Re: OK! No more BS. Time to start working.
[Re: sgcuda]
#1963912
12/05/15 07:08 PM
12/05/15 07:08 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Thanks. Yes. Gears are going back to Libert for overhaul. Not sure if just going back with pro shift rings or maybe upgrade to face plate. Haven't talked to them yet on price difference. Going to also put on a Passon aluminum case, tailhousing and side cover.
[image][/image]
[Re: sgcuda]
#1963922
12/05/15 07:16 PM
12/05/15 07:16 PM
sgcuda
I have red and yellow LED bulbs that I was going to use for a street project, but I think I will install them in the Cuda. They are the old 1157 style, so I could put the high elements on during the day. Should look cool.
[image][/image]
[Re: sgcuda]
#1964338
12/06/15 01:38 PM
12/06/15 01:38 PM
sgcuda
I could use some input for front bumper alignment. Anyone have any front end shots of their cars? My Unlimited Fiberglass bumper never really fit right. I don't know if the bumper is supposed to overlap the lower part of the grill and the valance at the same time. The angle of the bumper never really matched the angle of the front of the car. The center of the bumper is tight against the car, but the ends droop and are wide from the fenders. Might be time for a replacement. Any recommendations?
[image][/image]
[Re: sgcuda]
#1964892
12/07/15 02:11 PM
12/07/15 02:11 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Sent a couple pics to your email to help w/ the bumper.
[Re: sgcuda]
#1970580
12/16/15 12:47 AM
12/16/15 12:47 AM
sgcuda
Talked to Josh at Smith Racecraft today. Ordered custom cut Triple Adjustable Ladder bars, diagonal link and crossmember kit. Great guys. Gave me a great price. Not sure if they will be in time to go under the Christmas tree. Oh well. Pics to follow.
[image][/image]
[Re: sgcuda]
#1972956
12/19/15 10:28 PM
12/19/15 10:28 PM
sgcuda
Got metering blocks, throttle plates, axle cover coming in for Christmas. Axle cover is Strange piece in black. My question is: do I paint my rear housing in black or in silver? I thought that the silver contrast would look different. Will be painting the ladder bars black. Rear shocks for now are Koni (red) but will probably be upgrading to Summit or QA1 aluminum pieces. Frame rails, springs will be black.
[image][/image]
[Re: sgcuda]
#1973732
12/21/15 11:36 AM
12/21/15 11:36 AM
an8sec70cuda
I'd paint the rear black. Check w/ Viking for shocks. http://vi-king.com/
[Re: sgcuda]
#1975191
12/23/15 04:04 PM
12/23/15 04:04 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I think satin black looks great on most everything underneath a car.
[Re: sgcuda]
#1981048
01/01/16 02:07 PM
01/01/16 02:07 PM
sgcuda
Back to the axle bearing issue. Will probably be upgrading to rear disc brakes. That means the drum brake backing plates will be removed, taking .100" of motion out of the equation. Should fix the issue. My question is, where does the Wildwood rear brake caliper bracket attach to the housing flange? From the back or front of the flange. If it attaches from the front (axle shaft side) I'm guessing that I will have to grind the drive studs pretty short. Does anyone have a pic of the bracket on their rear axle?
[image][/image]
