Product recommed. to remove sealer front/rear window frames #1972679
12/19/15 02:31 PM
12/19/15 02:31 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Any recommendations on a product to remove the sealer from front and rear window frames after glass is removed?
I also need to remove the excess sealer from the stainless moldings too.
Thank you in advance for your assistance!
Re: Product recommed. to remove sealer front/rear window frames [Re: vinnyd76] #1972687
12/19/15 02:43 PM
12/19/15 02:43 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
This stuff removes everything. Wear long sleeves, gloves, eye protection, and don't use it where there is any wind. Seriously!
Chisel Gasket Remover
Re: Product recommed. to remove sealer front/rear window frames [Re: vinnyd76] #1972699
12/19/15 03:04 PM
12/19/15 03:04 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Will that product remove paint?
Re: Product recommed. to remove sealer front/rear window frames [Re: vinnyd76] #1972851
12/19/15 07:56 PM
12/19/15 07:56 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I would recomend lacquer thinner.Be careful on the painted parts.
Re: Product recommed. to remove sealer front/rear window frames [Re: vinnyd76] #1972867
12/19/15 08:20 PM
12/19/15 08:20 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Wax and grease remover
Re: Product recommed. to remove sealer front/rear window frames [Re: forphorty] #1972957
12/19/15 10:30 PM
12/19/15 10:30 PM
IN
ahy Offline
ahy  Offline
IN
If it is a rubbery adhesive, suggest adhesive remover first (3M or similar). It should be easy on the paint. If that does not work, then lacquer thinner but be careful of the paint. The gasket remover will certainly take it off... along with any paint it comes in contact with.
If it is hardened urethane, I believe you basically chisel it off (carefully) but no personal experience with this.
Re: Product recommed. to remove sealer front/rear window frames [Re: vinnyd76] #1972985
12/19/15 11:24 PM
12/19/15 11:24 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
Gasket remover will remove paint.
