Page 2 of 3 1 2 3
Re: 1976 grille swap help please [Re: timeklr] #1867559
07/10/15 02:43 AM
07/10/15 02:43 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
OK for the next step you will need to mount the grille less bezels and re assemble your buckets and mounts with bulb also, gather your drill, drill bits, reamer bit, paint pen or soap stone and those bezels.
Re: 1976 grille swap help please [Re: timeklr] #1867563
07/10/15 02:56 AM
07/10/15 02:56 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
Here are the coming issues 4 I believe to get it done 1 is the adjuster closest to pass side on both buckets will need a hole drilled in rad support to pass through 2 is the screw that holds the tension spring may hit depending on its length you can replace with a shorter screw grind it or drill pass hole its up to you,3 is the drivers side bezel will need to be trimmed to allow for that same adjuster that needs to pass through support but don't stress you cant see trim job when mounted 4 is the marking of your bucket mount tab holes on the rad support to bolt things up,
Re: 1976 grille swap help please [Re: timeklr] #1867568
07/10/15 03:14 AM
07/10/15 03:14 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
take the bezel and slide it up your and then get a hold f the headlight assembly guide the assembly through opening in grill its a bit of a angle and rotate thing to get it in there hold it as centered in hole as you can and slide bezel down your arm and into place best you can , were not looking for perfection yet, all will not fit together due to adjuster just holding things in place with hands to mark pass hole now, center light in bezel best you can and press on bulb assembly and wiggle a bit to get the adjuster on the pass side to leave a mark on the support, this is where you will be drilling the pass hole, remove bezel and bulb assembly, I removed grille and drilled a hole at point that adjuster marked rad support made the hole about 1" or so for wiggle room.
Re: 1976 grille swap help please [Re: timeklr] #1867570
07/10/15 03:19 AM
07/10/15 03:19 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
drivers side
Re: 1976 grille swap help please [Re: timeklr] #1867910
07/10/15 09:39 PM
07/10/15 09:39 PM
5thAve Online content
5thAve  Online Content
I did the opposite of you when I took my round headlight buckets off and took a spot weld cutter to the tabs on the bucket to leave the core support hole free. Only one or two of mine had two spot welds. It looked like the first one hit the edge of those tabs so the did a second one to make sure it stayed put.
Re: 1976 grille swap help please [Re: timeklr] #1870580
07/15/15 12:58 AM
07/15/15 12:58 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
I was thinking of going that way also but decided to go through the back since I'd be drilling mounting holes in both bucket mounts and rad support it was kinda a toss up. I got the buckets painted and final mounted today lifes good
Re: 1976 grille swap help please [Re: timeklr] #1870616
07/15/15 01:34 AM
07/15/15 01:34 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
OK next you will do the same hold in place and mark but this time mark the mounting holes you drilled in bucket mount once done dis assemble and drill
Re: 1976 grille swap help please [Re: timeklr] #1870621
07/15/15 01:38 AM
07/15/15 01:38 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
at this point I noticed the tension spring retaining scre hits a bit and just ground it down a little,
Re: 1976 grille swap help please [Re: timeklr] #1870639
07/15/15 01:50 AM
07/15/15 01:50 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
ground down
Re: 1976 grille swap help please [Re: timeklr] #1870643
07/15/15 01:52 AM
07/15/15 01:52 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
re fit and space
Re: 1976 grille swap help please [Re: timeklr] #1870644
07/15/15 01:53 AM
07/15/15 01:53 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
getting close
Re: 1976 grille swap help please [Re: timeklr] #1870650
07/15/15 01:59 AM
07/15/15 01:59 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
from here it is shimming to the depth you like and aiming the bulbs so I think you got it from here best to have your adjusters in the middle of the adjustability while shimming so it gives you an idea where your at and allows you full adjustment for fine tuning, This is my first how to so sorry if its not the best a least it is an idea on how to attack the grille swap.
Re: 1976 grille swap help please [Re: timeklr] #1870794
07/15/15 07:27 AM
07/15/15 07:27 AM
places
79powerwagon Offline
places
Nice work!
Re: 1976 grille swap help please [Re: timeklr] #1872046
07/17/15 12:13 AM
07/17/15 12:13 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
The green paint comes off with paint thinner woo hoo I was kind of worried about using stripper, time well spent.
Re: 1976 grille swap help please [Re: timeklr] #1872790
07/18/15 10:38 AM
07/18/15 10:38 AM
WV
Danny Offline
Danny  Offline
WV
Great job! Looks awesome!
Re: 1976 grille swap help please [Re: timeklr] #1873534
07/19/15 02:49 PM
07/19/15 02:49 PM
WV
Danny Offline
Danny  Offline
WV
How about a picture of the grille with the green removed? Would like to see how it looks.
Re: 1976 grille swap help please [Re: Danny] #1875479
07/22/15 12:28 AM
07/22/15 12:28 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
I'll post a pic with green completely off soon as I remove it all, the paints been a good scratch barrier while working on truck.
Re: 1976 grille swap help please [Re: timeklr] #1952133
11/16/15 02:23 AM
11/16/15 02:23 AM
So Dak
GOLDENCOMMANDO Offline
So Dak
Did you ever get all the paint removed from the grille?
Re: 1976 grille swap help please [Re: GOLDENCOMMANDO] #1966121
12/09/15 02:58 AM
12/09/15 02:58 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
Been working at it a bit need to polish it yet
Re: 1976 grille swap help please [Re: timeklr] #1966123
12/09/15 03:02 AM
12/09/15 03:02 AM
tn
timeklr Offline OP
timeklr  Offline OP
tn
cleaned not polished
Page 2 of 3 1 2 3
