Re: Cheap tig welders. Are they worth it?
[Re: sgcuda]
#1969047
12/13/15 05:47 PM
12/13/15 05:47 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Yeah, there are plenty of cheap off-brands. If I went that route, wanted to stay with at least a known good supplier, and some place to get consumables for them. Eastwood is available from Jegs or Eastwood under $700. Hobart is available from Northern Tool for around $1,200. Then you got stands, tanks, supplies.
[image][/image]
[Re: sgcuda]
#1969067
12/13/15 06:36 PM
12/13/15 06:36 PM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Rollcage fabrication? So these are welds your life could depend on?
I would not (never, nyet, nein) buy Chinese, and/or cheapo equipment. I've used the Miller Diversion. Runs OK. Maybe a little light for chassis work. The intended use needs to be considered. Sheet metal, .083, .134. 3/16 or 1/4 thick suspension brackets, rear axle housing work, etc. If you have to run the machine with it's tongue out, it's too small.
In this economy, there are lots of deals on used, good condition, quality, name brand equipment. Local auctions, Craigslist, local welding suppliers, word of mouth. Some of it is beat to death though. Just need to be careful. I would buy a nice used Lincoln or Miller before a new 2nd class machine all day long.
[Re: sgcuda]
#1969069
12/13/15 06:38 PM
12/13/15 06:38 PM
Posts: 494 IL
EchoSixMike
IL
I lied, the new Lincoln AC TIG is Square Wave 200 and it's $1400. It's a simple machine, but superior to the Miller offering in the same range, their Diversion. http://www.weldingsuppliesfromioc.com/lincoln-square-wave-tig-200-welder-k5126-1Another issue is how much power do you need and what electrical service do you have? My Syncro 250 is good for output (310amps) but eats electricity (105 amp 230v input at full bore) You won't need high output except for aluminum IME, but if you only have say 40 amp service, you need an inverter. And transformer machine are bloody huge and heavy, which is why I have the Everlast 160STH, that's something I can lug about, and it's dual voltage. And it's cheap, so when some moron at work falls on it or something stupid, they can buy me another and I don't have to find someplace to hide their body. S/F.....Ken M
[Re: sgcuda]
#1969111
12/13/15 08:03 PM
12/13/15 08:03 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Keep looking on e-bay, Craig's list. I bought a 1973 330 Miller gold star with cooling tank, cables, pedal, a ton of rods, and cart for $550. I drove 275 miles to pick it up. Weights over 1000 pounds and has all the bells and whistles. Miller man keeps wanting me to trade it in on a new syncrowave but I won't( he has a buyer). My first one was made up with a 250 amp ac-dc Miller and a add on Linde high frequency box, only down side was starting the arc and amp adjustment. Like I said look around and stay away from the new stuff, even though they're nice, but the older rigs will still get the job done. Don't just buy the welder, the little things will add up big time, find one with most or all of the goodies, cheaper in the long run.
[Re: EchoSixMike]
#1969127
12/13/15 08:56 PM
12/13/15 08:56 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
I lied, the new Lincoln AC TIG is Square Wave 200 and it's $1400. It's a simple machine, but superior to the Miller offering in the same range, their Diversion. http://www.weldingsuppliesfromioc.com/lincoln-square-wave-tig-200-welder-k5126-1Another issue is how much power do you need and what electrical service do you have? My Syncro 250 is good for output (310amps) but eats electricity (105 amp 230v input at full bore) You won't need high output except for aluminum IME, but if you only have say 40 amp service, you need an inverter. And transformer machine are bloody huge and heavy, which is why I have the Everlast 160STH, that's something I can lug about, and it's dual voltage. And it's cheap, so when some moron at work falls on it or something stupid, they can buy me another and I don't have to find someplace to hide their body. S/F.....Ken M Ordered the new Lincoln a while back. They are on back-order and lots of customers waiting for one. On paper that thing blows the Miller Diversion 180 away, so I can't wait to try it. I did try the Miller 180 and really liked it but glad I saw the new SquareWave: if it lives up to it's specs all those off-shore brands and Miller are going to lose a pile of sales. I hope to see it in the next couple of weeks. I highly recommend Baker Gas, they are awesome to deal with. I ordered a new Miller 211 and Miller plasma cutter from them too. As an experienced welder, I find the machine capabilities and prices a little too good to be true............hopefully I'm wrong.
Mo' Farts
Moderated by "tbagger".
[Re: sgcuda]
#1969170
12/13/15 10:35 PM
12/13/15 10:35 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would like AC capability for aluminum down the road. Airgas does list Miller and Hobart together. I would love a Miller or Lincoln within budget. I have a Snap-On Mighty Mig 140 that has Tig but I haven't been able to get it to work. Plus, when I change over cables and settings, then revert back, the wire feed calibration gets wacked. Snap-On knows about this, says to just reset the feeder potentiometer. Sounds easy enough, except that all of the covers have to come off in order to do that. Next time, I might just drill a hole in the right area to access the pot with a long screwdriver, and then get on the phone with tech support to see what is wrong with my setup. Can't seem to get an arc going no matter what power level. Mig side works super. Tig does not have foot pedal option or AC. Generally, if the machine is not sold as tig specific, it will have no "start" circuit. You have to scratch start the arc. One of my welders is one of the first inverter style power sources. 200 amps, never blows a breaker, it is setup as my wire welder now, but in the old days it was my scratch start tig machine. No a/c capabilities.
[Re: sgcuda]
#1969202
12/13/15 11:28 PM
12/13/15 11:28 PM
sgcuda
It might just be that I never used a Tig welder before. Might need to find someone local to give me some hands on. Still would like the capability of welding aluminum.
[image][/image]
[Re: sgcuda]
#1969209
12/13/15 11:44 PM
12/13/15 11:44 PM
Posts: 6,018 Salem
Grizzly
Salem
What kind of welding experience do you have?
Mo' Farts
[Re: sgcuda]
#1969230
12/14/15 12:23 AM
12/14/15 12:23 AM
sgcuda
Arc, Mig, gas. Pretty good at fitting tubing. My 'Cuda was my first build long ago. Have done plenty of roll bars, back halves, lots of fabrication work. No pro by any means, but I can get the job done, without people going "OMG! Who welded THAT???".
[image][/image]
[Re: sgcuda]
#1969270
12/14/15 01:35 AM
12/14/15 01:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The one thing with alum.. you start heating it then when you see it turn shiny its ready for the bead.. the hardest part is jumping the gap on the start of the bead.. once you do that then the temp jumps across the area easy and the bead will form easy... dab, dab, dab... and so on.. when you get near the end the temp will climb so you start backing off the pedal... practice EDIT I also ball the electrode so the power will run in circles to heat better(just on alum)
[Re: sgcuda]
#1969292
12/14/15 02:05 AM
12/14/15 02:05 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
HTP and Esab have good units too. I picked up my Lincoln 225 through trading, I bought my Lincoln sp250 wire feed for 800, it is a full digital machine that is old but still runs good. I like the ability to do what I want with all of my welders. I started with a Hobart buzz box that has a tig torch and a Montgomery Wards High frequency box. 75% of the people who say they need liquid cooling really don't run enough amps to actually need it. I have a cooler that I have never even used yet. Get the best machine you can afford or wait until the right deal comes along. I waited 5 years for my tig. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Evil Spirit]
#1969306
12/14/15 02:25 AM
12/14/15 02:25 AM
Posts: 22,734 Bitopia
jcc
Bitopia
Biggest knock on the cheaper, low amperage welders is the duty cycle. I have an Eastwood 135 amp - 110v welder that I use the snot out of. Has the shield gas kit and infinate dials, not stepped ones. Pull the covers and you can't tell the difference from a Lincoln, and the Eastwood uses Tweeco consumables. Great for everything from sheet metal up to 3/16" mild steel, but I wouldn't want to do a whole cage with it, due to the 20% duty cycle. I have access to a Miler 200 for the finish cage welding. But the Eastwood is the best $300 I ever spent, other than bar tabs and hookers. 33? replies and this is the only with real world experience reply with a cheap tig?. I got a Miller Syncrowave 500, so no further comment. ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif)
[Re: jcc]
#1969325
12/14/15 03:14 AM
12/14/15 03:14 AM
MR_P_BODY
Biggest knock on the cheaper, low amperage welders is the duty cycle. I have an Eastwood 135 amp - 110v welder that I use the snot out of. Has the shield gas kit and infinate dials, not stepped ones. Pull the covers and you can't tell the difference from a Lincoln, and the Eastwood uses Tweeco consumables. Great for everything from sheet metal up to 3/16" mild steel, but I wouldn't want to do a whole cage with it, due to the 20% duty cycle. I have access to a Miler 200 for the finish cage welding. But the Eastwood is the best $300 I ever spent, other than bar tabs and hookers. 33? replies and this is the only with real world experience reply with a cheap tig?. I got a Miller Syncrowave 500, so no further comment. There isnt a reason he has to buy cheap.. as I said in one post.. get a quality rebuilt for the price he is willing to spend ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: sgcuda]
#1969329
12/14/15 03:33 AM
12/14/15 03:33 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Another vote for Miller Diversion line. Great product at a decent price
[Re: jcc]
#1969342
12/14/15 06:07 AM
12/14/15 06:07 AM
Posts: 494 IL
EchoSixMike
IL
33? replies and this is the only with real world experience reply with a cheap tig?. I got a Miller Syncrowave 500, so no further comment. I have fairly extensive experience with an Everlast 160STH, which is DC, HF start. He said he wanted an AC/DC unit. I own a Syncro 250 at one job, and use an Everlast 325 EXT at another, where we weld heads, blocks and other things that racers blow up. It's a nice machine, but outside the OP's budget, as are the HTP machines(awesome welder) as well as the higher end Miller/Lincoln units. The smaller Everlast machines seem OK, based on what I've seen, their customer support is generally replace the unit, which is a problem for guy's using a welder for income. That's what you're paying for with Miller/Lincoln, a dealer support network where you can get a loaner while your junk is being fixed. The other thing that the OP needs to address is what I brought up earlier; if you want to weld aluminum and you're looking at used transformer stuff, you better have at least a 60 amp circuit to use, with more being better. 60 amps/230v will get you to about 180-200 amp output on a transformer TIG machine, which is baseline minimum (IMO) to do decent aluminum work on anything other than sheet metal. Unless you want to buy some helium mix, but now we're getting into semi-exotic territory. S/F.....Ken M
