Re: Trick Flow heads
[Re: AndyF]
#1969747
12/14/15 10:25 PM
12/14/15 10:25 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I should add that the Moroso valve cover gaskets don't work with the MP valve covers. The MP valve covers cut the Moroso gaskets and ruin them.
I've used the Moroso gaskets with the Indy cast covers for years without any problems but the MP valve covers ruined the Moroso gaskets almost immediately. I switched back to the thick black FelPro gaskets for the rest of the dyno session. Andy I have those gaskets and MP valve covers and haven't had any issues. My MP covers are at least 10 yrs old. Do you know if MP may have changed the valve cover. Not questioning what happened to you just wondering out loud. Thanks
Ok
[Re: HEMI472]
#1970146
12/15/15 02:03 PM
12/15/15 02:03 PM
Posts: 31,078 Oregon
AndyF
how much horsepower can be made with these heads ?? I don't see dyno numbers?? thanks Ed 330 cfm will make 650 to 700 hp depending on the rest of the combo. 600 hp should be fairly easy to make with pump gas and street/strip type cam. Trick Flow posted dyno numbers for their test engine.
[Re: B Dartman]
#1970149
12/15/15 02:04 PM
12/15/15 02:04 PM
AndyF
What's the preferred valley pan to use with aftermarket heads?
See 440 Source, Hughes, Indy, etc. all have options to choose from....thoughts? I used a stock tin valley pan with gaskets glued to each side.
[Re: AndyF]
#1970292
12/15/15 06:03 PM
12/15/15 06:03 PM
dartman366
Mt. Vernon, Ohio
See 440 Source, Hughes, Indy, etc. all have options to choose from....thoughts? I used a stock tin valley pan with gaskets glued to each side. for what its worth, I just ordered the hughes two piece from mancini for $62.00 figured it was worth a try.
[Re: dartman366]
#1970321
12/15/15 06:56 PM
12/15/15 06:56 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
I used a stock tin valley pan with gaskets glued to each side. [/quote]for what its worth, I just ordered the hughes two piece from mancini for $62.00 figured it was worth a try. [/quote] I am curious how this works out . Keep us informed Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: AndyF]
#1970391
12/15/15 08:45 PM
12/15/15 08:45 PM
cudatom
Massillon, Ohio
Do you have Trick Flow heads? It appears to me that the valve cover and the head don't line up so the gasket is in shear. The rubber can't handle the load and splits. A thick fiber gasket can handle the shear load. Thanks Andy. So the issue seems to be a combo of the head and VC. I wasnt sure from the 1st post if that was the case or if something with the VC changed.
Ok
[Re: tex013]
#1970433
12/15/15 09:38 PM
12/15/15 09:38 PM
Thumperdart
State of confusion
for what its worth, I just ordered the hughes two piece from mancini for $62.00 figured it was worth a try. [/quote] I am curious how this works out . Keep us informed Tex [/quote] Didn`t work for me but maybe you`ll have better luck.......
[Re: Thumperdart]
#1970470
12/15/15 10:32 PM
12/15/15 10:32 PM
dartman366
Mt. Vernon, Ohio
for what its worth, I just ordered the hughes two piece from mancini for $62.00 figured it was worth a try. I am curious how this works out . Keep us informed Tex [/quote] Didn`t work for me but maybe you`ll have better luck....... [/quote]awww crap, that don't sound very incouraging,,what did or didn't it do, so I know what to expect.
[Re: dartman366]
#1970490
12/15/15 10:51 PM
12/15/15 10:51 PM
Thumperdart
State of confusion
Tried it on my buddy`s 512 years ago and no matter what we did it leaked BADLY and we even tried the "Right stuff".......
[Re: Thumperdart]
#1971071
12/16/15 09:17 PM
12/16/15 09:17 PM
Posts: 867 Bellevue, NE
Charger453
Bellevue, NE
Tried it on my buddy`s 512 years ago and no matter what we did it leaked BADLY and we even tried the "Right stuff"....... Same here. Waste of damn $ but of course they'll blame it on your install. Funny how I've never had any other valley pan leak. Save yourself some time and $. My 2 cents.
[Re: fast68plymouth]
#1971331
12/17/15 08:55 AM
12/17/15 08:55 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Have to say I'm impressed with TF's response to customer feedback. Much better than other suppliers whose attitude seems to be "you will buy our half assed product and like it."
"I think its got a hemi"
[Re: Cab_Burge]
#1971591
12/17/15 07:03 PM
12/17/15 07:03 PM
dartman366
Mt. Vernon, Ohio
Note to self: don't try to save a few bucks on lower priced part's,,guess I just added one more item to the swap meet pile.lol
