Re: My bracket hemi build
[Re: Triple Threat]
#1973642
12/21/15 03:02 AM
12/21/15 03:02 AM
Triple Threat
Renton Washington
For comparison sake I had a 390 LA engine in this car before. It had 2 points less compression, 11:1, a similar sized solid flat tappet. And heads that went 280@.600 That combo went 10.75@123 on pump gas.
2 points more compression, 75 more CFM of head flow at .600 and some corn juice fueling it. How much ET is that worth??? Hopefully enough haha.
Car is only legal to 10.00 as it sits....
[Re: Triple Threat]
#1973645
12/21/15 03:07 AM
12/21/15 03:07 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Yep you will be slowing it down to stay legal.
Mopar to the bone!!!
[Re: Triple Threat]
#1991631
01/16/16 12:10 AM
01/16/16 12:10 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Don't normally drop in on the GIII page, so I had missed this until now. Looks like a great build, License & more cage work may be in your future. Cant wait to see the Red Car under your shoe again, D!
[Re: Triple Threat]
#1999808
01/27/16 03:33 PM
01/27/16 03:33 PM
Triple Threat
Renton Washington
Pistons finally showed up last week so got the block bored and honed to size. Owner of the shop was happy we used the torque plate, he checked it after finishing with a bore gauge and noted it moves about .0008 with the plate not bolted down. Will begin our mock up next week. ![](http://i30.photobucket.com/albums/c302/1Fast68/9B367369-BF7A-4EA6-8607-BACFA4399C6D_zpszq2hradu.jpg) ![](http://i30.photobucket.com/albums/c302/1Fast68/B015FFC9-3F46-4F81-9211-5AF381C261B8_zpsr7mxbjl1.jpg) ![](http://i30.photobucket.com/albums/c302/1Fast68/98BEA86E-FA17-40E7-B9CA-0EDAF520B58C_zpstd1nrfmc.jpg)
[Re: Triple Threat]
#2000287
01/28/16 04:17 AM
01/28/16 04:17 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Good luck on the build, looking forward to see how it runs Be nice to know someone hear in the NW that's figuring out all the tricks to get one of these going!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Triple Threat]
#2000548
01/28/16 05:04 PM
01/28/16 05:04 PM
72Swinger
Nebraska
I agree^^^, I would sand those crowns with wet 1000 grit.
[Re: Triple Threat]
#2000613
01/28/16 06:59 PM
01/28/16 06:59 PM
Triple Threat
Renton Washington
They look sharper in the picture than real life, but i'll definitely be going over everything.
Thanks for the idea!
[Re: Triple Threat]
#2001223
01/29/16 03:29 PM
01/29/16 03:29 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
That piston looks like detonation city, as well as blocked flame travel and crevice volume up the wazoo. Would it not have been better to mill the heads some and get a much smoother dome shape even if it still ended up a tad less compression?
As for polishing pistons tops I use 1000 grit also and wet it but not with water but WD-40, it seems to clog less.
[Re: Triple Threat]
#2001228
01/29/16 03:35 PM
01/29/16 03:35 PM
HotRodDave
Kalispell Mt.
I guess I should elaborate on the detonation, those ridges beside the exhaust valve look like the worst offenders, they are gonna get real hot real fast as well as blocking flow of the last little bit of exhaust stroke and that will reduce scavenging. I would eliminate them all together. Then open up the spark plug divots for more access for the flame to travel to all surfaces faster and easier then put a big radius on everything else except above the top ring land obviously. I bet you will make more power and reliability even if it costs 1/2 point compression.
[Re: Triple Threat]
#2014381
02/18/16 01:15 AM
02/18/16 01:15 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would have gotten ceramic coatings on the pistons...oil shedding on the bottom, heat reflective on top and anti scuff on the sides
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Triple Threat]
#2014637
02/18/16 02:05 PM
02/18/16 02:05 PM
Triple Threat
Renton Washington
We did some mock up this past weekend.
Piston to Valve .075 intake .115 exhaust
My Apaches are 71.5 CC
Compression appears to be 13.5:1 based on our calculations, should work fine on E85.
[Re: Triple Threat]
#2014745
02/18/16 04:52 PM
02/18/16 04:52 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Compression appears to be 13.5:1 based on our calculations, should work fine on E85. you need bigger cam and you can send me your little one that is bigger than mine
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Triple Threat]
#2015056
02/18/16 11:45 PM
02/18/16 11:45 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Good to see you are making progress Dustin.
"Just a Bracket car dressed up like a streetcar"
[Re: Triple Threat]
#2026460
03/07/16 02:06 PM
03/07/16 02:06 PM
Triple Threat
Renton Washington
Short Block is together. Trying to have the engine completely finished this week.
