Re: Footbrake Race Converter experts - ? on 2 step vs Flash RPM
[Re: Streetwize]
#1970361
12/15/15 07:52 PM
12/15/15 07:52 PM
Posts: 8,372 fredericksburg,va
cudaman1969
fredericksburg,va
Not an expert, but the purpose of the two step was so you could floor it, then release the button on the top light. If the rpm isn't up enough it might bog since the carb is wide open, no pump shot is left. Normally we tried to get 3000-3500 stepping, with just brakes it would creep, that was the point the TB was needed. Of course depending how loose the converter is it might be a higher rpm, then could be more slippage on the top side. I had a 8 inch 3800 conv. but it would push out of the lights at 3000 so tried using all four brakes on the line lock, then going to the TB. Ended up taking all the buttons,boxes out and staging at 1900-2100 , cut good lights and ran the same times.
[Re: cudaman1969]
#1970370
12/15/15 08:07 PM
12/15/15 08:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would check what rpm you start skidding the front tires... thats gonna be the major factor.. the higher the rpm the closer you will be to your max torque.. a low rpm does hit the tires harder(its wind up that slaps the conv.. and in a lot of cases will blow the tires off at the hit... a higher rpm(closer to the stall is less of a slap to the conv).. on my TB I could NEVER come off idle.. I had to be up in the rpm to some point
[Re: Streetwize]
#1970410
12/15/15 08:59 PM
12/15/15 08:59 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have a 8 in converter that flashes around 5000 but I can only go around 2900 on the line before it slides the front tires. It leaves harder stalling foot braking as much as I can but it runs the same ET idling or 2900. I can cut a better light the higher I stall it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1970527
12/15/15 11:32 PM
12/15/15 11:32 PM
Posts: 1,030 ohio
67mprfan
ohio
I'm curious about hooking my 2 step so I can have a little more consistency and focus more on the light.if I leave higher than 3200 my 60ft is crap so I leave about 2900 with converter flashing to 5400
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#1970535
12/15/15 11:37 PM
12/15/15 11:37 PM
Thumperdart
State of confusion
I'm curious about hooking my 2 step so I can have a little more consistency and focus more on the light.if I leave higher than 3200 my 60ft is crap so I leave about 2900 with converter flashing to 5400 Your mph is definately soft for that et unless you slightly lifted.......
[Re: Thumperdart]
#1970547
12/15/15 11:50 PM
12/15/15 11:50 PM
Posts: 1,030 ohio
67mprfan
ohio
I'm curious about hooking my 2 step so I can have a little more consistency and focus more on the light.if I leave higher than 3200 my 60ft is crap so I leave about 2900 with converter flashing to 5400 Your mph is definately soft for that et unless you slightly lifted....... No I didn't lift that was on a TNT night, those days I usually chase et
[Re: 67mprfan]
#1970549
12/15/15 11:51 PM
12/15/15 11:51 PM
Thumperdart
State of confusion
Somethings up then.......
[Re: Thumperdart]
#1970567
12/16/15 12:25 AM
12/16/15 12:25 AM
D-50
North, Alabama
At all the tracks I bracket race at (6 tracks) if you use a 2 step you have to run in the Pro class with the guys with Delay boxes and trans brakes. I run in the foot brake class. No electronics at all. Also no buttons allowed (line lock on toggle switch only).
[Re: 67mprfan]
#1970572
12/16/15 12:35 AM
12/16/15 12:35 AM
MR_P_BODY
I'm curious about hooking my 2 step so I can have a little more consistency and focus more on the light.if I leave higher than 3200 my 60ft is crap so I leave about 2900 with converter flashing to 5400 When you go up n rpm.. what else are you changing.. your changing the torque point and the slap of the conv.. when I go lower on rpm I have to raise the tire pressure to compensate.. if I go up I lower the pressure.. being a 4 link I dont have to change that part.. but if a ladder bar I did have to change the front of the bars ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: D-50]
#1970649
12/16/15 02:21 AM
12/16/15 02:21 AM
Posts: 3,475 Dandridge TN
Dabee
Dandridge TN
At all the tracks I bracket race at (6 tracks) if you use a 2 step you have to run in the Pro class with the guys with Delay boxes and trans brakes. I run in the foot brake class. No electronics at all. Also no buttons allowed (line lock on toggle switch only). Same here. Are you running foot brake class using a trans brake and two step?
[Re: Streetwize]
#1970654
12/16/15 02:37 AM
12/16/15 02:37 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
There are tracks that allow a trans brake in the foot brake class, I race at 2 of them. Never understood why. They both have a electronic class which I guess just lets the racer add a crossover/delay box.
[Re: rowin4]
#1970655
12/16/15 02:41 AM
12/16/15 02:41 AM
D-50
North, Alabama
There are tracks that allow a trans brake in the foot brake class, I race at 2 of them. Never understood why. They both have a electronic class which I guess just lets the racer add a crossover/delay box. That does not make sense. Why call it a foot brake class and allow a trans brake?
[Re: Streetwize]
#1970666
12/16/15 03:04 AM
12/16/15 03:04 AM
rowin4
Being that I run a stick car I run in the foot brake class, I figure they have a slight advantage using a trans brake. I probably could eliminate the mechanical clutch linkage and put on a hydraulic slave cylinder with a solenoid hooked up to the line lock . I think that is not allowed at some tracks. Does anyone use that type of setup?
[Re: D-50]
#1970676
12/16/15 03:22 AM
12/16/15 03:22 AM
MR_P_BODY
There are tracks that allow a trans brake in the foot brake class, I race at 2 of them. Never understood why. They both have a electronic class which I guess just lets the racer add a crossover/delay box. That does not make sense. Why call it a foot brake class and allow a trans brake? Because its called no box and box.. thats the way division 3 is.. thats why I have a trans brake because its legal even in no box ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Streetwize]
#1970686
12/16/15 03:45 AM
12/16/15 03:45 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Hardly an expert, but I'll share my experience. My car is a heavy street car, and I've found that it 60's better leaving more up on the converter. 9-1/2" converter, flashes to around 4500, I've been setting the 2-step at 3000, where its nearly a half a tenth quicker than just down at 2500. I also typically don't floor it when its on the 2-step. I get just past the 2-step RPM and hold it there to leave myself some pump shot. Stomp it and let go of the brake at the same time; 2 step is just wired into the brake light circuit.
Common bracket classes up here are sportsman (footbrake, no electronics,, no 2 steps 12.00 floor), Pro (Trans-brakes & 2-steps are ok, floor is 8.00) & Super Pro (add delay boxes & electronic devices).
2-step is not considered "electronics".
[Re: StealthWedge67]
#1970723
12/16/15 10:23 AM
12/16/15 10:23 AM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
My 2-step is triggered off the brake pedal. I have it set at 3000 and it hits the tires hard but my 60's suffer due to the short wheelbase and the (too) high rate of wheelstand. If I understand what Lenny said the higher the launch speed the less violent a light car will hit the tires. Like I said it seems counter intuitive but since you are at WOT you get no torque boost from the (secondary) pump shot.
So....I was going to try 3800 and if that helps, 4200 on a 5300 flash, brake pedal is plenty stout to keep it from rolling through at 3000.
Still hoping Lenny will chime in, I may just need to call him. Again, I'm trying to visualize the fluid dynamics of the converter in those first couple 1/10's of a second after coming off the footbrake.
It's logical that generally the lighter a car is the "tighter" a given converter will be for a given gear (torque multiplication) and the hit would be a bit softer, just trying to get my head around the FB RPM vs launch RPM vs true Flash (full pull)
