Re: 6.2 heads2 [Re: Uhcoog1] #1961422
12/02/15 01:07 AM
12/02/15 01:07 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Originally Posted By Uhcoog1
Glendora Dodge Parts Manager:
Matt Deane
626-335-9992
mdeane at glendoradodge dot com
He's a hot rodder and has helped with many builds on the forum
iagree I have used Matt for years and can say he is a real parts guy
"Just a Bracket car dressed up like a streetcar"
Re: 6.2 heads2 [Re: The Shadow] #1961473
12/02/15 02:15 AM
12/02/15 02:15 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
I called Dave Weber's Modern Muscle shop today and I was told that the Super Charged head is unique, built for the Super Charger. However, they also confirmed something I wondered about. The head on the 6.4 Ram truck engine is the same head as the SC head and is drilled for an NA intake. That's the one to use if you want the non-SC intake bolt pattern. They mentioned that the main advantage of the SC or Ram head was its stronger material for boosted applications.
Re: 6.2 heads2 [Re: The Shadow] #1961830
12/02/15 05:19 PM
12/02/15 05:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: 6.2 heads2 [Re: The Shadow] #1961832
12/02/15 05:21 PM
12/02/15 05:21 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
$4250 can get you a hellcat shortblock. I want to buy one just to have one
Re: 6.2 heads2 [Re: The Shadow] #1961840
12/02/15 05:31 PM
12/02/15 05:31 PM
USA
hudsonhornet7x Offline
USA
THe blocks are listed for sale, but are not in stock. I called already lol
Re: 6.2 heads2 [Re: The Shadow] #2114833
07/21/16 02:41 PM
07/21/16 02:41 PM
Duloc
The Shadow Offline OP
Duloc
Any idea why the pn changed for the 2016 models.
Looking to finally pull the trigger and noticed they have changed
Re: 6.2 heads2 [Re: Wailin D] #2114895
07/21/16 03:54 PM
07/21/16 03:54 PM
IL
knyech1 Offline
knyech1  Offline
IL
+1
Hellcat head is unique; it's 356-T6 aluminum just like the supercharger rotor case vs. the 319 alloy the other heads use. The 6.4 truck head is also 356-T6.
Another thing that hasn't been mentioned is that the passenger side head will have dowel holes machined in them to locate the 'charger. This would obviously only apply to those who were looking to mount a supercharger. Not sure if the truck heads would have these machined holes or not. From what I can recall, I have seen sets of heads with the SC bolt pattern without the dowel holes.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: 6.2 heads2 [Re: The Shadow] #2114949
07/21/16 05:11 PM
07/21/16 05:11 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If you use the truck heads they use the standard G3 Hemi intake pattern. The Hellcat heads have a unique pattern exclusive to the superchargers. Long story short,use the truck heads.
Mopar to the bone!!!
Re: 6.2 heads2 [Re: 72Swinger] #2115071
07/21/16 08:32 PM
07/21/16 08:32 PM
Duloc
Duloc
I find find it hard to believe its the same head casting and material with different bolt pattern. It's listed $300 cheaper than a hellcat head.
Re: 6.2 heads2 [Re: The Shadow] #2115114
07/21/16 09:33 PM
07/21/16 09:33 PM
NY usa
540challenger Offline
NY usa
last time I check the truck and hellcat head were different materials.
Re: 6.2 heads2 [Re: The Shadow] #2115126
07/21/16 09:49 PM
07/21/16 09:49 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'm betting they don't have hollow stem valves either.
Re: 6.2 heads2 [Re: The Shadow] #2115177
07/21/16 10:37 PM
07/21/16 10:37 PM
Duloc
Duloc
Any insight to the pn change for 15-16 hellcat heads?
Re: 6.2 heads2 [Re: The Shadow] #2122745
08/01/16 04:43 PM
08/01/16 04:43 PM
Duloc
Duloc
Just for any interest. The heads have changed to pn 68225718ab and 19ab. They are the new pns for the 16 and 17 heads. They want up in price but the core charge is less so they are cheaper than the 15 heads. Dealer said they had no idea what the changes are.
They are on the way.
Re: 6.2 heads2 [Re: The Shadow] #2123933
08/03/16 11:33 AM
08/03/16 11:33 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Anyone have a part number for the "big gas" truck head? Aka the less expensive hellcat head
Re: 6.2 heads2 [Re: The Shadow] #2123997
08/03/16 01:10 PM
08/03/16 01:10 PM
USA
USA
CYLINDER HEAD - 2015 RAM 2500 (68280507AA) left
CYLINDER HEAD - 2015 RAM 2500 (68280506AA) right
Hope this helps!
Re: 6.2 heads2 [Re: hudsonhornet7x] #2125868
08/05/16 05:11 PM
08/05/16 05:11 PM
dogdays Offline
dogdays  Offline
Quick Google search shows the lowest price is less than $960 with the core charge added in.
Moparpartsforme.com
R.
Re: 6.2 heads2 [Re: The Shadow] #2125905
08/05/16 06:01 PM
08/05/16 06:01 PM
Duloc
Duloc
www.moparpartsdeals.com/ is the cheapest I could find.
But I did buy from waldorf dodge at the same price.
