Re: small block water pump suggestions with half fill block
[Re: 1980volare]
#1971638
12/17/15 08:29 PM
12/17/15 08:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The engine is out, and on a stand. It's a 150 dollar engine. I'm going to clean the jackets, level it and fill it from the deck, slap it back together and see how much it will take. Are you gonna street drive it.. if not then go higher on the fill ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: 1980volare]
#1973076
12/20/15 02:01 AM
12/20/15 02:01 AM
Posts: 7,506 Az
Crizila
Az
Yes. I'm thinking just lower then the water pump holes, will be fine. That will be about a 3/4 fill.
Fastest 300
[Re: crash520]
#1974730
12/22/15 08:08 PM
12/22/15 08:08 PM
Posts: 7,506 Az
Crizila
Az
Never seen my water temp over 190. Remember, if you are replacing 2/3 of the water with hard block, whats left goes through the rad 3 times as often as before. Oil temp goes up, water temp goes down.
Fastest 300
[Re: 1980volare]
#1974930
12/23/15 01:43 AM
12/23/15 01:43 AM
Posts: 7,506 Az
Crizila
Az
Crizila,you see in any crazy oil temps with it filled that high? Oil temps are up for sure, but still well within the operating range of the oil I run - at the track. As I said, I have no experience over long periods of time on the street in hot weather. Half fill, you may have to go with an oil cooler. You will just have to try it and see.
Fastest 300
