Prepping a stock block for racing
#1968237
12/12/15 08:42 AM
12/12/15 08:42 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Apart from sonic testing, magnafluxing & Torque Plate honing, what prep work do you do to make a factory block race ready? I was deburring my 400 block, cleaning up all the casting flash & generally smoothing my block, when a Chevy friend looked at what was doing & said I was wasting my time. Do any of you guys that work on stock block racers do any cleanup of the block? I coated all the inside surfaces with POR15 to make for a smoother surface for oil return, am I going too far?
Re: Prepping a stock block for racing
[Re: rebel]
#1968250
12/12/15 10:03 AM
12/12/15 10:03 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Chase every thread and blow them out with air. Deck and line bore check while at machine shop. Modifying oil pickup to 1/2" I think is still up for debate but I would recommend it.
[image][/image]
[Re: Locomotion]
#1968269
12/12/15 11:34 AM
12/12/15 11:34 AM
fullmetaljacket
[Re: rebel]
#1968323
12/12/15 01:05 PM
12/12/15 01:05 PM
Posts: 4,206 New York
polyspheric
New York
How will you know if you didn't completely gassed out all solvents, petro products, LocTite, etc?
You'll drive over the crank when the paint film reaches the pump.
Boffin Emeritus
[Re: polyspheric]
#1968325
12/12/15 01:10 PM
12/12/15 01:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You'll drive over the crank when the paint film reaches the pump. The factory paints the race blocks also.. I've been doing it for years also.. never had any issue of driving over the crank
[Re: FastmOp]
#1968369
12/12/15 02:29 PM
12/12/15 02:29 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would never ever use Por15 but that's just me. Heck I won't even use that crap on the bottom of my cars any more after it peeled of mine and several other Friends cars.
[Re: pittsburghracer]
#1968374
12/12/15 02:44 PM
12/12/15 02:44 PM
MR_P_BODY
I would never ever use Por15 but that's just me. Heck I won't even use that crap on the bottom of my cars any more after it peeled of mine and several other Friends cars. Same here.. I use Rustoleum .. I used Chassis Saver and POR15 on my chassis.. that stuff SUCKS.. it peels off in sheets... then I sprayed it with Rustoleum .. still holding great
[Re: rebel]
#1968422
12/12/15 03:56 PM
12/12/15 03:56 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Dont forget main studs.They have to line hone after they are installed but add strength.Degree cam also.Balance and clearance is important also.Rocky
Chrysler Firepower
[Re: rebel]
#1968507
12/12/15 06:17 PM
12/12/15 06:17 PM
polyspheric
New York
The difference: how do you know yours is as clean as a new block?
Boffin Emeritus
[Re: polyspheric]
#1968509
12/12/15 06:22 PM
12/12/15 06:22 PM
MR_P_BODY
The difference: how do you know yours is as clean as a new block? Have it hot tanked... then spray it with brake cleaner.. blow it dry.. spray paint with Rustoleum that has worked for years now
[Re: polyspheric]
#1968512
12/12/15 06:27 PM
12/12/15 06:27 PM
Posts: 1,532 off the grid
340B5
off the grid
The difference: how do you know yours is as clean as a new block? How would I know a new block is as clean as mine? Clean it once, clean it again and then when you got it clean, Clean it again.
Yeah, it's got a smallblock.
[Re: MR_P_BODY]
#1968522
12/12/15 06:42 PM
12/12/15 06:42 PM
Posts: 982 western pennsylvania
b1dartsport
The difference: how do you know yours is as clean as a new block? Have it hot tanked... then spray it with brake cleaner.. blow it dry.. sray paint with Rustoleum that has worked for years now. After you are done with all grinding, filing and block prep If you don't have access to a hot tank, take the block out on the driveway and hit all the passages with a pressure washer and blow it dry with a compressor. If you are not planning on painting anything hit it with WD40 or similar light oil because it will begin to rust almost before your eyes. wave:
