Re: small block water pump suggestions with half fill block
[Re: crash520]
#1970046
12/15/15 11:05 AM
12/15/15 11:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Factory pump for A/C... it has a 8 blade pump VS a 6 blade pump on the non A/C cars.. a good flowing elec fan and shroud EDIT It will most likely need a oil cooler.. get a large one.. that oil temp puts heat into the coolant system also Also.. you can add a plate to the back of the pump fins and it acts like a anti spill plate.. some pumps come with it... just cut a thin plate round and tack it to each fin.. make sure its centered
[Re: MR_P_BODY]
#1970079
12/15/15 12:20 PM
12/15/15 12:20 PM
Posts: 7,506 Az
Crizila
Az
Factory pump for A/C... it has a 8 blade pump VS a 6 blade pump on the non A/C cars.. a good flowing elec fan and shroud EDIT It will most likely need a oil cooler.. get a large one.. that oil temp puts heat into the coolant system also Also.. you can add a plate to the back of the pump fins and it acts like a anti spill plate.. some pumps come with it... just cut a thin plate round and tack it to each fin.. make sure its centered ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) all of the above! You want to start with an oil temp gauge first, just to see where you are at. Drill and tap the drain plug and put one in. 8 blade pump with mods are always good. Stick with stock crank pulley size also.
Fastest 300
[Re: crash520]
#1970246
12/15/15 04:50 PM
12/15/15 04:50 PM
Posts: 4,457 Washington
madscientist
Washington
Just buy the Milodon pump and forget it. You don't have to screw with it.
I have never run an oil cooler. All they do is add restriction to an already restricted system. If you have 8 quarts of QUALITY OIL oil in the pan and your cooling system is correct, an oil coller is not needed.
FWIW you need FLOW. So do NOT run pullies that slow down the water pump. What you lose in HP with the WP you can gain back in better ignition timing and a cooler engine.
[Re: crash520]
#1970303
12/15/15 06:19 PM
12/15/15 06:19 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Edelbrock makes a very nice pump for smallblocks
[Re: crash520]
#1970675
12/16/15 03:21 AM
12/16/15 03:21 AM
Posts: 7,506 Az
Crizila
Az
Fantastic info guys, I have a remote filter set up with dual return feeds into the front and rear of the block somewhat like the R blocks so should I need to run an oil cooler it won't be difficult PUT AN OIL TEMP GAUGE ON IT FIRST. Otherwise, it's guess-o-matic time. A good quality synthetic oil will handle 250* without a problem ( per Royal Purple ). I run about a 3/4 fill in my 408. 1 pass and I am at 212*. Have no idea what it would line out at on the street for an extended period of time. Every engine / build is different so don't rely on what this or that guy said. Put a guage on it and run it for a while.
Fastest 300
[Re: crash520]
#1971220
12/17/15 01:03 AM
12/17/15 01:03 AM
Posts: 3,425 Toronto
mshred
Toronto
So mshred, your saying you dropped 20-30 deg by changing oil and ditching the remote oil filter? Maybe I should rephrase- it still reaches the same eventual temperature, but it takes MUCH longer to get there, and even once it reaches that temperature, it can come down from it MUCH better with the synthetic oil. Once its hot, if you idle a lot it will increase the oil temps, but if you get steady airflow from driving to hit the oil pan, it helps big time in cooling things down. I can get it from 230-240 to 200-210 degrees just from getting some air to it for a bit, and it will stay there afterwards....could never do that with the Penn oil Like Crizila said, get a guage on the pan first and run a good synthetic, you may find you dont need need a cooler or anything of that sort. Just my 2 cents and I thought for sure going back to a block mounted filter under h ot headers was going to make things worse, but it didn't. I truly believe the synthetic oil is what made the biggest difference and me personally I ditched the remote filter setup as I just was not a fan of pumping oil further then it had to be from the block, even if it did increase overall oil capacity.
[Re: crash520]
#1971567
12/17/15 06:29 PM
12/17/15 06:29 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
Is a HAlf fill above the freeze plugs or Below? Is anyone filling these through the freeze plug holes or is the only way to do it through the 2 large holes on the deck surface?
I wanna fill this bone stock 360 without pulling it apart.
[Re: Porter67]
#1971629
12/17/15 08:12 PM
12/17/15 08:12 PM
MR_P_BODY
My street racers been a half fill with a crs pump for eight years, no oil cooler needed but its limited miles and short distances.
80 Volare, not to step on the topic, but do a bit of research on your half fill.
You might find to get the results of doing a half fill you should pull your motor for many reasons.
You could probably just dump it in like you want but the end result might be little benefit without doing it the proven way.
Yep.. I agree... I leveled my block front and back and level on the deck... I put a torque plate on it to proper specs.. let it dry a couple of days then set up the other bank the same way... lots of tamping and banging on the side walls of the block with a plastic mallet to get it all settled in place ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: 1980volare]
#1971638
12/17/15 08:29 PM
12/17/15 08:29 PM
MR_P_BODY
The engine is out, and on a stand. It's a 150 dollar engine. I'm going to clean the jackets, level it and fill it from the deck, slap it back together and see how much it will take. Are you gonna street drive it.. if not then go higher on the fill ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: 1980volare]
#1973076
12/20/15 02:01 AM
12/20/15 02:01 AM
Posts: 7,506 Az
Crizila
Az
Yes. I'm thinking just lower then the water pump holes, will be fine. That will be about a 3/4 fill.
Fastest 300
[Re: crash520]
#1974730
12/22/15 08:08 PM
12/22/15 08:08 PM
Posts: 7,506 Az
Crizila
Az
Never seen my water temp over 190. Remember, if you are replacing 2/3 of the water with hard block, whats left goes through the rad 3 times as often as before. Oil temp goes up, water temp goes down.
Fastest 300
[Re: 1980volare]
#1974930
12/23/15 01:43 AM
12/23/15 01:43 AM
Posts: 7,506 Az
Crizila
Az
Crizila,you see in any crazy oil temps with it filled that high? Oil temps are up for sure, but still well within the operating range of the oil I run - at the track. As I said, I have no experience over long periods of time on the street in hot weather. Half fill, you may have to go with an oil cooler. You will just have to try it and see.
Fastest 300
