Re: What front-end system system would you go with?
[Re: J_BODY]
#1973217
12/20/15 01:19 PM
12/20/15 01:19 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks for all the ideas, pictures, and suggestions guys. Lots of good ideas.
[Re: Tig]
#1973221
12/20/15 01:35 PM
12/20/15 01:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Apologies for the Hi-jacking, I've been looking at this too. What has always concerned me is how they match the rear suspension, for example, if you are using Caltracs, can you get the recommended rise / extension of 5 inches? (IIRC) If you were to change to a strut set up you would be close to loosing 300# on the front end.. with that much change in the front/rear ratio you wouldnt need that travel.. see what your front/rear weight percentage is now and then with a strut set up.. you might even need to lower the engine to help out ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: justinp61]
#1973239
12/20/15 02:17 PM
12/20/15 02:17 PM
dartman366
Mt. Vernon, Ohio
I really like this idea as with other projects it would keep costs down. What do you think of this system Doug as I could get rid of the tortion bars, use my brakes, free up some room, and have some more adjust-ability. I would still have to deal with bump steer but from the way you sound its doable. http://www.gerstsuspensions.com/coil-over-conversion-kit.html Has anyone ran this ^^? I wonder how much travel it has at the wheel? I have to say I like the looks of the LCA arms in a493demons photos though. looks identical to my CAP lca's and radius rod's , I also run their upper controll arm's and have had no issues, now I just need to find someone that has a tubular K frame that is set up with rack and pinion steering and no motor mounts (i use a plate) so I can use all the stuff that I already have, including my Strange brakes.
[Re: SpareParts]
#1973248
12/20/15 02:46 PM
12/20/15 02:46 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
It kinda looks like the old Dillinger Chassis stuff that's no longer available Got a set of dillinger lca setting on shelf collecting dust.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: dartman366]
#1973250
12/20/15 02:47 PM
12/20/15 02:47 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I really like this idea as with other projects it would keep costs down. What do you think of this system Doug as I could get rid of the tortion bars, use my brakes, free up some room, and have some more adjust-ability. I would still have to deal with bump steer but from the way you sound its doable. http://www.gerstsuspensions.com/coil-over-conversion-kit.html Has anyone ran this ^^? I wonder how much travel it has at the wheel? I have to say I like the looks of the LCA arms in a493demons photos though. looks identical to my CAP lca's and radius rod's , I also run their upper controll arm's and have had no issues, now I just need to find someone that has a tubular K frame that is set up with rack and pinion steering and no motor mounts (i use a plate) so I can use all the stuff that I already have, including my Strange brakes. Ya I already messaged the manufacture in the link I posted to see if I could use my mopar based Wilwoods that I already have and its a no-go. I would lose lots of money selling mine and rebuying new ones.
[Re: pittsburghracer]
#1973258
12/20/15 03:04 PM
12/20/15 03:04 PM
dartman366
Mt. Vernon, Ohio
John, what spindles are you using and are you planning on changing those also, I would have to go look at my set-up again but if I remember correct every thing bolted to the spindle flange where the origional brakes were attached.
[Re: dartman366]
#1973265
12/20/15 03:11 PM
12/20/15 03:11 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
John, what spindles are you using and are you planning on changing those also, I would have to go look at my set-up again but if I remember correct every thing bolted to the spindle flange where the origional brakes were attached. This car is all stock Mopar up front so stock mopar spindles. My small tire 74 Duster is stock mopar spindles too with an after marker system and rack n pinion steering but we did LOTS of work to get the steering right. My black 70 car is really the nicest with strange struts. VERY easy to work on.
#1973268
12/20/15 03:16 PM
12/20/15 03:16 PM
dartman366
Mt. Vernon, Ohio
John, what spindles are you using and are you planning on changing those also, I would have to go look at my set-up again but if I remember correct every thing bolted to the spindle flange where the origional brakes were attached. This car is all stock Mopar up front so stock mopar spindles. My small tire 74 Duster is stock mopar spindles too with an after marker system and rack n pinion steering but we did LOTS of work to get the steering right. My black 70 car is really the nicest with strange struts. VERY easy to work on. I removed the stock 76 disc spindles and went to a factory 10" drum spindle on mine.
[Re: Tig]
#1973302
12/20/15 03:55 PM
12/20/15 03:55 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
Apologies for the Hi-jacking, I've been looking at this too. What has always concerned me is how they match the rear suspension, for example, if you are using Caltracs, can you get the recommended rise / extension of 5 inches? (IIRC) My car is street/strip and runs Cal-Tracs and not real fast, it ran high 6.50s with the 408 and who knows what it'll run with the 434. I need the travel for my car to work. If I understood what I read I can use my Strange brakes as they are on the large 73 and up spindle. I e-mailed Carl Gerst and asked about the travel on his coil over conversion and about using it on the street too. His reply to the travel question: On the coilover for stock k frame, at the wheel is just a hair over 5", I'd like more, but can't get a longer coilover in without hitting something unfortunately, if you braced the original shock tower with a down tube/roll cage, and mounted into the original shock tower itself, you get get a coilover long enough to get over 6" of travel. About driving it on the street: Oh yeah! This setup is far stronger than factory, and much smoother, no binding on the strut rods either, like the factory ones, all in all, much more stable front suspension.
#1973345
12/20/15 05:34 PM
12/20/15 05:34 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Currently there are two guys making tubular LCAs. I have the HDK version but Junior636 has bout the same thing and a weld-on pivot suport. I am running the HDK without a support with a little different pivot shaft, but have not had in on the road/track yet. These use 3" travel shocks and get about 4" at the spindle. My UCAs were already on the car when I bought it, and are probably 19 yrs old. That Dillinger setup was pretty nice but he dropped out I think. Junior636s stuff is the system on that GTS website. He has threads on FABO and YB. I have some pics of my setup on the install thread on my Demon in the susp section. Your car has the shock towre tied to the snout bar so you would probably not need the support hoop that HDK and junior636 offer. I still used HDKs upper shock mount that goes inside the shock tower and ties to it. It would work with that green car also. https://board.moparts.org/ubbthreads/ubbt...tml#Post1955700
[Re: Airwoofer]
#1973405
12/20/15 07:35 PM
12/20/15 07:35 PM
Posts: 153 Antioch, CA
lucky13
Antioch, CA
Currently there are two guys making tubular LCAs. I have the HDK version but Junior636 has bout the same thing and a weld-on pivot suport. I am running the HDK without a support with a little different pivot shaft, but have not had in on the road/track yet. These use 3" travel shocks and get about 4" at the spindle. My UCAs were already on the car when I bought it, and are probably 19 yrs old. That Dillinger setup was pretty nice but he dropped out I think. Junior636s stuff is the system on that GTS website. He has threads on FABO and YB. I have some pics of my setup on the install thread on my Demon in the susp section. Your car has the shock towre tied to the snout bar so you would probably not need the support hoop that HDK and junior636 offer. I still used HDKs upper shock mount that goes inside the shock tower and ties to it. It would work with that green car also. https://board.moparts.org/ubbthreads/ubbt...tml#Post1955700 not that it really matters but, the GTS system is built by 71Street over on FABO. I don't think Junior636 ever sold any of his arms, yet. Although they do look alot alike
[Re: SpareParts]
#1973470
12/20/15 09:06 PM
12/20/15 09:06 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte your gtx had a system you built right? How much travel did you have? I'm guessing you didn't need much. My problem(part of it) is on a 26" radial I need front end travel, also I am admittedly kinda cheap so I am trying to build my own.
Just can't understand some of the prices asked for these golden front ends I built my own, well before there were any aftermarket ones. Build a few and you will see why they are not cheap. My GTX had very little travel, but that was because I had it tied down and didn't need it, but could have had a LOT. I used stock upper control arms and built my own lowers and frame brackets. Since I had Wilwood brakes already, I modified a factory spindle to accept a lower balljoint just like the top and built my own steering arms. For info, most guys don't actually need NEAR as much front travel as they THINK they do
