Page 4 of 5 1 2 3 4 5
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: volaredon] #196764
01/29/09 08:21 PM
01/29/09 08:21 PM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
ok.
i bought these pushrods for the conversion.
are these the right ones?
http://chucker54.stores.yahoo.net/mopper9.html
i bought them off a guy who swears there the ones for the magnum head conversion.
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: erick72] #196765
01/29/09 08:25 PM
01/29/09 08:25 PM
E
erick72 Offline OP
erick72  Offline OP
E
ok.
while looking on mancini i was wondering.are these the head bolts i need for the conversion?
http://chucker54.stores.yahoo.net/mopmagen.html
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: erick72] #196766
01/30/09 09:12 AM
01/30/09 09:12 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yup, right head bolt set, if the pushrods are the #P5007477, then yes.
2017 Grand Cherokee Overland
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: patrick] #196767
01/31/09 06:50 PM
01/31/09 06:50 PM
E
erick72 Offline OP
erick72  Offline OP
E
awesome and yes they are the right pushrods!
yay!
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: volaredon] #196768
02/01/09 01:02 PM
02/01/09 01:02 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Crap again; took 2 sets of mag heads (1 was a set off a 360-380HP crate) out to Hughes for drilling to LA intake specs, and all 4 heads are CRACKED!!! thats 3 sets of heads I had with exactly zero usable!
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: volaredon] #196769
02/02/09 12:35 AM
02/02/09 12:35 AM
E
erick72 Offline OP
erick72  Offline OP
E
that really blows!!!!!!
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: erick72] #196770
02/02/09 08:08 AM
02/02/09 08:08 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
eric, what are you running for trans/converter and gears ?
Nice, steetable 318 build I would use the EQ heads drilled for LA intakes, A performer intake with either a Thermoquad or small 600cfm Eedelbrock and a small cam like a CompCams XE25O or XE254
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: AdamR] #196771
02/02/09 03:24 PM
02/02/09 03:24 PM
E
erick72 Offline OP
erick72  Offline OP
E
haha
stock and stock!
i dont know what the rear end is.i wanna pull it out to clean it u and see what gear tag is on one of the bolts!
what are EQ heads?whats a performer intake?
i have a aluminium holley street dominator single plane if thats any good
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: erick72] #196772
02/04/09 04:11 AM
02/04/09 04:11 AM
If your car was an original small block you more than likely have the 8 1/4".
Do you see bolts around the inspection cover, on back of the housing, when looking under the car from the rear? if so ya got 8 1/4.
An 8 3/4 does not have an inspection cover and the gear or center section bolts up from the front.
How long have ya been the owner of that car?
I remember responding to a craigslist add about a guy looking for 71-72 Satellite/Roadrunner parts but lost the persons email addy.
That wasn't you was it?
Sorry if it was...
I don't really have any small block parts, I might have some connections tho, if ya still need.
Anyways what area are you located?
I'm just northeast of Detroit by the lake.
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: erick72] #196773
02/04/09 04:27 AM
02/04/09 04:27 AM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
haha
stock and stock!
A performer intake is from edelbrock and its a great 2 plane intake. Better low end torque than the M1. It's lighter too. They make an air gap performer now too that makes gobs of low end torque. My buddy has one on a 350, he had the regular performer 1st, and there is a noticeable difference. The air-gap needs a little more cam though.
I wouldn't use the single plane at all. You need a lot of cam, and RPMs to do anything with it. Unless you plan on being on the track most of the time. Go on ebay or even in the SB parts for sale on this site. You can get a used Edelbrock Performer for a 273/318 small block for less than $100.00. Make sure the threads are all clean, and if its magfluxed and clean of cracks its worth the little extra they'd charge. Buy used, then sand and paint it up.
The performer is much better for street/strip use. Also, run a thermoquad carburetor, a rebuild-able core shouldn't cost more than 40-50 bucks. Demonsizzler on this site charges 200 for a rebuild. Its worth it, still cheaper than a new carb, and anything used needs a rebuild anyways. You can get a GP sorenson kit and a book for 50 bucks too if you want to rebuild yourself.
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: RoyceFlo73] #196774
02/05/09 01:21 AM
02/05/09 01:21 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The street dominator for a small block mopar is a tourqy intake with smalish runners and plenum compared to most single planes, also the runners are as long as a dual plane so they are not like most single planes.
There is no performer air-gap for a small mopar. The performer air gap for a small chevy has the same exact ports as the non a-ir gap performer for a small chevy, the only differance is the air-gap so the ideal cam would be the same for either.
I do agree about useing the thermo quad, it is a very good carb when you consider the $$$ you would spend on something else plus the heat insulateing benifits and big 800+ cfm from a carb that will run great on a little engine.
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: HotRodDave] #196775
02/05/09 01:42 AM
02/05/09 01:42 AM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
Well then, I stand corrected. Do you still thinking the dominator is better than the performer for a street application? Then again, I suppose if he already has the Dominator thats going to be best for him. But generally speaking what would be better?
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: HotRodDave] #196776
02/05/09 02:03 AM
02/05/09 02:03 AM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Were the street dominators for 318"s? Or were they fine for 340/360's as well? I didnt know if there was more than one version or not?
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: DusterKrazy] #196777
02/05/09 11:17 AM
02/05/09 11:17 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Edelbrock used to make a "street Master 318" intake I had one on my 79 D 100 shortbed, which I had put in a 69 318 in (higher CR because the 69 heads had smaller chambers) and like the smallest Purple shaft MP cam (P/N ended in 757) with a Carter AFB 625 CFM that thing ran GREAT and pulled down some surprising MPG numbers too; (22+ on the hwy)
and I didn't drive that thing easy either; maybe it was the lack of power steering power brakes and the fact that it was a 833 OD. I was actually QUITE hard on that truck!!!!
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: DusterKrazy] #196778
02/05/09 03:59 PM
02/05/09 03:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the street dominator was intended for 273-318 engines that had low hood clearance and needed tq. The perfomer and street dominator would probably be a toss up so use what you got. Either of those two intakes will bolt up and run on a 340-360 but be down a little top end power.
The strip dominator on the other hand is desighned with the bigger 340-360 ports and will make good top end power on those motors but they tend to kill the tq a little motor needs.
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: HotRodDave] #196779
02/05/09 04:16 PM
02/05/09 04:16 PM
I have a SB street dominator. It has 318 ports & I am going to use it on mag heads
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: RapidRobert] #196780
02/05/09 06:36 PM
02/05/09 06:36 PM
Thunder Bay,ON
LilRedDave Offline
LilRedDave  Offline
Thunder Bay,ON
Here's the way to go for heads.
Clearwater EQ heads
You can't even buy the parts and labor to rebuild old heads for what these are going for.
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: LilRedDave] #196781
02/05/09 08:32 PM
02/05/09 08:32 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I found several places cheaper than them including Hughes!!!
CCH wants $350 too high; I found some for $229 each; EQ's national sales Manager has them listed on Ebay for that! These are "bare" prices/I have plenty of valves from bum cracked heads and access to valve grinding equip to "clean them up" before installing them.
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: LilRedDave] #196782
02/05/09 09:32 PM
02/05/09 09:32 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Clearwater EQ heads
carolina machine engines quoted me $100/pr less for ones set up with 2.02/1.6 SBC valves + .1" longer than stock and springs set up for a roller cam w/.55" lift. www.cmengines.com
Re: 318 build!!!!!!!!!!!!!!!!!!!! [Re: volaredon] #196783
02/06/09 12:24 PM
02/06/09 12:24 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I believe the CCH heads are not bare but have the 2.02 intakes, springs and keepers.
I have not checked out Carolina but will today.
Craig
