Re: When installing a cam...advance it? Retard it? Help.
[Re: Vert]
#1960964
12/01/15 02:56 PM
12/01/15 02:56 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Am I the only one that thinks having those heads milled for a compression boost is worthwhile? Is there enough squish/quench if milled .020 with a .039 gasket? 906 heads already have 0.100 in the shallow end, correct? Since it already apart... every little bit helps. C'mon now. Nitrous or boost fixes lack of compression. ![fan fan](/ubbthreads/images/graemlins/custom/fan.gif) I'd have to see how much that would set me back to have the heads milled if it were worth it. Also would the intake have to be milled also?
[Re: 69B3GT]
#1960988
12/01/15 03:26 PM
12/01/15 03:26 PM
Posts: 5,167 CT
GTX MATT
CT
300 to mill a set of heads is steep, but I know alot of shops charge more if you have them milled alot. Realistically you can get a set of 906s down to 74 CC without going crazy milling. If a shop will do it for $100 bucks thats worth it, as it'd bump compression around 3/4 of a point.
The cheapest thing to do is find a set of stock pistons from an earlier engine and swing them in. I've sold a couple sets from engines I've torn down.
[Re: Jerry]
#1961201
12/01/15 08:22 PM
12/01/15 08:22 PM
RapidRobert
First I would mockup first & see how far the intake bolt holes (or better yet the top/bottom alignment of the ports) are in the "V" above or below dead centered in the intake manifold bolt hole "tunnel". this way when they mill the deck(s) they can mill the intake face more or less than the prescribed (.012 for .010) amount (as needed) so you end up with dead on alignment. they'll do the math to effect the slope change amt & you're paying likely the same or close to it anyway. EDIT wouldn't hurt to mill the head intake face and the intake. You want NO vac leaks.
[Re: 69B3GT]
#1962032
12/02/15 09:35 PM
12/02/15 09:35 PM
Posts: 10,646 Freeport IL USA
poorboy
Freeport IL USA
Man, you guys just can't do this without spending a fortune, can you?
Degree in the cam, you have the stuff. Run the stock rockers. Bolt it together, bolt it in the car, have fun. Save your money for the big build you have planned.
A mild cam in a 440, in a dart, will be fun on the street. Your not drag racing, a couple of tenths of a second slower will not be noticed on the street, but the extra expense to save those extra tenths will be missed. It will buy a lot of gas! Gene
[Re: poorboy]
#1962091
12/02/15 11:07 PM
12/02/15 11:07 PM
Posts: 15,487 Florida
scratchnfotraction
A mild cam in a 440, in a dart, will be fun on the street. Your not drag racing, a couple of tenths of a second slower will not be noticed on the street, but the extra expense to save those extra tenths will be missed. It will buy a lot of gas! Gene sell those parts and buy a whiplash for 165$, cheap and works with all the stock parts. my 2 SB have never had the heads off, both whiplash rollers. the 440 got a set of gaskets,hand lapped the valves,whiplash cam/springs/lifters under 400$ got 5000 miles on it now and it is nothing but fun with it in a daily driver. just say'in
[Re: 69B3GT]
#1962596
12/03/15 07:24 PM
12/03/15 07:24 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I have degreed the last 3 cams I've put in my car, 1 Isky, 2 comps, and have always found them to be spot on where they should be when I start out "dot to dot".
The internet has a way of making the best way the ONLY way. Not degreeing a cam isn't the end of the world. If you have the tools and want to see what everyone's talking about, go for it, if not, you'll join with millions of others who have just lined the dots up with a ruler and everything has been fine.
[Re: Exit1965]
#1962608
12/03/15 07:42 PM
12/03/15 07:42 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
[Re: dogdays]
#1962617
12/03/15 07:48 PM
12/03/15 07:48 PM
scratchnfotraction
Boy, SFT, you sure got religion on those Whiplash cams!
R. after yrs of cam swaps that do nothing but make a pig until 3500 rpm with a mix-matched of stock parts/intakes/carbs/headers. it is nice to have a 165$ cam in a 300$ JY engine and have fun on the daily 100 mile grind too and from work. I happy to have one work like they said it was going to. not a race cam for sure but in traffic and at the stop light I cant stop the ear to ear grin I have.
