Oil in radiator #1957918
11/25/15 09:59 PM
11/25/15 09:59 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
Hello, i have a rebuilt 383 that has not fired yet. Have turned it over but thats it. anyway i noticed a little oil in my radiator when i was checking the level. What would cause this? I have no water in the oil. so it couldn't be a cracked block or head gasket correct?
Re: Oil in radiator [Re: ryanf] #1957923
11/25/15 10:15 PM
11/25/15 10:15 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
1) Pressure test...
2) Are you certain it's engine oil???
Think I'd verify it's not trans fluid if an auto car...
Rad been checked-out???
Re: Oil in radiator [Re: ryanf] #1957924
11/25/15 10:17 PM
11/25/15 10:17 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
Thanks, i have not done a pressure test. I am certain its engine oil as its a manual transmission car. Radiator has not been checked out but is a new champion alum. radiator.
Re: Oil in radiator [Re: ryanf] #1957963
11/25/15 11:20 PM
11/25/15 11:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
how much oil do you see in the rad? Did you rinse out the new rad before using it? Always rinse them out, I learned the hard way at the shop on customers cars. We have no idea what is in a new radiator when they arrive.
Re: Oil in radiator [Re: RSNOMO] #1958005
11/26/15 12:08 AM
11/26/15 12:08 AM
1) Pressure test...
that'd be my first start, pump it up to 15 & see if it holds
Re: Oil in radiator [Re: ryanf] #1958062
11/26/15 01:43 AM
11/26/15 01:43 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
ok thanks, i'll pick up one of those kits tomorrow or friday, fill it back up and test it. How long should it hold 15? indefinitely?
Re: Oil in radiator [Re: ryanf] #1958113
11/26/15 02:57 AM
11/26/15 02:57 AM
ideally forever but it will vary & most seep a little. I bought an alum stat housing and drilled it with a .339 "R" drill bit then tapped for 1/8 NPT then screwed in a 1/8 NPT/schrader brass tank valve that sells at O'reillys for less than $3 then pump it up with your air chuck. took minutes from start to finish. Far cheaper than a Stant radiator pump up universal kit tho the kit has the adapter to check the cap also. Holler how it goes. EDIT Drill a miniscule hole in the stat flat ~1/32 or just use your smallest bit (wont affect cooling at all & vastly eases initial fillup time. MORE EDIT monitor your time as you'll hit 15 in seconds! EVEN MORE EDIT stat housing was pot metal or cast iron, just felt like alum when I was working with it
