Re: Trick Flow heads
[Re: dartman366]
#1971620
12/17/15 07:55 PM
12/17/15 07:55 PM
Thumperdart
State of confusion
Greg(Superformance)suggested some flat alum. sheet like he did so I may go that route to get rid of the pan and keep oil out of the intake ports........
[Re: BradH]
#1973429
12/20/15 08:08 PM
12/20/15 08:08 PM
Thumperdart
State of confusion
I am curious if the Hughes 1-piece cover works OK, but recall enough complaints about the 2-piece design to rule that one out. After reading about the coating not allowing the silicone to seal, I may try the 2-piece since it seems easier to get ALL surfaces tight and sealed unlike a 1-piece deal but not sold on that yet.......
[Re: AndyF]
#1973431
12/20/15 08:12 PM
12/20/15 08:12 PM
Jerry Kathe
I was running an out of the box Victor 383 intake. Looks like there is some room for improvement with port alignment. All of the ports look like this. The floor is lower and the roof height is the same with the TF head compared to conventional placement...really? It may be better to leave it as a built in reversion shelf
[Re: Jerry Kathe]
#1973458
12/20/15 08:51 PM
12/20/15 08:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Go with a thicker gasket and slot the bolt holes a little.. then port the top side if needed
[Re: AndyF]
#1973515
12/20/15 11:10 PM
12/20/15 11:10 PM
dartman366
Mt. Vernon, Ohio
I was running an out of the box Victor 383 intake. Looks like there is some room for improvement with port alignment. All of the ports look like this. How's that same gasket look on the head,
[Re: fast68plymouth]
#1973986
12/21/15 07:00 PM
12/21/15 07:00 PM
fast68plymouth
So. Burlington, Vt.
I took it that way, but was commenting that "usually"(well, never in my case) does that gasket properly line up with all 4 ports on the head. They aren't as far off as the ports are in the pic of the manifold though.
#1974013
12/21/15 07:37 PM
12/21/15 07:37 PM
Posts: 31,076 Oregon
AndyF
I'll post a picture of the gasket on the head. It looks to me like the head was ported to the gasket but I'll double check. It would make some sense for TF to port their heads to the FelPro gasket even if the FelPro gasket doesn't fit stock heads perfectly.
I don't have a good picture that shows all four ports but this picture shows one pair. The other pair look roughly the same.
#1974103
12/21/15 10:34 PM
12/21/15 10:34 PM
BradH
Off the top of my head, I can't think of a single time where I used those fel-pro paper gaskets and they properly lined up with all the ports on any heads. Generally, when you line up one pair of ports, the ones at the other end of the head are too far from the first pair. Yep, the Fel-Pros are spaced too wide, the Indy SR gaskets are spot-on, and the Indy MW gaskets are too narrow. For some odd reason, when Hughes CNC'd my "standard port" Victors, it looks like they spaced the ports approx. the same as Indy does their MW gaskets, so I have to cut "good" standard-port gaskets to fit that narrower port spacing. Hughes' own house-brand gaskets don't fit, either. You'd think something this basic wouldn't be a freakin' problem, given everything else that goes into designing a head or a CNC program. This type of inconsistency plays He11 w/ intake manifold port alignment, too.
[Re: AndyF]
#1974107
12/21/15 10:38 PM
12/21/15 10:38 PM
BradH
The scrub pattern from the RAS rocker arms looks really good for almost .700 lift. Then, IIRC, the Crane "gold" should work out pretty well, too, although their adjusting screw angle may be pretty far "out there" at .600"+ lift. Everything else I know of is probably going to sit too far to the exhaust side and require something like a B3RE "realignment kit" to pull the sweep pattern back in.
