Re: Does any Dodge or Ford dealer stock fuel sender floats?
[Re: Kern Dog]
#1969991
12/15/15 05:04 AM
12/15/15 05:04 AM
Posts: 1,083 SE PA
Yellow Fever
SE PA
[Re: Kern Dog]
#1970057
12/15/15 11:39 AM
12/15/15 11:39 AM
Posts: 2,336 Ball Ground, Georgia
Dixie
We have the plastic floats. When we did the sending unit production, the manufacturer did not recommend brass floats due to today's fuel formulation. They said it would eat the solder around the float and cause it to sink. Just an FYI....
[Re: mopars4ever]
#1970141
12/15/15 01:54 PM
12/15/15 01:54 PM
Posts: 737 Michigan
BlueRacer69
It was available at the local Ford dealer. Try and give one a call. I think this is the part number Motorcraft COAZ-9202-B Yeah, I think Ford used a float like that on the older 5.0 Mustangs. Check with your local Ford dealerships parts counter guy.
[Re: krautrock]
#1970291
12/15/15 06:01 PM
12/15/15 06:01 PM
RapidRobert
No thoughts on if E10 will attack solder over time but Just me I'd get one of those furd brass floats mentioned (preferably a dealer one if possible) & call it good
[Re: mopars4ever]
#1970507
12/15/15 11:15 PM
12/15/15 11:15 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
It was available at the local Ford dealer. Try and give one a call. I think this is the part number Motorcraft COAZ-9202-B Hey everyone, I went to a Mustang restoration store in Sacramento. They had one in stock in the part number listed above. It is brass. Cool thing is, they didn't try to stick me with a "Mopar" tax. I left there paying just a few pennies over $7.00 !
[Re: Kern Dog]
#1970551
12/15/15 11:53 PM
12/15/15 11:53 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Ford used them in all kinds of vehicles.Vans for sure had them.I have some stashed somewhere as I saved about a dozen at one time.Been 20 years since Ive seen them though.I do know Ford did stock them.Rocky
Chrysler Firepower
[Re: Kern Dog]
#1970687
12/16/15 03:46 AM
12/16/15 03:46 AM
Posts: 4,848 Memphis
HemiRick
Memphis
That Jeep one corroded due to water in the tank....not the gas. I use the brass ones too and have not seen one fail in an abnormally short time once. I think the gas theory eating the solder is BS.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: tman]
#1970843
12/16/15 03:11 PM
12/16/15 03:11 PM
dogdays
Fuel available to the largest percentage of car owners has had 10% ethanol (or 10%MTBE for a while) for at least 20 years. In most populated areas it is the only gasoline you can buy short of racing gas.
Thanks for posting all those links but they don't tell me anything. Four of the five are not backed by any kind of science. The Oak Ridge National Lab report was a literature search by a private firm and did not do one second of experimentation.
So all those links prove nothing.
My '64Dog had pinholes in the float, away from the sender, in 1991. I soldered them shut and it is still intact today. I would be equally leery of a plastic float as ethanol could possibly affect the plastic molecules. Most likely the float is polyethylene. Ethanol is a feedstock for polyethylene production, but not the major one which is methane.
Water in the gas? Yes there is some but you neglected to say that when the water percentage goes over a certain threshold, the alcohol/water mix segregates and forms its own layer at the bottom of the tank.
Anyway I know I won't change your mind but would like to get a valid opposing view into the discussion.
R.
