Re: Upgrage/tuning help [Re: twayne24365] #1966550
12/09/15 08:01 PM
12/09/15 08:01 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Getting the car to launch better WILL help the ETs, but based on MPH and weight of car, it is down on power a good bit from where it should be. That isn't the launch.
Re: Upgrage/tuning help [Re: Monte_Smith] #1966872
12/10/15 02:57 AM
12/10/15 02:57 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree thats its just down on power some. I use SS springs and the longer Mp shocks and I only run an 850 DP. I do have more cubes but my car is heavier and I run through a full exh. My 60's average in the low 1.50's with a best of 1.50 and I do not use the pinion snubber as it did not help any with the SS springs. I would work on the tune with the combo. I kinda feel the Victor may be a bit much for that combo also. Myself I run the Indy dual plane and thats with 4.30's and a 30 x 9 tire. Good luck with that nice Coronet. Ron
Re: Upgrage/tuning help [Re: 383man] #1967013
12/10/15 12:05 PM
12/10/15 12:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the timing set to.. it could be way down and
that will kill power... my timing slipped after a
couple of runs.. that was after I checked the timing
but I didnt get the hold down tight and it moved..
I thought I had hurt the engine being that it layed
over that much
wave
Re: Upgrage/tuning help [Re: twayne24365] #1967104
12/10/15 02:08 PM
12/10/15 02:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Let me build you a 1050 dommy.......
Re: Upgrage/tuning help [Re: twayne24365] #1967130
12/10/15 02:36 PM
12/10/15 02:36 PM
Maryland
twayne24365 Offline OP
Maryland
Timing is between 14-16 initial and 36 all in by 2500.
As for the superstock springs I didn't take any clamps off, they are on the car just the way they came brand new from Mancini.
The next day I get some time I'll run a compression test and pull the valve covers to check the rockers/lash.
It definitely doesn't seem to have the power like it did after I first got it broken in. Maybe the basic check over will turn something up
