Page 13 of 45 1 2 11 12 13 14 15 44 45
Re: Trick Flow heads [Re: dartman366] #1971603
12/17/15 07:28 PM
12/17/15 07:28 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I bet a certain someone can whip you up one on the water jet - no problem
Re: Trick Flow heads [Re: DoubleD] #1971610
12/17/15 07:45 PM
12/17/15 07:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
work workmaybe even one with a access plate whistling
Re: Trick Flow heads [Re: dartman366] #1971620
12/17/15 07:55 PM
12/17/15 07:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Greg(Superformance)suggested some flat alum. sheet like he did so I may go that route to get rid of the pan and keep oil out of the intake ports........
Re: Trick Flow heads [Re: Thumperdart] #1971738
12/17/15 11:00 PM
12/17/15 11:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I am curious if the Hughes 1-piece cover works OK, but recall enough complaints about the 2-piece design to rule that one out.
Re: Trick Flow heads [Re: fast68plymouth] #1973397
12/20/15 07:16 PM
12/20/15 07:16 PM
AndyF Offline
AndyF  Offline
The scrub pattern from the RAS rocker arms looks really good for almost .700 lift.
Re: Trick Flow heads [Re: fast68plymouth] #1973398
12/20/15 07:19 PM
12/20/15 07:19 PM
AndyF Offline
AndyF  Offline
I was running an out of the box Victor 383 intake. Looks like there is some room for improvement with port alignment. All of the ports look like this.
Re: Trick Flow heads [Re: AndyF] #1973419
12/20/15 07:56 PM
12/20/15 07:56 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That's almost as bad as the ports on my B engine M-1 tunnel ram. No pics right now, but it's going to take filling and re-drilling the holes and/or welding/grinding the ports walls to get it lined up-Doh!. I found out the NOS was POS.
Re: Trick Flow heads [Re: BradH] #1973429
12/20/15 08:08 PM
12/20/15 08:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
After reading about the coating not allowing the silicone to seal, I may try the 2-piece since it seems easier to get ALL surfaces tight and sealed unlike a 1-piece deal but not sold on that yet.......
Re: Trick Flow heads [Re: AndyF] #1973431
12/20/15 08:12 PM
12/20/15 08:12 PM
Jerry Kathe Offline
Jerry Kathe  Offline
The floor is lower and the roof height is the same with the TF head compared to conventional placement...really?
It may be better to leave it as a built in reversion shelf eek
Re: Trick Flow heads [Re: Jerry Kathe] #1973458
12/20/15 08:51 PM
12/20/15 08:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Go with a thicker gasket and slot the bolt holes
a little.. then port the top side if needed
wave
Re: Trick Flow heads [Re: AndyF] #1973515
12/20/15 11:10 PM
12/20/15 11:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
How's that same gasket look on the head,
Re: Trick Flow heads [Re: fast68plymouth] #1973802
12/21/15 01:47 PM
12/21/15 01:47 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Off the top of my head, I can't think of a single time where I used those fel-pro paper gaskets and they properly lined up with all the ports on any heads. Generally, when you line up one pair of ports, the ones at the other end of the head are too far from the first pair.
When those are the gaskets that will be getting used, I cut the gasket and take a little slice out of it so I can line up each pair of ports individually.
Re: Trick Flow heads [Re: fast68plymouth] #1973835
12/21/15 02:49 PM
12/21/15 02:49 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Did I understand him to say that the gasket in the photo "fits" the head as expected but the same gasket fits the intake as illustrated?
Re: Trick Flow heads [Re: fast68plymouth] #1973986
12/21/15 07:00 PM
12/21/15 07:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
I took it that way, but was commenting that "usually"(well, never in my case) does that gasket properly line up with all 4 ports on the head.
They aren't as far off as the ports are in the pic of the manifold though.
Re: Trick Flow heads [Re: fast68plymouth] #1974013
12/21/15 07:37 PM
12/21/15 07:37 PM
AndyF Offline
AndyF  Offline
I'll post a picture of the gasket on the head. It looks to me like the head was ported to the gasket but I'll double check. It would make some sense for TF to port their heads to the FelPro gasket even if the FelPro gasket doesn't fit stock heads perfectly.
I don't have a good picture that shows all four ports but this picture shows one pair. The other pair look roughly the same.
Re: Trick Flow heads [Re: fast68plymouth] #1974103
12/21/15 10:34 PM
12/21/15 10:34 PM
BradH Offline
BradH  Offline
Yep, the Fel-Pros are spaced too wide, the Indy SR gaskets are spot-on, and the Indy MW gaskets are too narrow.
For some odd reason, when Hughes CNC'd my "standard port" Victors, it looks like they spaced the ports approx. the same as Indy does their MW gaskets, so I have to cut "good" standard-port gaskets to fit that narrower port spacing. Hughes' own house-brand gaskets don't fit, either.
You'd think something this basic wouldn't be a freakin' problem, given everything else that goes into designing a head or a CNC program. This type of inconsistency plays He11 w/ intake manifold port alignment, too. realcrazy
Re: Trick Flow heads [Re: AndyF] #1974107
12/21/15 10:38 PM
12/21/15 10:38 PM
BradH Offline
BradH  Offline
Then, IIRC, the Crane "gold" should work out pretty well, too, although their adjusting screw angle may be pretty far "out there" at .600"+ lift.
Everything else I know of is probably going to sit too far to the exhaust side and require something like a B3RE "realignment kit" to pull the sweep pattern back in.
Re: Trick Flow heads [Re: BradH] #1974149
12/21/15 11:33 PM
12/21/15 11:33 PM
AndyF Offline
AndyF  Offline
I think the head porters use a certain gasket as a template but they might not tell anyone which gasket they used.
My EZ heads from MCH didn't line up with any MW gasket until I tried a Mr Gasket #302. Perfect alignment. So I'm guessing that MCH used the #302 gasket as their template.
Re: Trick Flow heads [Re: AndyF] #1974192
12/22/15 12:16 AM
12/22/15 12:16 AM
okla.
sam64 Offline
sam64  Offline
okla.
tf posted dyno numbers,but did they show the motor combination anywhere?
Re: Trick Flow heads [Re: sam64] #1974237
12/22/15 12:50 AM
12/22/15 12:50 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
A little bit of info in their SEMA vid on the build
Trick Flow Powerport Heads
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
