Re: Rear shock question
[Re: sixpackgut]
#1975852
12/24/15 09:07 PM
12/24/15 09:07 PM
Thumperdart
State of confusion
Fyi, i just swapped my leafs and weighed everthing.
My switch from ladder bars to leafs and caltracs added 52lbs to my car Curious but why did you switch?
[Re: sixpackgut]
#1975859
12/24/15 09:28 PM
12/24/15 09:28 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1975981
12/25/15 02:46 AM
12/25/15 02:46 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive Isn't your class running just as fast as modified? Was looking at the difference between ss sb/pa and modified and I think the ss class was faster.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1976016
12/25/15 05:19 AM
12/25/15 05:19 AM
sixpackgut
Charleston
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive Isn't your class running just as fast as modified? Was looking at the difference between ss sb/pa and modified and I think the ss class was faster. Jay Brown ran in the 8s in mod this year with a ford cammer
[Re: sixpackgut]
#1976893
12/27/15 01:33 AM
12/27/15 01:33 AM
Posts: 10,049 MN
JERICOGTX
MN
Because the modified class doesnt have a minumum weight now and any size engine. I just wanted to be somewhat competitive Isn't your class running just as fast as modified? Was looking at the difference between ss sb/pa and modified and I think the ss class was faster. Jay Brown ran in the 8s in mod this year with a ford cammer And the guy with the Green Nova was running 9.0's until it broke at Union Grove. Jays car could be faster with some actual track time.
69 GTX
68 Road Runner
[Re: dvw]
#1976901
12/27/15 01:45 AM
12/27/15 01:45 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Tightening the shock is supposed to slow the extension and limit the speed of rise, but not control amount of rise, that is strictly spring rate.
Tightening a single, adjusts both bump and extension, so yes, will make it ride stiff Doesn't the front eye location control rise? Doug Two springs, one soft, one stiff, both mounted in the same spot, will have different amounts of rise. That's about spring rate.........same as SS springs were
[Re: Monte_Smith]
#1976905
12/27/15 01:54 AM
12/27/15 01:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Tightening a single, adjusts both bump and extension, so yes, will make it ride stiff Doesn't the front eye location control rise? Doug Two springs, one soft, one stiff, both mounted in the same spot, will have different amounts of rise. That's about spring rate.........same as SS springs were But we take the SAME springs as in SS springs... the lower front eye location will give a softer hit and if all things the same a lower rise to the body.. it would have more PUSH forward
[Re: sixpackgut]
#1976921
12/27/15 02:19 AM
12/27/15 02:19 AM
Monte_Smith
North Alabama
I`m runnin Rancho 5-ways and don`t have the lengths handy but iirc there`s 6" of travel w/2" of that being compression and the rest extension. The key is enuff comp. on the street to not bottom out and enuff ext. to not unload the tires....... that is exactly what I was thinking also but I was having a lot of rear separation looking at photos of my car at drag week now that I have leaf springs on it. Thinking if I had a stiffer shock than I wouldn't need that much either. I know all the things to do to suspension, to change rise...........my comment was directed at THIS post from Ray. To point out that shocks will NOT effect his rise or separation AMOUNT, only the rate of that action.
[Re: sixpackgut]
#1976970
12/27/15 03:44 AM
12/27/15 03:44 AM
sixpackgut
Charleston
I understand what my car is doing and why its doing it. What I wanted to know is how much travel do I need in a set of rear shocks. It turns out that I will only get around 4.6" of travel but I would have prefered more
