Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1962466
12/03/15 03:39 PM
12/03/15 03:39 PM
NE Ohio
DoubleD Offline OP
DoubleD  Offline OP
NE Ohio
The Edelbrock Victor specs are
• Cylinder Head Specifications:
• Combustion chamber volume: 170cc
• Intake runner volume: 245cc
• Exhaust runner volume: 105cc
• Intake valve diameter: 2.32"
• Exhaust valve diameter: 1.94"
• Valve stem diameter: 5/16"
• Valve guides: Maganese Bronze
• Deck thickness: 5/8"
• Valve spring diameter: 1.54"
• Valve spring maximum lift: .700"
• Rocker stud: N/A
• Guideplate: N/A
• Pushrod diameter: 5/16" or 3/8"
• Valve angle: Int. (stock) / Exh. Tipped 1.5° - 21.5°
• Exhaust port location: Stock
• Spark plug fitment: 14mm x 3/4 reach, gasket seat
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1962501
12/03/15 04:05 PM
12/03/15 04:05 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Look pretty good to me.
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1962545
12/03/15 04:43 PM
12/03/15 04:43 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
- Rich, did you o-ring those or did Stage V do that? Thanks.
Tim at FHO did the O-rings
- Rich, What the valve sizes, what's the chamber and intake runner size.
Intakes: 2.40, Ferrea, Titanium, 11/32 stem
Exhaust: 1.90, Ferrea, Titanium, 11/32 stem
Special Manley LocCap locks (no lash cap required)
Chambers worked out to be 156 cc.
I didn't measure the intake runner after porting. I just dropped golf balls down the port and then counted them. They flowed over 500 CFM.
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1962738
12/03/15 10:17 PM
12/03/15 10:17 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
And I thought my StageV replacements were doing good at 367 @ .600...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: HEMI - Gen -II 572 - head choices [Re: rickseeman] #1963153
12/04/15 02:12 PM
12/04/15 02:12 PM
California
mickm Offline
mickm  Offline
California
Originally Posted By rickseeman
How much did you pay for the Stage V's done?
rick, if that was meant for me, i'd have to look it up. that was 4 years ago or so, and i got the heads, rocker gear and reciprocating assembly in one shipment from FHO. i'll dig up the receipts, but those will be outdated prices by now.
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1963332
12/04/15 07:39 PM
12/04/15 07:39 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Dave, if you want it to run on race gas why are you only gonna run 11 to 1 compression? I'm just wondering.
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1963453
12/04/15 10:48 PM
12/04/15 10:48 PM
NE Ohio
DoubleD Offline OP
DoubleD  Offline OP
NE Ohio
Well 11-1 to 12-1 is were it will end up but even at 11-1 the chance of detonation while racing is too great to risk in my mind - especially running it lean in good air - you will never hear the detonation - putting around the street I may run 50-50 but this crud they call high test today - is just that corrodes everything! Race gas is still cheap insurance in my mind even for my lawnmower!
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1963466
12/04/15 11:05 PM
12/04/15 11:05 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I don't run a Hemi but my small block is 10.9 comp. and I have never run anything but 93 octane in it. (35* timing)
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1963627
12/05/15 08:40 AM
12/05/15 08:40 AM
pa
572charger Offline
572charger  Offline
pa
my stage v headed 605hemi is 12 to one comp on pumpgas93octane car is 2 tenths slower on112octane race gas boggles my mine every time i put race gas in it ive done it 3 different times all with the some results go figure
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: HEMI - Gen -II 572 - head choices [Re: 572charger] #1963718
12/05/15 12:10 PM
12/05/15 12:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you dont change the timing when using race
fuel.. it burns slower so you need to have it start
the burn sooner(adding timing).. I've seen this many
times when changing to a higher octane fuel
wave
Re: HEMI - Gen -II 572 - head choices [Re: DoubleD] #1963888
12/05/15 05:38 PM
12/05/15 05:38 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
It'd be nice if you could shave the pistons to put you right at 10.5:1 although I think 11to1 is fine on pump gas, it's not gonna slow the car down. I've always ran 93 octane and have never seen any corrosion, 572Charger has had the same results. If you like race gas that's fine I just always thought it was a major pain and un-needed expense.
I ran 50% race gas in my 69 Dart, then I started just running one gallon of race gas along with 4 gallons of 93 octane. Car went 9.82 with the 500" low deck, 11to1 compression, heads only flowed 325. The last day that I raced the car I tried straight 93 octane, it spun the tires and still went 9.87 at 136mph. No signs of detonation or anything.
A 572 Hemi will be FUN! I'm jealous!
Re: HEMI - Gen -II 572 - head choices [Re: 572charger] #1964081
12/05/15 11:03 PM
12/05/15 11:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Been running 11.5:1 in my Hemi's for years on 93. They are very tolerant of pump gas. Was itching to go 12:1...We will see...I recently had an issue with mine and its all torn down right now. If the block or heads end up decked, it will be 12:1 ....
