove. Jays car could be faster with some actual track time.
69 GTX
68 Road Runner
[Re: dvw]
#1976901
12/27/15 01:45 AM
12/27/15 01:45 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Tightening a single, adjusts both bump and extension, so yes, will make it ride stiff Doesn't the front eye location control rise? Doug Two springs, one soft, one stiff, both mounted in the same spot, will have different amounts of rise. That's about spring rate.........same as SS springs were
[Re: Monte_Smith]
#1976905
12/27/15 01:54 AM
12/27/15 01:54 AM
MR_P_BODY
Tightening a single, adjusts both bump and extension, so yes, will make it ride stiff Doesn't the front eye location control rise? Doug Two springs, one soft, one stiff, both mounted in the same spot, will have different amounts of rise. That's about spring rate.........same as SS springs were But we take the SAME springs as in SS springs... the lower front eye location will give a softer hit and if all things the same a lower rise to the body.. it would have more PUSH forward
[Re: sixpackgut]
#1976921
12/27/15 02:19 AM
12/27/15 02:19 AM
Monte_Smith
North Alabama
I`m runnin Rancho 5-ways and don`t have the lengths handy but iirc there`s 6" of travel w/2" of that being compression and the rest extension. The key is enuff comp. on the street to not bottom out and enuff ext. to not unload the tires....... that is exactly what I was thinking also but I was having a lot of rear separation looking at photos of my car at drag week now that I have leaf springs on it. Thinking if I had a stiffer shock than I wouldn't need that much either. I know all the things to do to suspension, to change rise...........my comment was directed at THIS post from Ray. To point out that shocks will NOT effect his rise or separation AMOUNT, only the rate of that action.
[Re: sixpackgut]
#1976970
12/27/15 03:44 AM
12/27/15 03:44 AM
sixpackgut
Charleston
I understand what my car is doing and why its doing it. What I wanted to know is how much travel do I need in a set of rear shocks. It turns out that I will only get around 4.6" of travel but I would have prefered more
