1964 Chrysler rear drum removal
#1959470
11/28/15 10:01 PM
11/28/15 10:01 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
It is expected the rear drum brake drum to not be easily removed on this '64 New Yorker but I want to make sure I am attempting to do it correctly. Once the axle nut is off then what is the proper way to pull the drum?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 1964 Chrysler rear drum removal
[Re: dfsmopars]
#1959475
11/28/15 10:08 PM
11/28/15 10:08 PM
Posts: 21,144 Niles , Ohio
therocks
Niles , Ohio
Put the nut back on but just flush with the threads.then you need the correct hub remover.The hub comes off with the drum.Do not try to use one of the socalled drum removers it will destroy the drum.The remover I have is 3 arms.They attach to the studs and lug nuts hold it on Then you tigten the center to the large stud in middle of drum.Then you smack the handle that slips on the end of the remover.The drum will pop off.Thats why you leave the large nut on but loose so threads dont get screwed up.Some say you can leave the large nut loose and drive slow in circles and they will pop.Ive never had much luck that way.The pullers are usually on Ebay for sale.I havent decided to sell mine or keep it as I dont have any early cars left.Oh yeah dont loose the keyway when the drum comes off.Rocky
Chrysler Firepower
[Re: dfsmopars]
#1959502
11/28/15 11:38 PM
11/28/15 11:38 PM
dfsmopars
Kentucky
Well guess I'll spring for one of those pullers. I made a puller on that concept but nothing seemed to move. Either the tool I made could not get the power transferred enough to pull it or my lack of confidence was the hinderance. Thanks.
[Re: hemi71x]
#1959523
11/29/15 12:11 AM
11/29/15 12:11 AM
Posts: 44,229 Bend,OR USA
Cab_Burge
Usually the driver sides are really tight, tight enough to use a rosebud Oxy acetelene torch to heat the hub up with tension on it to avoid destroying the drum and hub ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Been there, done that(ruin the drivers side hub and drum without heat) more than once ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
[Re: dfsmopars]
#1959533
11/29/15 12:28 AM
11/29/15 12:28 AM
dfsmopars
Kentucky
So the hub is pressed on a tapered axle shaft? I have an original service manual that does not give any details or illustrations.
[Re: dfsmopars]
#1959682
11/29/15 12:53 PM
11/29/15 12:53 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
You really need to use the proper tool. It requires patience, and fortitude. Removing the driver's sided drum on my Polara took three days. If it hasn't been removed in 30 or 40 years it will need some heat to help it along too. Heat the hub, tighten the tool, and smack it on the end of the tool with a sledge. Repeat as necessary and eventually you'll here a pop and it will come right off. Once you get them off, if you want to make servicing the brakes easier, you can convert your hubs to '65 and up slip on drums pretty easily. Tapered Axle Rear Brake Conversion
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: dfsmopars]
#1960175
11/30/15 11:13 AM
11/30/15 11:13 AM
therocks
Niles , Ohio
The loose and driving I tried a few times.Never worked for me.The puller always worked and as said some are tough to get off.Seems people are afaraid of hitting the handle.I use a 5 pound small sledge.Some sound like a rifle shot when they pop.Rocky
Chrysler Firepower
[Re: dfsmopars]
#1960623
12/01/15 12:09 AM
12/01/15 12:09 AM
dfsmopars
Kentucky
There is a a big difference in cost of the pullers on eBay. Are the cheap ones good enough to use twice? I don't plan on dealing with this again.
[Re: dfsmopars]
#1961104
12/01/15 04:52 PM
12/01/15 04:52 PM
therocks
Niles , Ohio
The cheap ones are just that cheap.I bought one and it lasted 1/2 a pull and the hub wasnt stuck hard.Then I bought the good one I have now.Its pulled a lot of drums and never a problem.I think mine is Mac or SnapOn but it dosent have a name I can find.It is old though.Ive never found a big problem once they come off.Just clean everything good and I use some antisieze on install even though some say not to.Drove the 57 and 62 at least 20K miles and never any problems.Rocky
Chrysler Firepower
