Re: 318 build!!!!!!!!!!!!!!!!!!!!
[Re: mopowered]
#196727
01/18/09 12:25 PM
01/18/09 12:25 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I've had both the Crosswind and the Edelbrock Air Gap...they look very similar and the crosswind did seal fine for me BUT the Air Gap is so much better quality and doesn't make as many "cooling noises" when you shut the engine off.
I have some boneyard magnum heads that I pulled myself, and they're fine...not cracked. I will say that if you run nearly any cam that's not a stock cam you'll have to change the valvesprings. I also had to grind away some casting flash on the OEM heads for pushrod clearance. I use the Summit Racing (I believe they are made by comp or crane) 7.650" Chromemoly pushrods and they are much higher quality than the MP's. Stock rockers, old "LA" M/T Valve covers, and everything seals up great.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#196728
01/18/09 03:26 PM
01/18/09 03:26 PM
Posts: 580 Detroit,Michigan USA!
erick72
ok let me get this straightl.ive had so many mixed answers i get magnum heads,i clean them,leave the stock rockers on there,put them on the engine with different head bolts since i heard there different,them i go to mancini ask for the pushrods and lifters for this setup and install those,then i get the crosswind or edelbrock intake,set it on seal it up install it,throw a carb on there and fire it up? is this right or am i missing something i really thank you guys for this help! like you don't even know!
[Re: erick72]
#196731
01/18/09 03:36 PM
01/18/09 03:36 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
you will need to replace the hydraulic lifters ... HT-2011 is the part number from summit
you will need new pushrods..they must oil the rocker arms thru the pushrods..
the one MP sells...alot of people say they are too short...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#196733
01/18/09 03:39 PM
01/18/09 03:39 PM
70AARcuda
las vegas
Tony
[Re: erick72]
#196735
01/18/09 03:49 PM
01/18/09 03:49 PM
goldduster318
Lake Orion, MI
you will need:
Magnum Heads Magnum Head Bolts Magnum Compatible Intake Manifold Magnum Intake manifold bolts Aftermarket/AMC type oil through pushrod lifters 7.650" length pushrods Magnum rocker arms (these are different from the originals) 318 Cylinder Head Gasket Magnum Intake Gasket (I recommend the edelbrock one) Valve Cover gaskets (use "LA" gaskets for 5-bolt covers and Magnums for 10 bolt covers) Exhaust Manifold or Header Gaskets
Auto cars will also need the kickdown linkage modified or replaced with a cable.
be sure to test fit the heads and pushrods and make sure that the pushrods have adequate clearance as they pass through the heads
[Re: RoyceFlo73]
#196738
01/18/09 04:38 PM
01/18/09 04:38 PM
goldduster318
Lake Orion, MI
Its extremely hard to run factory kickdown linkage with a tall intake like the RPM air gap or the crosswind, and you'd still have to customize the bracket since the magnum has vertical intake bolt holes.
[Re: goldduster318]
#196739
01/18/09 04:48 PM
01/18/09 04:48 PM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Rebuild your tranny and add a full manual VB with a B&M or Hurst cable shifter. No more kickdown linkage. Its fun to bang gears with the full manual and youll be set for future hp upgrades.
Keep old mopars alive.
[Re: 2boltmain]
#196740
01/19/09 01:23 AM
01/19/09 01:23 AM
erick72
i do have a ratchet shifter cable ran by a steel cable!
so i have to modify the kickdown bracket.has anyone done this?
could i install a manual valve body?is it that hard?
also is a bone stock 340 cam gonna work,cause i don't wanna change out the valve springs ont he magnum heads im gonna be purchasing soon.
[Re: erick72]
#196741
01/19/09 09:53 AM
01/19/09 09:53 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
ok, for heads, contact www.cmengines.com ask for a quote for some enginequest 318B heads with oem valves & keepers and GM3100 springs and retainers set up at 1.65" IH. I'd walk away from the chinese heads, I'd go for rebuilt OEM over those. the EQ 318 heads are magnum heads, made in new zeeland and sold as "iron rams" by hughes. last year I got a quote from CME for $650/pr set up like this. the 318B uses an LA intake pattern. for a 318 I'd use an eddie performer intake (can find used for about $100). I'd snag some junkyard rocker arms. the GM 3100 springs are a beehive spring w/about 350 lb/in rate and a 1.065" coil bind height. search the "best of" section for "cheap magnum spring" for more info. for a cam, I'd probably look at a comp XE256. for kickdown, I modded my 2bbl kickdown to work with an eddie RPM air gap.....
[Re: patrick]
#196742
01/19/09 09:59 AM
01/19/09 09:59 AM
Posts: 5,117 Haslett, MI
7DRRunner
Haslett, MI
there's a article in the Winter 2008 edition of Engine Masters magazine
they build a 400HP 318 LA series block on a working man's budget
FYI
"Good luck on your project."
1970 Road Runner
"Accellertii Incredibus"
[Re: patrick]
#196743
01/19/09 04:55 PM
01/19/09 04:55 PM
erick72
ok.i found some used ones for 50 bucks plus shipping.they were off a running car.with rocker arms! im gonna snag those.
