Re: PPP shifter, forward or reverse pattern?
[Re: J_BODY]
#1963591
12/05/15 02:49 AM
12/05/15 02:49 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Thanks j, is that the bracket supplied by ppp or your fabbed up one?
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: 383man]
#1963735
12/05/15 12:47 PM
12/05/15 12:47 PM
Posts: 9,952 Weddington, N.C.
Streetwize
Weddington, N.C.
Ron,
Justin explained it pretty well. The 1-2 is really a can't miss with the RVB and the forward SCS gate. The only slight downside on the 2-3 is you have to ' over and up' (against the detent spring) no big deal it terms of time ti shift...but it's worth it for peace of mind hitting the ( harder and more critical to execute) 1-2 as hard as you want. As a lot of us know you can possibly 'shift past 3 and hit the '1-3' if you hit it just slightly askew with the scs rvb gate.
The ppp and similar shifters look cool, its almost like the scs/winters style gating layed over on it's side.
I like the double neutral of the PPP, thats one of the disadvantages of a conventional RVB, you cant go from high to N without downshifting through the gates.
[Re: Streetwize]
#1964146
12/06/15 12:37 AM
12/06/15 12:37 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ron,
I like the double neutral of the PPP, thats one of the disadvantages of a conventional RVB, you cant go from high to N without downshifting through the gates. Thanks Wize. Ron
[Re: mikeysmopars]
#2340291
07/20/17 11:57 AM
07/20/17 11:57 AM
Posts: 296 Germany
1964Polara
Germany
OK Ben thanx but still don't understand whats the difference whether front or rear entry. Isn't the travel distance P to R to N etc. at the lever the same whether front or rear entry? I just don't get it logically (;-))
[Re: Ben Holt]
#2340855
07/21/17 09:41 AM
07/21/17 09:41 AM
Posts: 4,717 Motor City
6PKRTSE
Motor City
I have the PPP shifter for my car with just the regular ole reverse manual valve body shift pattern and trans brake.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
